Exhaust balance pipe - vital?
Discussion in 'UK Motorcycles' started by Pip, Jun 21, 2008.
  1. Pip
    I scored a pair of shiny chrome-ridden NOS exhausts for the Ural form
    ebay, see. Slightly different part number, but looked pretty much the
    same and the old ones were deffo shagged to the point of being beyond
    redemption.
    The question is - is a balance pipe vital? The old exhaust has a pipe
    connecting the two 'silencers' and the new one has no such provision.
    How desperate is an ancient design of low-powered flat twin, copied
    from a 1940's BMW for balance of exhaust pulses? I can't imagine it
    would affect power output too badly if the cylinder scavenging was not
    100% ... or would it?
    Anybody got a clue? Anybody GAF?
    Perhaps I ought to nosh the tow headers together into a bean-can
    collector and ram them into a spare old Bandit can stuck on the
    outside, survivor-bike stylee.
    Pip, Jun 21, 2008
  2. Pip
    Doki Guest
    However, I do know from PPC mag, that collectors are a) difficult to make
    and b) design is quite critical. Can't remember the specifics but IIRC the
    angle that the pipes meet at affects power delivery.
    Doki, Jun 21, 2008
  3. On a Urinal? No way.
    (When I remade the exhausts for my Z400 twin, I disposed of the balance
    pipe. And the earlier models didn't have them anyway).
    The Older Gentleman, Jun 21, 2008
  4. Pip
    Dan L Guest
    Hmm, well ISTR Platy's Eastern Bloc Crapster ran okay with one of the
    pipes hanging off where it joined the head. The comedy bubble machine
    noise was quite amusing too.
    Dan L
    Too much time to think, too little to do.
    http://thebikeshed.spaces.live.com/
    2002 Triumph Sprint RS 955i (It's big, and it's black)
    1996 Kawasaki ZR1100 Zephyr (Gone, but not forgotten)
    BOTAFOT #140 (KotL 2005/6/7/8)
    X-FOT#000
    DIAABTCOD #26
    BOMB#18 (slow)
    OMF#11
    Dan L, Jun 21, 2008
  5. Pip
    I'd say not - the Guzzi had balance pipes as OE but the Conti type open
    megas it has now don't.
    I'm led to believe they smooth out the pulses and have a quietening
    effect. It's been said on a twin they clear the gasses quicker but I'm
    not sure about that.
    sweller, Jun 21, 2008
  6. Pip
    I can sort of see that: ignoring pulse reflections etc then each
    cylinder has in effect two silencers at its disposal.
    Pip Luscher, Jun 21, 2008
  7. Pip
    That's how it was explained to me.
  8. Pip
    Jeweller Guest
    Would you like a small stack of "Horizontal View" (OC mag)?
    Jeweller
    R100RT
    Formerly: James Captain, A10, C15, B25, Dnepr M16 solo,
    R80/7, R100RT (green!)
    www.davidhowardjeweller.co.uk
    Jeweller, Jun 21, 2008
  9. Pip
    Pete Fisher Guest
    How to configure the exhaust system on a twin is an oft visited topic on
    the Morini list. 2:2 with balance pipe, 2:1, or 2:2 without balance
    pipe.
    All have been tried. The 'official' racing system was a 2:2 without
    balance pipe. Those that have experimented with that say it is crap (on
    the road at least). 2:1 requires matched header lengths before the join
    or they can make setting up the carbs very tricky. Given the 72 degree V
    with ports akimbo this makes for convoluted plumbing. For best all round
    results 2:2 with balance gets the votes. Though Morini took great
    trouble on OEM systems to run the rear pot pipe way up inside the
    silencer to give matched header lengths as well as using a balance pipe.
    On a flat twin, the pipe lengths are hardly an issue. So a balance pipe
    is certainly not vital IMO, though as Sweller said it might be a tad
    noisier.
    | Pete Fisher at Home: |
    Pete Fisher, Jun 21, 2008
  10. Pip
    Thanks very much for all that, Pete. Noise won't be an issue, as the
    guts of the old pipes fell out when stood upright - so the new ones
    have /got/ to be quieter of themselves (even though there is an
    audible tinkling of Russian rust and debris inside them already).
    Pip, Jun 21, 2008
  11. Pip
    After the Dnepr shed a pipe - and it ran perfectly well all the way home, if
    a little noisily - I seriously contemplated doing a 2-1 on it. The pipes
    would have run down either side to meet up behind the sump, then off to the
    left to connect to an old car back box between the bike and the chair. This
    would have looked fine and minimal, but it ended up a lot easier just giving
    my hard-earned to Mick Cross and slinging new ones on:
    http://www.facebook.com/photo.php?pid=119185&l=3f49b&id=528363400
    These had no link pipes or anything, but the performance - if I may describe
    it as such - didn't seem to be affected.
    platypus, Jun 21, 2008
  12. Pip
    Catching up with this late... as it is an old BMW lump it will be just
    fine without the cross pipe! you will be able to set up the
    carbs/tickover quite nicely.
    Hog, Jun 23, 2008
