ER-5 off the road
Discussion in 'UK Motorcycles' started by BGN, Sep 21, 2005.
  1. BGN
    Salad Dodger Guest
    Split pin still in place?
    | ___ Salad Dodger
    _/_____\_ GL1500SE-V/CBR1100XX-X/CBX1000Z
    |_\_____/_| ..78875.../...19634.../..30836.
    (>|_|_|<) TPPFATUICG#7 DIAABTCOD#9 YTC#4
    |__|_|__| BOTAFOT #70 BOTAFOF #09 two#11
    \|^|/ ANORAK#17 IbB#4 PM#5 WG*
    '^' RBR 2005: Abandoned.
    Salad Dodger, Sep 21, 2005
  2. BGN
    BGN Guest
    That little R-Shaped thing? Removed it.
    BGN, Sep 21, 2005
  3. BGN
    BGN Guest
    <sob> Yes. If only that were the solution.
    BGN, Sep 21, 2005
  4. BGN
    Richard A Guest
    My name is Big Gay Nick,
    I am a six foot puff,
    I cannot get my nuts undone,
    It's put me in a huff.
    Take deep breaths and remember the saying, "righty tighty, lefty
    loosey". :eek:)
    Failing that, angle grinder.
    Richard A, Sep 21, 2005
  5. BGN
    Hmm.. I can't understand why the chain is tighter when you've tried to
    slacken it off.
    Muck, Sep 21, 2005
  6. BGN
    BGN Guest
    Because That Fucking Bar is stuck in place.
    I can undo the bar at the topand move the wheel foreward and back
    perfectly, but as the nut at the bottom of That Fucking Bar is on so
    tight I can't adjust the angle that it's at which means the hole at
    the top of The Bar stays in the same place. If the nut at the bottom
    would loosen then I would have some leverage.
    Does that make sense?
    Never again will I get a bike with a drum rear.
    BGN, Sep 21, 2005
  7. BGN
    Hmm.. Look, calm down. It doesn't help anyone if you go around swearing
    at people.
    Muck, Sep 21, 2005
  8. BGN
    BGN Guest
    Heat. Lots of it.[/QUOTE]
    Will the heat from a lighter do it?
    BGN, Sep 21, 2005
  9. In uk.rec.motorcycles, BGN amazed us all with this pearl of wisdom:
    Blowtorch.
    Whinging Courier, Sep 21, 2005
  10. ...
    acetylene or angle grinder sir
    Peter Windridge, Sep 21, 2005
  11. BGN
    TMack Guest
    As others have suggested - much heat is first option (blow torch). If that
    fails then.....
    If you have a spare nut or can get a replacement then you might consider
    chiseling it free. However, this is not completely risk-free because the
    inner drum is alloy and migh fracture if too much force is applied.
    Basically you need a small sharp chisel and a hammer. Start by making an
    indentation in the middle of one of the flat faces of the nut. Then work it
    so that the chisel is eventually being applied at approx 45 degrees to the
    face and you are hammering the nut in the direction that will unscrew it.
    Plenty of firm smacks with the hammer are then applied to the chisel (NB as
    the drum is alloy do not use full swings with a lump hammer - just good
    thumps with an ordinary hammer). The combination of impact and rotational
    force will usually free off any nut that is stuck. I have done this many
    times and have hardly ever failed to move the nut eventually. For a
    (slightly) more sophisticated approach a "nut splitter" can be used (about
    £5 to buy) - this will actually cut through the nut, releasing its grip on
    the thread. If using a nut splitter you would need to support it below so
    that the impact is entirely on the captive chisel and you dont knock the
    torque bolt mounting off the drum.
    Yet another approach, if there is room to get at it, is to use a stillson
    wrench with an extender if necessary (I keep an old fork stanchion for just
    this kind of thing - slips over the end of a spanner or socket handle and
    allows greatly increased torque to be applied). The stillson gets tighter
    the more you turn so it won't slip off if it has a good grip to start with.
    However, it will mess up the nut so a replacement will be required. The
    danger with this one is that you might shear the whole thing off so proceed
    with caution.
    If none of the above work you WILL have to use an angle grinder to grind the
    nut off (the nut will be totally knackered by this time anyway) then replace
    both nut and bolt.
    Good luck
    Tony
    TMack, Sep 21, 2005
  12. BGN
    You want a nice BMW RGS: discs all round, shaft drive, and a favourite of
    gays.
    platypus, Sep 21, 2005
  13. BGN
    I think you mean, never again will I get a bike and ride it in the rain.
    Ask WC what fun can be had with disk brakes.
    Muck, Sep 21, 2005
  14. BGN
    Eatmorepies Guest
    14mm headed steel bolt that pushes through from the wheel side of the
    aluminium plate and sits in a hexagonal hole in the plate. Then the steel
    torque arm and a washer and 14mm steel nut. (They could be 13mm - anyway an
    8mm thread).
    Warm it up a bit - not too hot or you may soften the aluminium of the plate.
    Play a blowtorch over it for a minute or so.
    John
    Eatmorepies, Sep 21, 2005
  15. BGN
    Badger Guest
    That'd be oral sex, no?
    Badger, Sep 21, 2005
  16. BGN
    I'm sensing issues here.
    Pip Luscher, Sep 21, 2005
  17. BGN
    It's turned into a bunch of daffodils?
  18. BGN
    Yessssss....
    <evil snigger>
  19. BGN wrote
    See it is like that with bikes. Sometimes they just are, if you know
    what I mean.
    steve auvache, Sep 21, 2005
  20. BGN
    Eatmorepies emerged from their own little world to say
    At least that sounds cheap to fix when he rounds off the nut or snaps the
    bolt :)
    wessie, Sep 21, 2005
