Fly screen
Discussion in 'UK Motorcycles' started by Nicknoxx, Mar 20, 2006.
  1. Nicknoxx
    Nicknoxx Guest
    This weekend, I decided to investigate the creaking noise coming from
    the front of the bike and it turned out that the small aftermarket
    screen was rubbing against the instruments. Also the bolts which were
    holding the screen to the headlight were too short and the nuts had come
    off inside the headlight.
    As the screen also had a small crack, I decided to remove it and refit
    the headlight properly as I REALLY didn't want it to fall out while I
    was moving.
    Problem is that now, at speeds above the national limit, it's a bit
    windy so I'd like to fit a screen which actually fits.
    Suggestions please [1] for a replacement screen
    [1] The following can be considered superfluous:-
    Angle Grinder
    Go slower
    Gixer Thou
  2. In uk.rec.motorcycles, Nicknoxx belched forth and ejected the following:
    Shit in the carbs :eek:)
    Whinging Courier, Mar 20, 2006
  3. Nicknoxx
    Vass Guest
    beat me to it!
    Vass, Mar 20, 2006
  4. Nicknoxx
    Nicknoxx Guest
    Heh
  5. Nicknoxx
    Nicknoxx Guest
  6. Nicknoxx
    Dan L Guest
    I have an "Impala" screen from M&P on my Zephyr, previously I had it on my
    CB500.
    It does a reasonable job of deflecting the windblast and was quite cheap too
    (about £40 IIRC).
    Dan L (Oldbloke)
    Space in shed where NSR125 used to be
    BOTAFOT #140 (KotL 2005/6), X-FOT#000, DIAABTCOD #26, BOMB#18 (slow), OMF#11
    Dan L, Mar 20, 2006
  7. Nicknoxx
    Renapur
    platypus, Mar 20, 2006
  8. In uk.rec.motorcycles, platypus belched forth and ejected the following:
    Carole Nash
    Whinging Courier, Mar 21, 2006
  9. Nicknoxx
    42%. Just think about it.
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, Mar 21, 2006
  10. Nicknoxx
    Ace said...
    CG125[1]
    [1]MSOHP
    Lozzo, Mar 21, 2006
