Flipper-helmets? think again...
Discussion in 'Australian Motorcycles' started by JustAL, May 21, 2004.
  1. JustAL
    JustAL Guest
    I'm thinking SportsIntregral Helmet for a replacement.
  2. JustAL
    glitch1 Guest
    Happened last Sat, chinbar ripped out of the pivots on impact, buckled the
    visor which snapped into small pieces (shear-stress).
    Resulting injuries:
    Broken nose, cuts around nose, chin, cheeks requiring stitches inside the
    mouth as well.
    Injuries resulting out of the failed chinbar are further cuts/ damage to
    internal tissue of mouth, broken teeth all around the front.
    http://www.members.optusnet.com.au/glitch1/HJC/
    Looks like at least this HJC shouldn't have gotten "the faibled AS sticker"
    then.
    First time I saw those hinge-mechanisms close up, what a shocker, kids toys
    are made better.
    Any thoughts I'd ever had in the past regarding buying one of those have
    somehow....gone the same way as that helmet.
    cheers
    pete
    glitch1, May 21, 2004
  3. JustAL
    JustAL Guest
    You're right Zebee. Nothing is tested in that area.
    Dubious regardless of what you put on but the chances are higher of
    surviving due to construction.
  4. JustAL
    Mad Biker Guest
    my girlfriend has a zeus one for 300 bucks..
    I attempted to take the visor off to adjust it so it closes properly, the
    visor pins also hold the chin bar on, the visor can not be adjusted and thus
    will always have a bit of a leak in it, and i suspect it will snap the chin
    bar off fairly easily...
    although i found out it makes a stylish open face helmet..
    Dam cheepi
    Nat
    www.mad-biker.com
    Behold the 17th wonder of the world that didn't make it
    http://members.dodo.net.au/radburn/cattower.jpg
    Mad Biker, May 21, 2004
  5. In aus.motorcycles on Fri, 21 May 2004 21:15:08 +1000
    Got bad news for you...
    The ABS standard doesn't test chinpieces at all. Only skull protection.
    I don't think any standard, including Snell does.
    So don't put on that fullface thinking that the certification means you
    are safe....
    Zebee
    Zebee Johnstone, May 21, 2004
  6. JustAL
    Cam Guest
    Cam, May 21, 2004
  7. JustAL
    TB Guest
    The first time I came off the Gixxer the chin bar on my old helmet copped a
    nice wack when I hit the pedestrian island head first. Had some deep
    scratching on the Left Cheek/visor it but it stayed in one piece.
    Regardless of them being tested to standards or not, I think the fact that
    the full faces are usually constructed in a single shell, or many layers
    shell, the load of impact is distributed over a larger area, as opposed to
    teh pivots that hold the flip up part.
    TB
    '03 CBR600F4i
    '99 GSXR600
    '88 CBR250R
    TB, May 21, 2004
  8. JustAL
    Greg Byrnes Guest
    Not good to see but injuries compared to wearing Open Face?
    Flip style is always a half way house between open face and full face.
    Greg
    Greg Byrnes, May 21, 2004
  9. JustAL
    Damien Guest
    Some say that full-face helmets can be even worse in their own way. Can't remember the precise processes
    involved, but with a full-face helmet when you have an impact on the chin-piece, it transfers the forces
    through to the back of the skull and causes major neck/brain problems, and is thought to be a major factor in
    fatal accidents. So a chin-piece that shatters like that may actually be the best sort, in a similar way to
    crumple zones in cars, by disipating some of the force of impact by self-destructing like that. It may result
    in other injuries (as you described) but could also result in a decreased chance of something more serious. Of
    course, this is just a half-baked theory based on half-remembered articles from some bike magazine I can't
    remember, but there might still be something to it. Either way, cuts, bruises and broken teeth are still
    better than being dead!
    Damien
    GPX250 (stolen) -> CBR600
    Damien, May 21, 2004
  10. JustAL
    R1100Smee Guest
    Damien wrote:
    Sounds good in theory but if that were the case why do motogp and all
    other racing class riders wear full face helmets?
    i might just as well bend over now while the rich, dole bludgers and single
    mothers take
    turns fist fucking me up the arse!
    Corks on a rant
    R1100Smee, May 21, 2004
  11. JustAL
    Biggus Guest
    I think you would risk it with a fullface over open face at 300kph.
    I agree, the theory sounds ok, but dont believe it. Having hit the
    ground at over 200 at oran, and walked away with a majorly fucked
    helmet more than once.
    Biggus, May 21, 2004
  12. JustAL
    Nev.. Guest
    Because it is stipulated in the FIM Technical Regulations...
    "Helmets must be of the full face type and conform to one of the recognised
    international standards: Europe: ECE 22-04 & ECE 22-05 'p' - Great Britain:
    BS 6658 Grade A - USA: DOT Federal Standard n' 218/SNELL M95 & M2000"
    On a race track a rider is unlikely to suffer the sorts of accidents which
    might cause such injuries (i.e. hitting a solid object with helmet chinpiece).
    Nev..
    '03 ZX12R
    Nev.., May 21, 2004
  13. In aus.motorcycles on Sat, 22 May 2004 00:13:53 +1000
    Some years ago, there were some unexplained deaths in South Oz, and the
    design of the helmet was found to be responsible.
    If the chinbar hit the road at a certain angle, the chinstrap could
    transmit force to the jaw thence to the spinal cord.
    I believe that some helmets have the chinstrap angled differently to
    deal with this.
    Plus, it's still a fairly small number of crashes, you hve to hit at the
    right angle.
    RIding motorcycles is dangerous, you use the kit you personally feel
    safe with. The more you focus on the horrible things that *might*
    happen, the less fun you'll have.
    Conversely, the more you are sure the kit you wear will protect you from
    the consequences of your actions, the more stupid you'll be...
    Zebee
  14. JustAL
    R1100Smee Guest
    The ground is not a solid object???????????
    mothers take
    Corks on a rant
    R1100Smee, May 22, 2004
  15. Bloody uncomfortable---wore mine to Taylors Arm and back last weekend.
    Couldn't wear sunnies under it--they dug into the sides of my head and gave
    me a ripper headache.
    I also managed to kick it over last night and gouge the visor--have been
    told by BMW dealer that neither clear or tinted visors are currently
    available for the Sportsintegral.
    I've found it to be incredibly noisy at speed with the chin vent or visor
    cracked open (even with earplugs),and peripheral vision is almost
    nonexistant--very poor compared to my old Shoei X9 or Arais.
    Other than that,it's been fine... :)
    Looking for another new helmet Pat
    Pat Heslewood, May 22, 2004
  16. Quick--someone post a link to Rotten.com...
    Detonator Pat
  17. JustAL
    Nev.. Guest
    Given that most of us have actually met the ground in circumstances which we'd
    have preferred not to while wearing a full face helmet, or know other people
    who have, and in almost every instance we, and these people who we know who
    wear full face helmets, have not sustained fatal injuries which have been
    caused by the wearing of a full face helmet, then it can be taken as a given
    that hitting the ground in a full face helmet does not usually constitute the
    type of accident in which the circumstances might lead to fatal injuries being
    inflicted by a full face helmet, so I must therefore have been talking about
    some other solid objects.
    Nev..
    '03 ZX12R
    Nev.., May 22, 2004
  18. my BMW one hit the ground at a great rate, the visor ripped off in one piece
    and i got a face full of dirt but there was no sign of the chinbar breaking
    <<< this is a VERY GOOD THING
    there was quite a bit of scratching on the front of the helmet and chinbar,
    similar to 'ol mateys in the pic
    I would own another BMW one...and i was considering a HJC one...but maybe
    not!!
    fulliautomatix, May 22, 2004
  19. JustAL
    Stoneshop Guest
    Why would an aquatic actor in a '60's television series need a brain bucket?
    Dolphins have sonar and are smart, two factors that combine into them rarely if
    ever bumping into solid things.
    // Rik Steenwinkel '85 R80ST Skippy bike
    // Enschede '91 R100GS/PD The Great Unwashed
    // Netherlands '90 K75C Kommutabike
    // "Far away is only far away '81 MZ TS250/1+LSW Badkuip
    // if you don't go there" '79 Honda XL250S TBD
    // N 52.2158 E 6.88589
    Stoneshop, May 22, 2004
  20. JustAL
    Toosmoky Guest
    Got no argument on that but I'm sure there was some kerfuffle when BMW
    wanted to import their version in the first place...'bout '83 I think.
    *warning: user memory has bad sectors*
    Toosmoky, May 22, 2004
