First bin - ever
Discussion in 'UK Motorcycles' started by GungaDan, Jul 3, 2006.
  1. GungaDan
    GungaDan Guest
  2. GungaDan
    GungaDan Guest
    Ta for that. I imagine ebay will be the way to go. I just need someone
    to wipeout the RHS of a red and black one.
  3. GungaDan
    GungaDan Guest
    Ta. Fingers crossed it's got one of those.
  4. GungaDan
    GungaDan Guest
  5. GungaDan
    BGN Guest
    No gore really, just a healing flap of skin and no blood.
    Firstly: Did you go to A&E? I would have suggested you got it cleaned
    out before it healed. You probably can't get a stitch in it but it
    should have been covered up.
    Secondly: Did you notice that you used the generator housing as an
    expensive crash bung?
    BGN, Jul 3, 2006
  6. GungaDan
    GungaDan Guest
    It might have been a good idea but I did pull back flap of skin and
    rinse thoroughly so hopefully it'll be OK. I'm more worried about the
    broken rib that's likely to puncture a lung while I sleep tonight.
    Cause of death: drowning in own blood. Cracking.
    The generator housing was only the secondary crash bung. It's probably
    that which saved my rear NS indicator from any damage - so that kind of
    worked out. The primary crash bung (not shown) did it's job of smashing
    the fairing and then breaking off leaving the end of its M6 (ffs) screw
    embedded in the tapped hole.
  7. Looks like you might be lucky and got away without crankshaft end
    damage. You might need a new alternator as well as the casing, but
    compared to an engine rebuild, that's cheap.
    Iiwy, I'd look at finding some protection bars for the casing ends.
    Grimly Curmudgeon, Jul 4, 2006
  8. GungaDan
    BGN Guest
    Until the flap of skin dies and then goes mouldy while attached and
    takes the rest of your arm with it. Keep a very close eye on it and
    if anything odd even appears to happen (evben if 1mm of it goes an odd
    colour) you
    Can I have your Hayabusa if you die within the next week from a
    punctured lung?
    Thank goodness the NS rear indicator wasn't damaged - they're far more
    expensive than a new engine. :)
    BGN, Jul 4, 2006
  9. The Older Gentleman, Jul 4, 2006
  10. GungaDan
    Crash bars? On a 'Busa? Yer 'avin' a giraffe, aintcha.
    There are some pretty funky and subtle-but-effective casing protectors
    about, that come in the form of moulded carbon/kevlar covers, to be
    attached with Sikoflex to the casings. They're not cheap (when bought
    new) but reviews by racers that I've read reckon they do save casings
    - and they're cheaper than new casings and a lot cheaper than fucked
    engines or generators.
    Pip, Jul 4, 2006
  11. GungaDan
    On Mon, 03 Jul 2006 11:28:12 +0100, Kevin Weller
    If you're referring to the AV45/46, this is true - but only to a
    limited extent. When new and at walking pace, or pulling away very
    cautiously, sometimes you will feel the rear oscillate gently,
    probably as the deeply diagonally-cut tread alternates its angles.
    Once on the road so to speak, you should never feel this. I quite
    like it, myself ;-)
    Pip, Jul 4, 2006
  12. GungaDan
    GungaDan Guest
    It's not even as bad as it looks in the photo
    I'll keep an eye on it. Cheers.
    GungaDan, Jul 4, 2006
  13. GungaDan
    GungaDan Guest
    Hmmm, after yours and Bear's comments I might just remove the skin
    myself.
    Sure, why not. If I time it right, it might be back on the road by the
    time you get it (I'm aiming for this weekend). You'll have to put up
    with the scraped fairing though. Bad news is I'm feeling better this
    morning so you might be out of luck...
    I was certainly relieved. :eek:/
  14. That's what I meant. 'Crash bard' was more a generic term for some sort
    of protection.
  15. GungaDan
    Big Dave Guest
    Huh?
    Shakespeare?
    "We few, We happy few, We band of crazy bastards...."
    "Once more onto the grid dear friends, once more....."
    "Ambulance, Ambulance, Wherfore art thou Ambulance?"
    (sorry)
    Big Dave, Jul 4, 2006
  16. GungaDan
    Dan L Guest
    GungaDan wrote:
    *M6*
    FFS Indeed.
    Dan L (Oldbloke)
    Space in shed where NSR125 used to be
    BOTAFOT #140 (KotL 2005/6), X-FOT#000, DIAABTCOD #26, BOMB#18 (slow), OMF#11
    Dan L, Jul 7, 2006
  17. GungaDan
    Not on here there isn't.
    I'll email details of the anti Avon clique that exists but you'll have
    to slash your wrists with a broken engine casing once you've read it.
    Andy Bonwick, Jul 7, 2006
  18. GungaDan
    Suspension?
  19. GungaDan
    They're not even up to serious abuse on a Bandit so there's no way
    they're up to it on a Busa. They're absolute fucking crap if you start
    to push the bike a bit hard and I wouldn't put them on any bike
    belonging to me.
    That should get the usual response...
  20. GungaDan
    GungaDan Guest
    Before the Avon's I had Dunlop D207s which aren't supposed to be the
    best tyre in the world either. So I dunno.
    I could use broken engine casing or a jaggedy piece of fairing.
    The worst thing about the incident is not really understanding what
    happened. I reckon I was virtually upright when I gassed it so I'm
    surprised it didn't just sort itself out. One theory I have is that I
    might have (unintentionally) opened the throttle more as the bars
    flapped. It was pretty violent and I was very much the passenger. Well,
    for a bit.
    GungaDan, Jul 8, 2006
