Faled Test
Discussion in 'UK Motorcycles' started by Magpie, Aug 21, 2005.
  1. Magpie
    Your IAM observer, as are so many of them, was talking out of his/her
    arse. The examiner is correct.
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, Aug 22, 2005
  2. Magpie
    porl Guest
    Until your final shoulder check it's all about what you'd like to do isn't
    it? Otherwise why would you bother with the shoulder check? Seems a
    pointless distinction to make anyway, since it's situation dependant.
    porl, Aug 24, 2005
  3. Magpie
    why bother with a shoulder check? Just indicate, and perform your
    manoevre. If people fail to get out of your way, well, it's *your*
    problem.
    darsy, Aug 24, 2005
  4. Magpie
    Did you never hear of "Mirror, Signal, Manouever" when you learnt to
    drive? Same thing, innit? First you check it's safe for you to perform
    said manouever, then you signal to let others know your intentions,
    then you go.
    _______
    Ace, Aug 24, 2005
  5. Magpie
    porl Guest
    IME many drivers and riders, and sometimes myself, have at times indicated
    as a car approaches and you manouvre after they're passed- and I've never
    seen a panic reaction causing a pile up. The indicating isn't purely for the
    benefit of the vehicle approaching you from behind, it's also for vehicles
    directly behind you that might decide to whip out into the slipstream, and
    the driver in front of you. I maintain it's situation dependant and to put a
    hard and fast rule down is inflexible and a bit silly. The process of
    checking it's safe, etc still takes place, the action of indicating just
    occurs earlier for the purposes of more warning that would otherwise be
    preferable in some situations. It's quite simple.
    porl, Aug 24, 2005
  6. Magpie
    porl Guest
    I always shoulder check, I was questioning the apparent need for it if
    you've made a concrete decision about what you're going to do as per Mash's
    post.
    OTOH I can't see why people are getting so uptight about this. It's like
    saying "only ever use the front brake" or "always stick to the left kerb on
    the approach to a right hander". Sometimes there are exceptions.
    porl, Aug 24, 2005
