Exhaust sealing advice needed
Discussion in 'UK Motorcycles' started by eatmorepies, Apr 2, 2011.
  1. eatmorepies
    eatmorepies Guest
    The downtube to collector box on my CB400T leaked. New (non-original)
    exhaust downtubes and collector box fitted by previous owner. I disassembled
    the exhaust and found the previous owner had re-used the old fibre seals -
    which were in pieces and would never seal again.
    I bought new fibre seals - they are slightly too big to go into the
    collector box and slightly too small to go over the downtubes. I've had a
    bit of a bash at the collector box entry and can slip the seals in about
    half way - they might tap in the rest of the way. I've filed a slight
    chamfer on the inner edge of the seals but they don't look like they will
    slip over the downtubes without a lot of bashing. I could have a go at
    filing 0.25mm off their inner radius - but I'm not too keen on trying that.
    These seals feel very fragile and I don't want to bash/tap them much. Any
    advice?
    If I manage to destroy them, what other method is there to seal the 3mm gap
    in the join between the tube and the box?
    John
  2. They are.
    You can buy a type of fabric tape that withstands high temperatures.
    HVAC people sell them. A length of that rolled round the headers once,
    maybe twice, and liberally slathered in exhaust gum will do the trick
    once the clamps are tightened up.
    The Older Gentleman, Apr 2, 2011
  3. eatmorepies
    eatmorepies Guest
    Gentlemen
    Thank you for that information - I will store it for future use.
    What I did:
    1. Used a JCB bucket pin (44.8mm diameter) to open the collector box inlet
    hole up a little bit and ensure roundness.
    2. Heated one of the inlet holes to cherry red and tapped a dink out of it.
    Used the bucket pin again.
    3. Used a half round file to clean said inlet holes - followed by tidying
    with various grades of emery paper until the seal could just be pushed in.
    4. Made a tubular fibre washer file with a broom handle and garnet paper.
    5. Rubbed the fibre seals on the garnet paper for some time until they
    slipped over the ends of the down pipes. (Use a brass brush as a pinning
    tool for the garnet paper as you go).
    It only took 2 hours.
    The joys of making an older bike well again.
    John
  4. eatmorepies
    TMack Guest
    If these are the shiny, grey-coloured seals that Honda often use to seal
    exhaust connections, you will probably find, on close inspection, that
    they are made up from multiple layers compressed together. I have had
    success in the past in separating and removing layers to create a thinner
    gasket.
    Alternatively...I have used Gun Gum Exhaust Repair Bandage successfully
    for such jobs - wrapped around the smaller diameter pipe end before
    insertion. Another approach - a metal shim can be made from Gun Gum
    Flexiwrap Silencer Repair (or from an old tin can) to take up the slack
    between pipes. Either of these ways alternative, together with a liberal
    application of Gun Gum putty or similar exhaust paste, should do the trick.
    TMack, Apr 3, 2011
  5. You must have steadier hands than I. I've tried that dodge, but never
    with any real success.
    The Older Gentleman, Apr 3, 2011
  6. eatmorepies
    SIRPip Guest
    Me too. I've rasped down oversized gaskets, then applied a goodly
    swipe of sealant to make up the grooves I've caused, but I've never
    managed to peel one like an onion.
    Of sealant: for permanent solutions - Hermetite (or similar) exhaust
    assembly paste, as suggested by JB. Slicks the puipes, letting them
    slide together, then goes hard with heat (either running the engine, as
    intended - or if there's a really big gap and you're afeared of it
    blowing bubbles, an externally-applied blowlamp will suffice) and sets
    like concrete.
    For joints you'll want to dismantle again, bathroom silicone sealant.
    Really. Never goes really hard and won't work if there's any direct
    pressure on it, but it seals 100% around the likes of header pipes,
    doesn't look unsightly and comes apart once you've unbolted the thing,
    with a sharp tug.
    For the best of both worlds, a relatively recent discovery: Hilti
    intumescent firestop mastic:
    http://www.hilti.co.uk/holuk/page/module/product/prca_rangedetail.jsf;js
    essionid=8A14EBAB917054B24AA64FAE57620239.node1?lang=en&nodeId=-85904
    Sticks like shit to a blanket, swells up when the engine is run,
    sealing absolutely gastight. Dismantles with a tug and a twist, cleans
    off metal easily. Bit not cheap, but certainly does a job of work.
    SIRPip, Apr 3, 2011
  7. It is fiddlearse but doable.
    Those with experience of carefully peeling a solitary ten bob note from
    the roll without disturbing the rest will probably have more success
    though.
    steve auvache, Apr 3, 2011
  8. I've met a few who could peel an orange in their pocket - such skill is
    useful in other areas, without a doubt.
    Grimly Curmudgeon, Apr 4, 2011
  9. eatmorepies
    Thomas Guest
    OK, I can easily imagine other activities that require finger
    dexterity in a pocket, but for the life of me, I can't imagine why
    anyone would need to peel an orange in a pocket. Or why this
    particular skill would ever become public knowledge.
    "Oh, I say. Did you know I can peel an orange in my pocket?"
    "Get away from me, you fuckin' pervert!"
    Thomas, Apr 4, 2011
  10. It's a byword, an analogy, for being so tight with anything they need a
    crowbar to have a shit.
  11. eatmorepies
    davethedave Guest
    Similar to "An arsehole so tight only a dog can hear them fart" ?
    davethedave, Apr 4, 2011
