Flying with helmet
Discussion in 'UK Motorcycles' started by TD, Jan 27, 2010.
  1. TD
    TD Guest
    If it's in its original box, is it alright to check it in or do I want to keep
    it as hand luggage?
    TD, Jan 27, 2010
  2. Champ, or someone, will tell you that the original box was suitable for
    shipping the helmet originally, so will be fine on a plane.
    Personally, I carry mine hand luggage in a helmet case.
    doetnietcomputeren, Jan 27, 2010
  3. TD
    TOG@Toil Guest
    Hand luggage. If they object, wear it.
    TOG@Toil, Jan 27, 2010
  4. TD
    Switters Guest
    It's a Weapon of Mass Dentation innit?
    Switters, Jan 27, 2010
  5. TD
    Malc Guest
    Big Teeth?
    Malc, Jan 27, 2010
  6. TD
    YTC#1 Guest
    Stuff that, stick in the crate with the motorbike ! :)
    YTC#1, Jan 27, 2010
  7. TD
    Switters Guest
    Cavity search?
  8. TD
    It was me.
    So do I. Whenever I've had cause to fly anywhere there's a bike to be
    ridden on the other end of the journey, I've worn the bike kit on the
    plane to save luggage space in the throwovers I've checked in and
    carried my lid onto the plane as hand luggage in a proper padded Arai
    race bag.
    Lozzo, Jan 27, 2010
  9. TD
    I've done it three times since they introduced all the new security
    measures. Once from Stansted to Newcastle to collect the Thunderace
    from Colin, then to Nice where I borrowed Jas's ER-5 for the week, and
    then to Belfast where I collected the Gixer from Hog.
    The fact I was in bike kit didn't matter a bit, I got through the
    security checks as quick as anyone else.
    Lozzo, Jan 27, 2010
  10. TD
    For several years I've been riding to Leeds and Manc airports and walking
    straight to the flight with my full riding gear on. No problem. I've been
    asked to check my helmet in once when it was uncovered, I refused and stated
    it was an item of personal safety equipment and fragile. When in the rather
    lovely supplied carry bag, no problem.
    Hog, Jan 28, 2010
  11. TD
    TD Guest
    Problem is I already have a hand luggage bag, and the lid ain't fitting in
    there. And if I wear it, I'll probably fall foul of some new-fangled
    anti-terror legislation.
    TD, Jan 28, 2010
  12. TD
    TD Guest
    In addition to your "normal" hand luggage? I'm going with Easyjet and I have
    a feeling they'll try to shag me at every turn. I already have a normal hand
    luggage bag and a guitar[1], but I think trying to carry a lid on board as
    well is going to be seen as too much of a piss-take.
    [1] Which is shockingly allowed in hand luggage according to
    http://www.easyjet.com/en/planning/baggage.html
    TD, Jan 28, 2010
  13. Using the patented Mavis Beacon "Hunt&Peck" Technique, TD
    Easyjet may well be relaxed about it, but depending on which airport
    you're going from you may still have a problem.
    Last time I went through Luton they were enforcing a "one piece of hand
    baggage" rule at security very strictly.
    Wicked Uncle Nigel, Jan 28, 2010
  14. TD
    TD Guest
    FFS. FWIW, there was no problem at Heathrow last time I took a guitar in
    addition to the normal hand luggage.
    TD, Jan 28, 2010
  15. Using the patented Mavis Beacon "Hunt&Peck" Technique, TD
    Terrorist.
  16. Have they changed the rules then? When I was flying last year it was
    "One piece of hand baggage and one personal item".
    Which essentially meant my suitcase and my laptop bag. I was never refused.
    doetnietcomputeren, Jan 28, 2010
  17. Using the patented Mavis Beacon "Hunt&Peck" Technique,
    It varies from airport to airport in the UK.
    Basically, you have to guess.
  18. TD
    TD Guest
    I didn't take off my belt either!
    By the way, http://www.london-luton.co.uk/en/content/3/80/security.html
    suggests:
    "Each passenger is permitted to carry ONE item of cabin baggage through the
    airport security search point, the size of this item is restricted to a small
    trolley case.
    In addition to the one item permitted above, each passenger may carry a
    musical instrument in its case."
    I could put some strings on the lid I suppose, and pass it off as a neckless
    sitar.
    TD, Jan 28, 2010
  19. TD
    TD Guest
    See http://www.london-luton.co.uk/en/content/3/80/security.html
    "LAP TOP COMPUTERS COUNT AS ONE PIECE OF HAND BAGGAGE AND SHOULD BE REMOVED
    FROM CASE PRIOR TO SCREENING"
    Caps and grammar not altered to enable pedants to fill boots.
    TD, Jan 28, 2010
  20. TD
    Jim Guest
    Heh. I would love to see their faces if I tried that with my double bass.
    Jim, Jan 28, 2010
