FFS - battery access/replacement
Discussion in 'UK Motorcycles' started by darsy, Oct 27, 2010.
  1. darsy
    on a twatting Kawasaki ZX-12R.
    What a fucking spunk-dripping **** of a job! The fucking petrol tank
    has to fucking come off!
    What arsenugget designed that?
    Also, as an aside, often said, but bears repeating: **** Datatool.
    **** them right in their battery-draining little fucking eyes.
    (sorry about the Nige-o-meter value of this post, but discovering what
    needs doing has pissed me off).
    darsy, Oct 27, 2010
  2. darsy
    Malc Guest
    According to the Haynes BoL for the ZZR600 the whole fairing has to
    come off to change the headlight bulb!
    "First remove upper fairing (section 8.15)."
    Section 8.15 "To remove upper fairing first remove lower fairing"
    I think it's possible to worm a hand in there but you have to change
    it blind if you do.
    Malc, Oct 27, 2010
  3. darsy
    Simon T Guest
    Heh, I thought that was a nige post!!!
    Simon T, Oct 27, 2010
  4. darsy
    What? You're saying that an electrical item left running on a bike will
    eventually drain the battery? Who'd have thought it!
    I presume you're going to be sensible & fit an Optimate or CTek fly
    lead while you're there..?
    Krusty, Oct 27, 2010
  5. darsy
    Which is, what, a three minute job? Five at a push?
    ogden, Oct 27, 2010
  6. darsy
    there is one.
    But the previous owner (fx:cough: Zymurgy) had seen fit to leave on a
    US-style connector that didn't mate with the Optimate I actually
    owned...and...err I was lazy and forgot to buy one for ages, and when
    I eventually did, the battery was already deaded.
    darsy, Oct 27, 2010
  7. darsy
    yes, if you know what you're doing.
    darsy, Oct 27, 2010
  8. darsy
    Nige Guest
    The 1100 is a right **** of a job, too. Can be done without, but it's easy
    to drop the lamp into the headlight unit causing swearing at a volume that
    can be heard in space.
    Nige, Oct 27, 2010
  9. darsy
    Nige Guest
    My work here is done......
    Nige, Oct 27, 2010
  10. darsy
    I'm a cack-handed mechanical numpty and even I can get a tank off in a
    jiffy.
    ogden, Oct 27, 2010
  11. darsy
    SIRPip Guest
    No it fucking isn't. You can come back here and snip that sig you left
    in for a start.
    SIRPip, Oct 27, 2010
  12. darsy
    Nige Guest
    How odd, must be Darsy's mong sig at work....
    Nige, Oct 27, 2010
  13. darsy
    darsy, Oct 27, 2010
  14. darsy
    nope - been posting via Agent for a while now; no google-groups
    excuses.
    darsy, Oct 27, 2010
  15. darsy
    Nige Guest
    Worth a go, though :)
    Nige, Oct 27, 2010
  16. darsy
    Lady Nina Guest
    I'm me, the person who neglects bikes and smiles sweetly to get
    someone else to do the maintenance if I can possibly get away with it
    and even I can get a tank off in a jiffy.
    Lady Nina, Oct 27, 2010
  17. darsy escribió:
    I read the instructions in the Haynes manual for mine, and it was indeed off
    in a jiffy. Only possibly dodgy bit being the seven thousand rubber hoses to
    remember where to put back.
    Actually, seven thousand is an exaggeration - there were 4, but there were
    also various tubes that just went nowhere, so I assume the last person to
    remove and replace the tank, didn't bother with all of them.
    Paul Carmichael, Oct 27, 2010
  18. darsy
    TMack Guest
    ITYM "some" tanks. Try it with a V-strom for the first time to push the
    limits of a "jiffy" (7 "push centre" plastic tabs, 8 allen bolts and 4
    cross headed phillips-type bolts to remove, combined with some careful
    manipulating of fairing panels. All this just to expose the tank for
    removal).
    Then try it with my LS650 and you might experience what could be the longest
    jiffy of your lifetime. The clearance is so tight that only about 50% of
    LS650 tanks are removable without draining first and then removing the fuel
    tap. Mine is one of the removable ones but it can only be done by getting
    it into exactly the right position - and I mean EXACTLY. If it's 0.1 mm out
    of position (horizontally, vertically or laterally) then it can't be done.
    However, getting it off is the easy part. Getting it back on can be a REAL
    challenge.
    TMack, Oct 27, 2010
  19. darsy
    zymurgy Guest
    Heh. I refer to my post of January of this year
    http://groups.google.co.uk/group/uk.rec.motorcycles/msg/44085fb31a7661ca
    It's a twat of a job, but since that (new) AGM battery lasted a year
    on constant drain that's not bad.
    Best to keep it topped up periodically though ;)
    That was a Halfords charger tail BTW (which i've posted up before),
    but that's not a lot of use to you now, sorry :/
    Paul.
    zymurgy, Oct 27, 2010
  20. darsy
    don't worry - I have one now.
    **** all use at the moment, as the battery really is dead.
    On another note: I still have the spare key for that Tiger - do you
    want it?
    darsy, Oct 28, 2010
