External DVD RW recommendation
Discussion in 'UK Motorcycles' started by Hog, Apr 25, 2006.
  1. Hog
    Seeking recommendation on an external DVD RW
    USB or Firewire
    DVD R/RW/Dual layer at decent speeds
    Region Free
    Cheap as Chips
    The coded Matshita UJ-832 in this Vaio TX1 seems to beat DVD Region+CSS
    Free and AnyDVD. There are no firmware fixes either.
    Hog, Apr 25, 2006
  2. Hog
    John Higgins Guest
    I'm a paying customer for AnyDVD if you want a call raised to see if
    there's a fix.
    John Higgins, Apr 25, 2006
  3. Hog
    Well yes thanks VM. Spec as detailed.
    Hog, Apr 25, 2006
  4. Hog
    John Higgins Guest
    Drop me an email to the address in the headers with any messages that
    AnyDVD displays.
    John Higgins, Apr 26, 2006
  5. Hog
    John Higgins Guest
    It seems that you're out of luck and looking for another drive.
    "AnyDVD works with Matsushita (Panasonic) drives, as long as:
    1.) The drive is set to a specific region code. If your drive isn't,
    set your preferred region.
    2.) CSS protected discs match this region
    AnyDVD does not allow you with Matsushita (Panasonic) drives to watch
    or copy a CSS protected disc, which has a different region then the
    drive, unless you have a patched firmware. (AnyDVD allows this with
    every other drive)
    The reason is rather simple:
    MMC standard requires, that a drive should not reveal a title key on a
    region mismatched CSS protected disc. (It should return "Illegal
    request - region code does not match"). Some drives are even less
    restrictive and even give you the title key on region mismatch.
    But AnyDVD can usually reveal the title key with a brute force attack,
    as long as the drive allows you to read the scrambled sectors.
    Matsushita (Panasonic) drives do not! You CANNOT read the scrambled
    data, if the region code doesn't match.
    No other drive behaves this way, only Matsushita (Panasonic) drives do,
    as the standard does not require a drive to not reveal the protected
    data on region mismatch, but Matsushita (Panasonic) drives are more
    restrictive as they need to be.
    There is nothing AnyDVD, DVDDecrypter, or any other software can do
    about this. Sorry.
    Solution: Set the drive to a region, and only use matching discs.
    AnyDVD will remove CSS/Macrovision/Adverts/User prohibitions/forced
    subtitles/FBI warnings/... no problem.
    It cannot bypass region codes with Matsushita (Panasonic) drives."
  6. Hog
    Whew! well thanks. All this bollocks makes me really mad
    Hog, Apr 27, 2006
  7. Hog
    Well in the end I realised that though my IBM R32 does not have a DVD
    Writer it does have a more maleable DVD ROM which ripped Donnie Brasco
    Region1 to my network storage using AnyDVD Ripper. DVD Shrink put it on
    one DVD R using the Vaio. Interesting that once all the extra shite was
    removed it fitted on a single layer DVD with almost no compression and
    it plays beautifully. No startup crap, straight into the film as soon as
    the tray loads and just the basic credits rolling at the end.
    I used the new ImgBurn to burn the DVD. It's an update for DVD Decrypter
    and seems to work nicely.
    On the downside I may have to pay for AnyDVD :eek:)
    Hog, Apr 28, 2006
  8. Hog
    John Higgins Guest
    I always ditch the crap, especially the irritating trailers. I tend to
    convert to XViD for playback on the XBox rather than burn disks though.
    I thought it was worth every penny and the updates come through pretty
    regularly as the copy protection game progresses.
    John Higgins, Apr 28, 2006
