Seems like I've done everything I can think of to clear up the low-speed rich condition on my CV carb for cylinder #1. Disassembled, cleaned, new o-rings, new idle mixture screw, checked fuel height in the bowl via clear tube, etc. The only thing I can think of is that although the fuel level check shows it to be about right, the float is still allowing too much fuel into the bowl. The float tab is at its limit - I can't adjust it anymore without it losing contact with the shut-off needle while the float is in the fully closed question. My question is: Do these floats "grow" in density (i.e. get heavier) with age and crud absorption into the float material? I believe they're the original (and are not brass), but the experiment to replace with new is not cheap. Per plug read the rich condition is pretty even across all 4 carbs, but #1 is the most sensitive, often fouling at start-up. Thanks, JpnseFours
