ER-5 Question
Discussion in 'UK Motorcycles' started by david.alderton, Apr 14, 2008.
  1. So, the MOT time comes around again, and I go over the ER5, checking
    things as best I can and move on to the lights. All lights work, front
    headlamp might need some height adjustment, indicators blink in a
    satisying manner. Pull on the front brake lever and the brake light
    works, press the rear brake and nothing.
    How does the brake light turn on, when the rear brake is applied? I've
    had the footrest hangar/brake lever assemby off, I can't see any wires
    at all in the vicinity, and it still won't come on when the lever is
    pressed. There's no obvious sign that anything is missing. Does it
    even exist?
    TIA.
  2. david.alderton
    only pre 1986 bikes can get away with just one brake light actuator,
    so your bike /should/ have a switch on the pedal.
    darsy, Apr 14, 2008
  3. david.alderton
    Sometimes they're actuated by a spring, running backwards from the
    pedal and operating a switch mounted on the frame. It could be that
    the spring is missing, hence you wouldn't look at where the switch is.
    _______
    Ace, Apr 14, 2008
  4. Thanks very much.
    Further searching has turned up that the thing that was 3 or 4 inches
    away from the lever, is, in fact, the switch, without a spring.
    Much obliged.
  5. david.alderton
    <fx: high-fives Ace>
    who would have thought that the likes of you and me could have solved
    a technical bike-related problem on our own, eh?
    darsy, Apr 14, 2008
  6. david.alderton
    Pete Fisher Guest
    In communiqué
    In the cable presumably. For future reference you might find this link
    handy (though choose the right year and allow for US peculiarities).
    http://www.babbittsonline.com/pages/parts/viewbybrand/9/Kawasaki.aspx
    | Pete Fisher at Home: |
    Pete Fisher, Apr 14, 2008
  7. david.alderton
    I'm not completely surprised that I solved it on my own, but I would
    have been if you had.
    _______
    Ace, Apr 14, 2008
  8. david.alderton
    Pete Fisher Guest
    In communiqué
    Well done. Re-reading David's follow up I assume there is a switch with
    a missing spring. Not a cable switch with no spring in the first place
    (as on SO Morini rearset installations). Still can't find it on the
    on-line parts fiche though. The logic of the categorisation of what item
    is part of which assembly would be worthy of a chapter by Pirsig.
  9. Switch is present, but the spring isn't, or I've attached it to
    something else. The HBOL was particularly unhelpful over the weekend.
    However, that website was useful, and I was shown a service manual
    with decent enough pictures to go from there.
    Am looking forward to seeing what else I can break on it this evening
    in the course of 'maintainance and preparation'...
  10. david.alderton
    Beav Guest
    I certainly will.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Apr 14, 2008
