Festive Fettling (quite long)
Discussion in 'UK Motorcycles' started by Oldbloke, Dec 22, 2003.
  1. Oldbloke
    Oldbloke Guest
    Arrived home tonight to find m'boy and his trusty sidekick had commandeered
    SWMBO's garage and had started to dismantle the TS50, so I donned my trusty
    oldest clothes and joined in.
    Things found:
    Carb not connected to airbox (dismantled, cleaned and reassembled)
    Air filter disgusting, tried to rinse it with petrol but it dissolved (puts
    new filter on list)
    Sump oil drained, sort of brown colour, but still slippery with no gritty
    bits (this is a good sign).
    Sump drain plug needs new copper washer (adds to list)
    Petrol tank drained and rinsed, some rust evident but not too alarming.
    Loud end can sort of fell off (now fettling and repainting the original
    quiet one, much to m'boy's disgust).
    Exhaust looks a bit bodged where it joins the cylinder head (suggested
    soaking in copious quantities of releasing fluid before attacking with
    spanner, so added Plus Gas to list).
    Removed dying battery (adds new one to list)
    Added HBOL to list.
    All in all a good evening's work, and strangely theraputic after an
    exceptionally shite day at work.
    Oldbloke
    2000 Honda CB500, 1991 Suzuki TS50 (m'boy's)
    BOTAFOT #140
    "He's like Robbo's chubby kid brother"
  2. Oldbloke
    On Mon, 22 Dec 2003 20:07:11 -0000, "Oldbloke"
    That's how spannering is supposed to be.
    Best of luck, fella ;-)
    Pip, Dec 22, 2003
  3. Oldbloke
    christofire Guest
    I'm itching to get to halfords to a) see if there's a sale on, and b)
    get me some proper tools. After that, it's every SOC for itself.
    christofire, Dec 22, 2003
  4. Oldbloke
    Oldbloke Guest
    I had a feeling that the oil would be different due to it being a 2 stroke,
    thanks for confirming it. I told m'boy that starting to dismantle the bike
    without a manual was a bit like playing chicken, and have suggested that
    getting a HBOL be a priority so we at least have a fighting chance of
    putting it back together as Mr Suzuki intended.
    Oldbloke
    BOTAFOT #140
    Oldbloke, Dec 23, 2003
  5. Hang about - this may be utter bollocks. Many Jap two-strokes use
    ordinary 10/40 engine oil in their gearboxes. Some use gear oil, but
    many Jap strokers I've owned use straight engine oil. I'm pretty sure my
    RD350 power-valve did, for example.
    You aren't, as it were.....
    The Older Gentleman, Dec 23, 2003
  6. Oldbloke
    Timbo Guest
    Bet you can't beat the £2.99 set of spanners I picked up at our local
    one: should have retailed at £69.99!
    Timbo, Dec 23, 2003
  7. Oldbloke
    .... and my Yamaha DT 100
    sweller, Dec 23, 2003
  8. Oldbloke
    mups Guest
    In Lozzo's absence, all the 2 strokes I've owned have used normal 10-40W
    bike oil in the gearbox. The only other stuff I've used was on my tuned
    RD500, which had motor crosser gearbox oil in as recommended by Stan
    Stephens.
    mups, Dec 23, 2003
  9. Mmmmm. Why does mine usually go more like "socket to bolt, doesn't want
    to turn, turn you dolt, turn!, slip, hit knuckle open, round of bolt,
    curse, repeat"?
    SOBs, mmmmm.
    Merijn Broeren, Dec 23, 2003
  10. Oldbloke
    Because, Brother Merijn, you do not follow the SnapOn path. The one
    true way of shiny chromey spanners and sockets, each finely finished
    and attuned to the Flank Drive way.
    Hie thee at once, at speed, brooking no distraction or interruption,
    to a Man In A Van bearing the Holy SnapOn logo and there offer up your
    skin, your back teeth and you firstborn child and you will be rewarded
    with a set of tools fit for use by Gods and Greasemonkeys.
    ShiteOldSpanners, more likely.
    Pip, Dec 23, 2003
  11. Oldbloke
    mups Guest
    Skin, back teeth and firstborn, that's not going to get you more than a
    10mm combi from Snap-On. I hear they're doing a good deal on a 1/2" socket
    set for only one limb and a grandparent though.
    mups, Dec 23, 2003
  12. mups wrote
    Bugger, I have run out of grandparents. Do you think they would settle
    for a Great Aunt?
    steve auvache, Dec 23, 2003
  13. Oldbloke
    mb Guest
    Because you forgot the beer?
    mb, Dec 23, 2003
  14. ShiteOldMZs use EP80/90 gear oil, IIRC.
  15. Oldbloke
    mups Guest
    I can quite happly say I've never had the pleasure of changing the oil on
    an MZ.
    Apparently Royal Enfields gearbox's are filled with grease...
    mups, Dec 23, 2003
  16. Oldbloke
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, mups
    This is quite true.
    But not for long, generally.
    Nigel Eaton, Dec 23, 2003
  17. Oldbloke
    Oldbloke Guest
    Bad form and all that TOG, but could you possibly confirm where one could
    procure some K&N Filter Foam. ISTR you swear by it as an alternative to
    carpet underlay, but I CBA to Google for it (2nd glass of Tempranillo
    cutting in now). Also, any idea where I can get a copper washer for the
    sump plug from (sorry about this, but my previous experience of shite old
    mechanical devices is limited to cars, and that was about 20 years ago).
    TIA
    Oldbloke
    BOTAFOT #140
  18. I just bought mine from my local dealer (Sunami of Morden), who keep it
    in stock. About a tenner for a big sheet - that was enough to do the
    GT380, the Benly and the Monkey Bike.
    If you can't locate any, I s'pose I can always buy a sheet for you and
    lob it in the post.
  19. Oldbloke
    mups Guest
    Try http://www.bitzforbikes.co.uk/products.php for the filter foam but
    phone them rather than order on-line. They have loads of stuff
    listed for the TS50. I've used them for bits for the RS200 and they seem OK
    mups, Dec 23, 2003
  20. Oldbloke
    Oldbloke Guest
    message
    Heh, cheers for the offer, I may well come back to you on that one.
    Any ideas on the copper washer?, the boy has presented me with a fibre tap
    washer procured from the local hardware store which is deeply disturbing.
    Oldbloke
    BOTAFOT #140
