Flat and Run Down
Discussion in 'Classic Motorcycles' started by Ross, Mar 17, 2005.
  1. Ross
    Ross Guest
    It's that time of the year where I'm thinking of dragging the bikes out of
    hibernation in the garage, but all the batteries will be flat again. It must
    be time to invest in one of those battery charging/monitoring devices, you
    know, the optimate(?) type thing.
    Any recommendations on what type to go for and where to buy at a good price?
    All the bikes are 12v, and the ability to recover fully discharged batteries
    would be handy as I'll probably still neglect the poor things!
    Any suggestions appreciated.
    Regards
    Ross
    Ross, Mar 17, 2005
  2. Ross
    'Hog Guest
    Stick to the new model Optimate
    'Hog
    'Hog, Mar 17, 2005
  3. Ross
    Always puzzled me, this. Both the gixxer and the preceeding trumpet
    tended to be left in the garage for months without use during the
    winter, but neither of them would ever go flat (well, the trumpet did
    when it said outside veggie's for ~6 months, but I think it was on its
    way out by then).
    To be fair, I did take the gixxer out for a run in February, only
    about 3 months after its previous use, but it had no sign of an even
    slightly discharged battery at this point.
    As recommended by the world and his dog, I know. All I can say is that
    I've never needed one. Only after doing something stupid like leaving
    the lights on[1] have I ever needed to charge a battery, and for that
    a normal 1A trickle charger is perfectly adequate.
    [1] Or having a completely duff battery, like the 400/4 I had for
    about three years, although that had a perfectly good kickstart so was
    never an issue.
    Ace, Mar 17, 2005
  4. Ross
    'Hog Guest
    Alarm? Datatool on the Duke was a killer on the battery. Solalarm on
    the K1100 was a breeze.
    'Hog
    'Hog, Mar 17, 2005
  5. Adrienne M Bonwick, Mar 17, 2005
  6. Ross
    I only suffer with vehicles that have alarms. Neither the car nor the
    TL will start after two weeks or even less, of neglect. The Guzzi
    doesn't have an alarm and never gives any problems, well, not on the
    battery front. Both the car's and the TL's batteries, according to my
    Accumate, charge fully otherwise.
    Pip Luscher, Mar 17, 2005
  7. Ross
    It's the poxy bloody alarms. The gixxer was flat when I fished it out
    last weekend. Fortunately, I've (several) spare batteries.
    Champ, Mar 18, 2005
  8. Ross
    Mark Guest
    Generally agree, but my Meta 357T goes into "immobilise only" after
    ~10 days with zero current drain. Seems to work too, didn't start it
    for two months, and fired up OK. I'd rather have no alarm and a
    battery, than an alam for >10 days and a shagged battery.
    I do have a Optimate though - got when I had a VFR with a completely
    shagged battery & elec system! "Does what it says on the tin".
    Mark, Mar 18, 2005
  9. Ross
    My bike only has an immobiliser, and still it eats the battery :)
    I've got alternative product to the Optimate, but I can't remember
    what it's called. Works bloody well, tho - manages to keep the
    batteries for the race bike in good nick.
    Champ, Mar 18, 2005
  10. Ross
    Oximiser? The Oxford alternative, perhaps.
    I have the latest iteration: the Maximiser, which works well, too.
    Pip, Mar 18, 2005
  11. Ross
    Champ, Mar 18, 2005
  12. Ross
    Ross Guest
    Thanks for the suggestions, folks, looks like the Optimate is the way to go.
    Regards
    Ross
    Ross, Mar 21, 2005
  13. well, amazingly, the battery on the SOBoxer was still almost up to starting
    it on the electric boot. a touch of help from the battery charger and she
    fired up. I'd forgotten how loud it is, especially inside its shed, with
    the exhausts echoing back off the walls, lovely :)
    all I need now are a new tyre, an MOT and road tax... summat close to 150
    quid, buggrit, so it'll not happen this month.
    Austin Shackles, Mar 21, 2005
  14. Ross
    kenney Guest
    Why not just remove the battery and drain the oil and petrol when you
    lay the thing up?
    Ken Young
    Maternity is a matter of fact
    Paternity is a matter of opinion
    kenney, Mar 22, 2005
  15. you might want to leave the alarm on?
    wouldn't hurt on mine, no alarm on it. Nor had the petrol noticeably gone
    off, either - or not to the extent that it wouldn't go.
    Personally, I wouldn't drain the oil, though, 'cept perhaps if I knew I was
    laying something up for several years.
    Austin Shackles, Mar 22, 2005
  16. Austin Shackles wrote
    Draining petrol is a sin. It should be combusted.
    steve auvache, Mar 22, 2005
  17. Ross
    Ross Guest
    You're right, that would be the thing to do, but that would be far too
    sensible for me! ;-) Also there's just a chance that the weather would be
    good enough combined with me having the time, to drag the bike out for a run
    during the winter....it doesn't usually happen but you never know!
    Regards
    Ross
    Ross, Mar 24, 2005
