F*ing inboard vented twin front disk.
Discussion in 'UK Motorcycles' started by ian field, Dec 18, 2009.
  1. ian field
    ian field Guest
    Seems to seize at about 2C.
  2. ian field
    Dave Emerson Guest
    The i/b rear disk on my CBX550 caught fire once - that was an interesting
    afternoon.
    Dave Emerson, Dec 18, 2009
  3. Honda CBX550?
    ShiteOldCitroen?
    The Older Gentleman, Dec 18, 2009
  4. ian field
    ian field Guest
    When I bought the bike (complete with shiny new MOT ticket), the front brake
    was almost adequate if I never went over 30 - the rear brake only worked if
    I stood on the pedal and jumped up & down, then stayed on until the pads
    wore clear.
    The rear brake has had new seals top & bottom, cleaning up the corrosion
    took some skill not to remove too much metal, loads of silicone grease on
    re-assembly is a given.
    The front brake has had new master cylinder seals and DOT5 fluid, I worked
    the calliper pistons in & out with some fresh silicone grease - the light
    was fading by the time I'd fitted the new tyre.
    The new seals are in a drawer ready to go in and it'll probably be less of a
    bastard once that's done.
  5. ian field
    ian field Guest
    If you mean a 2CV, its probably more sophistamacated and doesn't have a
    backwards spinning engine.
  6. When they work, they're excellent, but 'cos they're shite in the long
    term I'd seriously consider different wheels/brakes/forks.
    Grimly Curmudgeon, Dec 19, 2009
  7. Bollocks. The engine in those was utterly lovely.
  8. ian field
    zymurgy Guest
    Or an Alfa Romeo.
    Inboard discs are great, keeps them away from the road grit, salt and
    shite.
    Not so good for cooling though ...
    Paul.
    zymurgy, Dec 19, 2009
  9. ian field
    SteveH Guest
    Especially when they're mounted right next to the transaxle 'box.
    SteveH, Dec 19, 2009
  10. ian field
    ian field Guest
    Not so lovely when they were new, luckily the first owner got modified cam
    chain tensioners under warranty.
    The service log also shows it had a replacement set of carbs early on in
    life.
    ian field, Dec 19, 2009
