Fat Guy, Clutch Slip...
Discussion in 'Australian Motorcycles' started by Rod Bacon, Mar 7, 2005.
  1. Rod Bacon
    Rod Bacon Guest
    I am finding that I'm riding the new toy perhaps a little harder then
    Kawasaki originally intended, especially from the traffic lights. My 120Kg
    coupled with some aggressive throttle action is giving me excessive clutch
    slip at takeoff.
    I am considering sticking in some heavier clutch springs but I was wondering
    if there are any potential negative side-effects from installing heavier
    springs, other than a stiffer lever?
    Clem, maybe you'd have some advice in this area?
  2. Hello, Rod!
    You wrote on Mon, 7 Mar 2005 16:55:36 +1100:
    RB> Clem, maybe you'd have some advice in this area?
    Loose weight you fat prick rolf
    Farque Khantz, Mar 7, 2005
  3. Rod Bacon
    Rod Bacon Guest
    Hmmm...
    Sureley a set of clutch springs is easier.
  4. I have the sme problem. got myself set of Barnett Clutchpaltes and springs
    made a big difference to the power delivery. :)
    I have hydralic so I only noticed a very smll increase in clutch stiffness
    but not enouhg to mke it uncomfortble or anything.
    If it gets uncomforble you can go for braided line.
    Cheers
    Zaphod Beeblebrox, Mar 7, 2005
  5. Rod Bacon
    Johnnie5 Guest
    $50 ???
    when you put on a new one coat it in grease and then you can remove the
    cover and
    then reuse the gasket again if need be
    Johnnie5, Mar 7, 2005
  6. Hello, Knobdoodle!
    You wrote on Mon, 7 Mar 2005 18:09:51 +1000:
    ??>> Hello, Rod!
    ??>> You wrote on Mon, 7 Mar 2005 16:55:36 +1100:
    RB>>> Clem, maybe you'd have some advice in this area?
    ??>> Loose weight you fat prick rolf
    K> What's Rolf got to do with it?
    K> Clem
    K> (tie me clutch springs down sport....)
    Teach me for typing when 1/2 cut lol
  7. Rod Bacon
    GB Guest
    Clem wants to be Pat when he grows up.
    GB
    GB, Mar 7, 2005
  8. Rod Bacon
    Rod Bacon Guest
    I don't know why i didn't recall this trick myself, as I actually did
    it to a mate's 610TE... thanks for the reminder!
    Rod Bacon, Mar 8, 2005
  9. Rod Bacon
    Rod Bacon Guest
    Everybody knows that.... now.
    Thanks for the tip!
