ER-5 off the road
Discussion in 'UK Motorcycles' started by BGN, Sep 21, 2005.
  1. BGN
    Salad Dodger Guest
    <waves> :)
    They're very handy for removing rusted-up exhaust pipes - as long as
    you are not planning on re-using them.
    | ___ Salad Dodger
    _/_____\_ GL1500SE-V/CBR1100XX-X/CBX1000Z
    |_\_____/_| ..78875.../...19731.../..31242.
    (>|_|_|<) TPPFATUICG#7 DIAABTCOD#9 YTC#4
    |__|_|__| BOTAFOT #70 BOTAFOF #09 two#11
    \|^|/ ANORAK#17 IbB#4 PM#5 WG*
    '^' RBR 2005: Abandoned - Bronze Award.
    Salad Dodger, Sep 24, 2005
    #81
  2. In uk.rec.motorcycles, Andy Bonwick amazed us all with this pearl of
    wisdom:
    What an excellent turn of phrase :O)
    Whinging Courier, Sep 24, 2005
    #82
  3. BGN
    Unless you happen to be ham fisted and near a brake or petrol line.
    Muck, Sep 24, 2005
    #83
  4. BGN
    BGN Guest
    I considered using an angle grinder with the wheel still on the bike
    but saw lots of things in the way, and I didn't fancy throwing sparks
    at my shiney new BT45, chain, swingarm, hugger, and rest of bike.
    I'm sure angle grinders have their place with bikes, but I didn't feel
    the situation was ideal for angle grinding :)
    Thank you everyone for your advice.
    BGN, Sep 24, 2005
    #84
  5. Aye. The proper way to cut a lump of RSJ is to mount it in a 3 ton jig
    and carefully shave off thous of material.
    Grimly Curmudgeon, Sep 24, 2005
    #85
  6. BGN
    I always thought you should stick it in a saw and let the machine do
    the work but failing that a gas axe does the job faster and better
    than an angle grinder.
    Andy Bonwick, Sep 24, 2005
    #86
  7. Needs must, sometimes. A recip saw is wonderful and a gas axe is lovely
    but if all you have available is an AG, then that's what you use. Yes,
    I've seen some terrible AG use, but I like to think mine is fairly ok.
    #87
  8. BGN
    muddy Guest
    I take a sawzall (recip saw) on the job and use it *all* the time. It
    rocks for removing old junction boxes out of the wall without knocking a
    huge hole in the wall.
    muddy, Sep 24, 2005
    #88
  9. BGN
    Lady Nina Guest
    Lady Nina, Sep 24, 2005
    #89
  10. BGN
    zymurgy Guest
    Look, WD40 isn't any good as a penetrating oil. It's a water
    displacement and lubricant.
    Stick some Plus Gas on it and go back to it tomorrow.
    This is all in the FFAQ y'know ..
    http://www.ukrm.net/faq/Bike_Maintenance/Seized_or_damaged_fasteners_studs_bolts.html
    I know, I wrote it.
    Cheers,
    Paul.
    zymurgy, Sep 24, 2005
    #90
  11. wrote
    Or a drop or two of diesel. Kin fabulous penetrating oil diesel is.
    Well not exactly fabulous as such but very good if left to seep in for a
    day and plenty of it to be had just lying around near the exit to many
    garages.
    steve auvache, Sep 24, 2005
    #91
  12. BGN
    zymurgy Guest
    Good for dunking siezed parts in, agreed.
    Not so good for dunking your hands in though. Latex gloves or barrier
    cream are your friends with this method.
    Cheers
    Paul.
    #92
  13. And some angle grinders are lethal after all...
    http://www.barnsley-chronicle.co.uk/
    #93
  14. BGN
    I'll have to look in the local hardware shop for a 1mm disc, ta for
    that. I'd have used a saw on noise grounds alone though.
    Muck, Sep 25, 2005
    #94
  15. BGN
    Should have used a washing machine motor securely anchored to the
    floor.
    Andy Bonwick, Sep 25, 2005
    #95
  16. BGN
    Make sure that your grinder is suitable for the thinner discs. You
    might find that the lock-nut doesn't secure the disc properly and it's
    stop/crack/burst in short order.
    The good thing about 1mm discs is that cuts caused by them heal
    quicker because they don't rip out as much flesh. This theory has been
    field tested by someone I know very well.
    #96
  17. BGN
    That sounds quite nasty, and I'll take note of that sage bit of advice.
    I'll take a few measurments or take the angle grinder its self to the
    shop to see.
    Still, I'll be more likely to be using my trusty TI-85 now. :)
    Muck, Sep 25, 2005
    #97
  18. I don't see how an ancient calculator could assist in removing stuck
    nuts.
    Grimly Curmudgeon, Sep 25, 2005
    #98
  19. BGN
    Yebbut "it's only an ER-5".
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, Sep 26, 2005
    #99
  20. BGN
    MikeH Guest
    Can't see the problem - my bike always tries to lie down at garage exits.
    MikeH, Sep 27, 2005
