ER-5 off the road
Discussion in 'UK Motorcycles' started by BGN, Sep 21, 2005.
  1. BGN
    BGN Guest
    FUCKING **** **** **** FUCKING BASTARD FUCKING **** **** FUCKING SHIT
    FACED **** BASTARD **** FANNY WANKER BOLLOCKS **** FUCKING SHIT SHIT
    BASTARD FACED SHITTY **** BASTARD **** FUCKING BASTARD SHIT SHIT
    BASTARD **** **** FUCKING **** BASTARD.
    **** IT.
    I CANNOT PUT INTO WORDS HOW PISSED OFF I AM.
    BASTARD.
    BGN, Sep 21, 2005
  2. In uk.rec.motorcycles, BGN amazed us all with this pearl of wisdom:
    Got a puncture?
    Whinging Courier, Sep 21, 2005
  3. BGN
    Gyp Guest
    Go on. Try.
    Gyp, Sep 21, 2005
  4. BGN
    Zanziba Guest
    The petrol goes in that little hole in the tank...
    Zanziba, Sep 21, 2005
  5. BGN
    BGN Guest
    I'm note quite ready to describe it yet.
    I'm going to shove more food in my mouth, go outside and then do
    something. I will then return and try to... Oh, I don't know.
    Words escape me.
    I need a poet to describe it.
    BGN, Sep 21, 2005
  6. In uk.rec.motorcycles, BGN amazed us all with this pearl of wisdom:
    Go and have a wank if you can't find a poet.
  7. You've binned it again, haven't you? Or else tried to service it, and
    buggered it entirely.
    I've got a nice GPz550, if you're interested ;-))
    The Older Gentleman, Sep 21, 2005
  8. BGN
    serf Guest
    Kill switch?
    serf, Sep 21, 2005
  9. BGN
    BGN Guest
    Kawasaki manual says:
    "Drive Chain Slack
    Chain Slack Adjustment
    Remove the safety clip from the torque link nut (Done)
    Loosen the rear torque link nut.
    CAUTION: DO NOT FORGET TO LOOSEN THE TORQUE LINK NUT."
    I would but the FUCKER WILL NOT BUDGE. I'm starting to round the end
    off of the nut, it's that tight. I've almost emptied a can of WD40 on
    it. I've undone the other end and moved it but that doesn't let me
    move the torque link nut.
    I am unable to loosen the chain without movig this fucking torque link
    nut.
    It might as well be welded on.
    BGN, Sep 21, 2005
  10. BGN
    BGN Guest
    buggered it entirely.[/QUOTE]
    Should adjusting the drive chain be SUCH A PROBLEM?
    OH. THE ANGER. THE RAGE. It has awoken something in me.
    Is a non-moving nut a good reason to get a new bike?
    BGN, Sep 21, 2005
  11. BGN
    Molly Guest
    Did anyone tell you that you have a way with words?
    Molly, Sep 21, 2005
  12. BGN
    It'll be corroded then. Go and do something else before you get angry
    and break it. I take it, it's a nut that goes on a stud? Both nut and
    stud are steel? Or is it a bolt that goes into alloy?
    Muck, Sep 21, 2005
  13. BGN
    BGN Guest
    Drum brake appears to be alloy, nut and bolt could be steel, but for
    the purposes of chain adjustment they might as well be the same block
    of metal.
    BGN, Sep 21, 2005
  14. Heat. Lots of it.
  15. BGN
    dwb Guest
    It has been for me - I just leave it alone now and let the shop do it when
    it's serviced.
    dwb, Sep 21, 2005
  16. In uk.rec.motorcycles, BGN amazed us all with this pearl of wisdom:
    THE ACCLAIM :)
    'It it wiv an 'ammer.
  17. BGN
    BGN Guest
    I've put the nut on it and tightened it a bit so it wont fall off and
    have now abandoned the bike outside the house otherwise I'm just going
    to get even more angry and kick the fucker over.
    The nut and stud and the steel bar which holds the rear brake in
    position seem to have become a new form of life that Does Not Budge
    even after a can of WD40 has been emptied on it.
    When I tried to loosen the chain (turned adjuster nuts wrong way) the
    bar was under so much stress that it pushed the sprocked backwards so
    that the chain got even tighter and is now so tight that I dare not
    ride it as it's bound to just snap. I can't loosen it because the bar
    doesn't want to be under any more pressure.
    That bar/torque link nut has been under so much stress/pressure for so
    long that I think some bizarre chemical reaction has taken place. I
    doubt that the torque link nut has ever been loosened in the life of
    the bike.
    BGN, Sep 21, 2005
  18. BGN
    BGN Guest
    Done that. Nothing.
    BGN, Sep 21, 2005
  19. BGN
    The Older Gentleman emerged from their own little world to say
    <snigger>
    Hythe would resemble a Portugese forest in no time.
    Try using something other than an open ended spanner from the bike toolkit
    first.
    wessie, Sep 21, 2005
  20. BGN
    SP Guest
    Are you attempting to undo it in the right direction?
    <ducks>
    Lesley
    CBR600FW
    BOTAFOT#101A UKRMHRC#12
    BONY#54P BOB#18
    http://www.wisewebservices.co.uk/lmp/
    SP, Sep 21, 2005
