Firestorm
Discussion in 'UK Motorcycles' started by Baloney, Sep 30, 2006.
  1. Baloney
    Baloney Guest
    Right - how would a fuckwit like me check this out? I'll bung some new
    Had a TDM850 before the VTR - loved it but bouncy suspension and lack of
    self control meant I kept chukking it up the road. The last high-side
    finished it off :( With the noisy Pro-stock zorsts it was really punchy and
    responsive.
    Before that was a GSXR600 - I REALLY did love this. Nothing I threw at it
    could upset it. No matter wot speed or wot mess I got myself into - it was
    unflappable. Admit I did love the screaming engine too.
    Was a while after TDM that the VTR came up (took a while for shoulder to
    heal etc...) quite cheap from a colleague at work. Its a stunner, dry
    miles, fsh, 7k miles, SP1 paintjob.
    I figured I loved the low punch of the TDM, wanted a bit more top end and
    better handling. I knew Gixxer top end and handling weren't on the cards,
    but thought handling should be acceptable (it might be when I get new
    tyres!) and a nice punchy 100bhp was a sure thing to make me smile!
    I do love the bike, but giving it beans is a rather tortuous affair - not at
    all satisfying :(
    Will try the plugs - it'll be interesting to see if they're the same colour
    too.
    Cheers
    Baloney, Oct 1, 2006
  2. Baloney
    Kim Bolton Guest
    Thanks. I'm sorry to hear about your bike; but I don't know the model
    and so can't suggest anything specific; others have mentioned looking
    at the plugs after a run - always a good indicator of health; change
    them for some new ones. If they show up OK, then it's down to chasing
    detail. I'm sure you'll get there. My feeling is a reduced airflow
    (clogged air cleaner, old rag, mouse nest) in the air passages, or
    ;possibly float or petrol feed problems, but YMMV. I once took some
    time to diagnose a problem on my single-cylinder bike; it ran OK at
    high speed, but had the blind staggers at less than half throttle.
    Eventually I traced it to the loss of the locating pin for the
    throttle slide, which was free to rotate in the carburettor body.....
    About the story above, a slight clue that all was not well was the
    bomb-aimer's report of yellow TIs. It suggests the crew mentioned were
    slightly early, or the target-marking slightly late. Bomber Command
    raids ran to tight timing by the standards of the day; yellow TIs were
    only used by Pathfinders for other Pathfinders to use; the TIs for the
    Main Force were green or red. Usually both were dropped, and the
    Master Bomber assessed their accuracy and directed Main Force
    accordingly - "Bomb on the green markers to the south" etc.
    The first Pathfinders over the target were the Primary Blind Markers.
    Using every navigational aid (dead reckoning, GEE, H2S radar) they
    would drop their yellow TIs where they thought the target was. The
    Illuminators then dropped hundred of flares to light up the target,
    and the Primary Visual Markers would then be able to see their
    specific aiming point, and drop green and red TIs accordingly. Main
    Force would then move in. This whole episode might take four minutes,
    with the Main Force attack lasting forty minutes (later it reduced to
    twenty).
    For our crew to see only yellow TIs meant that they had arrived at
    only the first stage of target marking; they should have seen a lit-up
    city showing yellow, red, and green TIs. I haven't read any reports
    that this particular raid ran late; so our crew must have been
    slightly early; perhaps turning a couple of miles short of the actual
    point over the Baltic. We'll never know, but it's interesting to make
    the deductions.
    Kim Bolton, Oct 2, 2006
