Flash drive recovery software
Discussion in 'UK Motorcycles' started by Catman, Apr 13, 2010.
  1. Catman
    Catman Guest
    Knowing all the photography types round here, does anyone have any
    software they can recommend for flash drive recovery?
    It's not for me. I'm not quite that daft.
    TIA
    www.cuore-sportivo.co.uk
  2. Catman
    Brownz Guest
    I've used photo rescue pro with satisfying results in the past -
    serial numbers are easily found on t' web.
    Brownz, Apr 13, 2010
  3. Catman
    Catman Guest
    Triff, ta. He can damned well pay if it works.
  4. Catman
    Catman Guest
    Probably the same stuff, IWHT. I'm not actually faced with an SD card
    with photos, but the blurb on the stuff Brownz kindly pointed to
    indicates, as I would expect, it'll handle any data on any medium.
    YMMV obviously.
  5. Catman
    Catman Guest
    Nasty
  6. Catman
    Brownz Guest
    Do you have a windows system that you can check to see if the SD Card
    appears under Disk Management ?
