Exhausting question
Discussion in 'UK Motorcycles' started by DR, Feb 8, 2010.
  1. DR
    DR Guest
    A friend has a 2008 XJR1300, fuel injected, and wants to put a
    straight-through can on it. I haven't got a clue about FI bikes - will
    it need the fuelling adjusted (i.e. Power Commander or something), or
    will it automatically adjust to suit as there's a lambda sensor in the
    exhaust?
    DR, Feb 8, 2010
  2. DR
    'Hog Guest
    Shirly a 2008 bike, which has a Catalyst, will have a fruitloop FI system,
    else said catalyst could be damaged. In which case... it will run ok but a
    PC will improve matters, is the usual answer.
    'Hog, Feb 8, 2010
  3. DR
    DR Guest
    'Hog posted:
    I'm guessing (although I don't know for sure) that the cat is in the
    standard can; certainly there's no "swelling" in the pipework, just an
    EXUP valve. The lambda sensor is downstream of the collector.
    DR, Feb 8, 2010
