Exhaust / Fuelling Question
Discussion in 'UK Motorcycles' started by Dan L, Jun 19, 2005.
  1. Dan L
    Dan L Guest
    When I fitted the 4 into 1 to the Zephyr I noticed that the headers, whilst
    second hand, were quite shiny and silver.
    They are now a bit bronzy looking, and I have observed that the oil
    temperature is a smidge hotter after a run than it used to be.
    The new exhaust is much thinner gauge steel than the old OEM chromed jobbie,
    so I put it down to this, as performance seems okay.
    When I had the zorst off yesterday I noticed that the valves (where visible
    through the ports) were a bit white.
    Is this something I should be worried about?
    Do the carbs need rejetting?
    Is rejetting a DIY job, or is it a black art requiring the services of the
    grand wizard of carburation (AKA Lozzo)?
    TIA
    Dan L (Oldbloke)
    M'boy's bike 2003 Honda NSR125R (Going)
    Dan L, Jun 19, 2005
  2. Dan L
    Dan L scribbled on the back of a napkin:
    That all sounds like it's running a bit leaner than it has before.
    Probably - only way to really find out is to stick a probe up its arse,
    sorry, exhaust and run it, preferably on a rolling road so you can
    figure out if it's running a bit too lean.
    With plenty of plug chops you can probably do it yourself or with some
    help from any of the esteemed members of this group.
    Timo Geusch, Jun 19, 2005
  3. Dan L
    Dan L Guest
    I am really embarrassed to admit this, but I have heard the term "plug chop"
    many times, and nodded as if I know WTF it means, but actually I don't.
    Could you enlighten me please (and don't tell anyone else I asked you).
    Dan L (Oldbloke)
    Dan L, Jun 19, 2005
  4. Dan L
    Loz H Guest
    Find a nice, clear bit of road and welly it at full/whatever throttle for a
    bit. Then, before you let off the throttle hit the kill switch, pull the
    clutch and coast to a stop. Then, whip out your plugs and check them. The
    colour of the plug will give an indication of the mixture at that amount of
    throttle.
    Loz H, Jun 19, 2005
  5. Dan L
    The simple version - you ride the bike and keep the revs up to the revs
    that you want to check the fuelling for (which you'd normally do at
    several points spread across the rev range so you can check if the
    fuelling is OK across the whole range) for a couple of minutes so the
    mixture can settle in properly, then hit the kill switch and coast to a
    halt. Easier if you also pull in the clutch...
    You then pull the spark plugs and check the colour of the deposit on
    the plug, which will tell you if it's running too lean or too rich. Or
    right, obviously.
    Nah, I'm sure that between myself and the rest of UKRM we can keep it a
    secret.
    Yeah, right.
  6. Dan L
    Dan L Guest
    Cheers Timo (and LozH).
    So, assuming it needs rejetting, is this a scientific thing or trial and
    error, because getting the carbs off is a right PITA.
    Dan L (Oldbloke)
    Dan L, Jun 19, 2005
  7. Dan L
    I'll be a right PITA because you'll end up trying several jet sizes
    until you get the right one. It'll be the same if you go on a rolling
    road or not in that case as it's mostly a case of change/adjust
    jets/needles, run bike, do it again etc pp ad nauseam.
  8. Dan L
    Loz H Guest
    Is it easy to get the tops off the carbs at all? (Assuming these are the
    same as others. I know ***** all* about Zephyrs...) If so, try raising the
    needle up a notch or so (again, assuming these carbs have needles with clips
    and notches in...). This will richen things up a touch in mid-throttle and
    may help a bit for now.
    As for doing it properly, getting it *perfect* is a right pain in the arse,
    but you may well be able to get it right enough to be better and safe by
    fiddling with the needles and increasing the size of the main jets a bit.
    A world of fiddling, and pissing the neighbours off by screwing up and down
    the road awaits you. Have fun! :eek:)
    Loz H, Jun 19, 2005
  9. Dan L
    Dan L Guest
    Fuckit then, I'll have to get the remains of the stock system over to that
    nice Mr Pip soonest to see whether he can stitch the rusty bits back to the
    rustier bits. The 4 into 1 was always only going to be a temprary fix as it
    makes the bike look unbalanced, and means I have no centrestand.
    Dan L (Oldbloke)
    Dan L, Jun 19, 2005
  10. Dan L
    Dan L Guest
    Heh, google for info about my neighbours, they're fucking cunts of the worst
    water, so this sounds like a plan.
    The zephyr carbs have shiny tops that look like pan lids which shouldn't be
    too difficult to get off. I believe there are diaphragms under them. I are
    mostly a numpty with complicated carbs, my main experience is with the
    little Mikuni VM unit off the TS50 which I have happily stripped and
    rebuilt. The zephyr carbs appear to be a slightly different animal.
    Dan L (Oldbloke)
    Dan L, Jun 19, 2005
  11. Dan L
    Andy Bonwick scribbled on the back of a napkin:
    And why do you think I mentioned the "rolling road" bit above, hmm?
  12. Andy Bonwick wrote:
    i'm reliably informed that road and track in Aylesbury are a set of
    jolly decent fellows, with the added bonus that tehy know what they're
    doing.
    Dnc
    <this space pending>
    B1200 - Back ~|~ VS800 - borked
    TS150 - squatting ~|~ V2300 - flat cap and rug
    Doesnotcompute, Jun 19, 2005
  13. Dan L
    Plug chops are free.
    sweller, Jun 19, 2005
  14. Road and Track, which are conveniently near to Oldbloke, will do him a
    dynorun for a tenner - then, if he needs anything doing, it'll end up
    costing him about 30 quid iirc[1].
    http://www.roadandtrack.co.uk/ (no affiliation, just heard good things)
    [1] they've done quite a lot of work for the local NCC county - as you
    can imagine, their machines generally need this kind of setup,
    mismatched engine/exhausts/etc
    Dnc
  15. Not to mention the fact that it might not be a jet problem, and they'd
    know this and be able to advise/fix as necessary - rather than shelling
    out time and effort on plug chopping to not solve the problem.
    Dnc
  16. Dan L
    Eiron Guest
    A permanent monitor is useful if you don't mind a bit of drilling and
    welding:
    http://www.knfilters.com/airfuelmonitors.htm
    Eiron, Jun 19, 2005
  17. Dan L
    Welcome to the club.
  18. Dan L
    There is that.
    I have a tin of Guzzi ones - **** knows where I got them - and the jets
    themselves can be easily changed at the side of the road.
    I did have a problem with jetting when I put the new 'Conti' exhausts in
    place of the old Dunstalls but after two changes I got it as right as it
    was going to be by chopping. In fact it was a lot better than before; I
    lost some of the bogging down effect caused by the oversize carbs at low
    revs and the top over rich fuelling.
    As a quick and dirty way of seeing if fuelling is a problem plug chops
    are useful and cheap but to do it, as you say, right with proof then a
    dyno is really the only option.
  19. Dan L
    Wizard Guest
    FWIW the latest edition of one of the monthly bike comics has an
    article about Taking Your Bike To A Rolling Road. I can't lay my
    hands on it ATM, but I'm 90% sure it was in RIDE.
    <8P Wizard
    Suzuki GS550 "I like that. Nicely shite" - TOG
    BMW 520i (to make Oldbloke jealous)
    ANORAK#17b BOMB#19 BOTAFOT#138 BREast#5 COFF#24
    COSOC#8 DFV#11 STG#1
    Remove location from email address to reply
    Wizard, Jun 19, 2005
  20. Dan L
    Dan L Guest
    Actually yes.
    This fuelling lark appears to be a fine / black art.
    Dan L (Oldbloke)
    Dan L, Jun 19, 2005
