ER-5 off the road
Discussion in 'UK Motorcycles' started by BGN, Sep 21, 2005.
  1. BGN
    Whinging Courier emerged from their own little world to say
    I refer the dishonourable member to the previous replies to his erroneous
    opinion.
    wessie, Sep 22, 2005
    #61
  2. In uk.rec.motorcycles, wessie amazed us all with this pearl of wisdom:
    Grrrr...
    <Grits teeth>
    Whinging Courier, Sep 22, 2005
    #62
  3. BGN
    BGN Guest
    What year is your ER5? Mine's a D1. The manual stresses in bold
    lettering that you MUST loosen that nut, and I agree with it.
    BGN, Sep 22, 2005
    #63
  4. BGN
    BGN says...
    Gas-axe the bastard.
    Lozzo, Sep 22, 2005
    #64
  5. BGN
    BGN Guest
    Gas-axe?
    BGN, Sep 22, 2005
    #65
  6. BGN wrote
    Quick fix toy for those with no patience or artistic soul.
    Angle Grinder, YKIMS
    steve auvache, Sep 22, 2005
    #66
  7. BGN
    Getting the pads out of your rear brake. Remember?
    Muck, Sep 22, 2005
    #67
  8. BGN
    OH- Guest
    I have tried to deduce what's going on here and might have
    got a rough idea by now.
    First, there is nothing inherently wrong with that bolt and
    nut. And drum brakes are easy to work on. Any bolting that
    is used outdoors needs grease (or an anti size like copaslip)
    during assembly. If this is neglected, any and all fasteners
    turn into major problems, especially to the inexperienced.
    Second, the reason that nut is secured with pin is that it
    is not meant to be tightened very hard. Yours seems to be
    so tight that you can not rotate the torque stay in
    relation to the brake shield. If that nut was not tightened
    excessively you would be able to adjust your chain slack
    without worrying about the torque stray (that's why the
    BoL does not mention it).
    Third, WD40 is a general light lubricant and water
    dispersant, not a penetrating oil. To free up a corroded
    fastener, you can use (usually with rather disappointing
    result) a penetrating oil and then you must wait for hours
    or days before trying to free the bolt or nut.
    If you showed any sign of understanding mechanical
    things I'd say that the problem is easily solved by
    total destruction of the original bolt and nut, put any
    old bolt in there temporarily and then ride to your
    dealer and get the replacement parts. As things stand,
    I'll join the choir and say "get a man in".
    This whole process is not negative, it's a good thing
    called "learning".
    OH-, Sep 22, 2005
    #68
  9. BGN
    frag Guest
    BGN? He'z just ziz guy, you know?
    If its just a nut & bolt drill the fucker out.
    Get a couple of nice new sharp drill bits.
    It sounds like you'll have to drill the head off the bolt, as thats
    accessible, which isn't hard to do.
    It'll be a damn sight quicker than struggling to undo the undoable, use
    a drill thats smaller than the head of the bolt but larger than the 8mm
    thread, say 10mm, and then you'll have the remains of the head of the
    bolt to take down to a hardware store to get new nut & bolt & washer.
    frag, Sep 23, 2005
    #69
  10. <Applause>
    The Older Gentleman, Sep 23, 2005
    #70
  11. BGN
    entwisi Guest
    Everything is for sale, it may just cost more than its worth :eek:)
    entwisi, Sep 23, 2005
    #71
  12. BGN
    I'm starting to wonder whether this whoile thread is an elaborate hoax
    - can you really be so inept that you can't sort out a simple nut &
    bolt? And if you can't, how much do you think you'll get for what is
    effectively a non-runner?
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, Sep 23, 2005
    #72
  13. BGN
    BGN Guest
    The nut & bolt would appear to not be all that simple.
    BGN, Sep 23, 2005
    #73
  14. BGN
    BGN Guest
    While trying to bodge the bike back into a usable state I appear to
    have got some movement out of That Bar. Movement in a bad way, in
    that it's now pointing downwards and is now tighter than ever.
    To get it back to how it originally was I have now removed the rear
    wheelso that I can get some leverage on The Bar to force it back to
    where it was before but it looks like it's so very, very stuck in this
    fixed position that I'm going to have trouble doing anything without
    bending The Bar, which isn't a good thing.
    I've got the weekend off, and as the bike is in a pretty stationary
    state I'm going to run around a few shops locally and see if they have
    a nut splitter/crusher or the like so they can destroy it.
    Learning is good, but not always a fun experience.
    BGN, Sep 23, 2005
    #74
  15. BGN
    BGN Guest
    Rejoice! Victory!
    I called a friend with a clue who has tools and he spent the last two
    hours working on it. After using every tool known to him, the only
    way he got it off was to file the whole thing off and then punch it
    through.
    A new nut & bolt are in place as a very temporary measure. I'll put
    the wheel back on tomorrow and then hop along to a dealer to ask them
    to order me a suitable replacement bolt.
    It was quite pleasing to see that someone with a clue took such a long
    time to do it. It's reassuring that I wasn't going about it the wrong
    way.
    BGN, Sep 23, 2005
    #75
  16. BGN
    muddy Guest
    We now return you to our regularly scheduled mayhem.
    muddy, Sep 24, 2005
    #76
  17. BGN
    If I saw someone going near any bike of mine with an angle grinder I'd
    chin them and take the bike somewhere else.
    Andy Bonwick, Sep 24, 2005
    #77
  18. BGN
    I've used a dremel on my Bandit and my FZR to good effect. Never my
    angle grinder though, far too course for what I had to do.
    Muck, Sep 24, 2005
    #78
  19. BGN
    It's the adjacent parts getting side-swiped by the angle grinder that
    would worry me.
    They're crude lumps of shit usually used by crude lumps of shit to do
    jobs that require a minimal amount of skill.
    #79
  20. BGN
    I wouldn't want to slip when cutting anything near a brake line for
    example.
    They're great for cutting up old shit to throw in the bin though, and
    for using with crude shitty arc welders.
    Muck, Sep 24, 2005
    #80
