FOAK: @ and "
Discussion in 'UK Motorcycles' started by Cane, Aug 22, 2007.
  1. Cane
    well, yes, that'd work, but I'd lose my AD authentifications and
    network drives....
    err...see above.
    darsy, Aug 22, 2007
  2. Cane
    well, yes, but he almost managed to make it look like he knew what he
    was talking about.
    darsy, Aug 22, 2007
  3. Cane
    Dave Emerson Guest
    Depends which domain you login with first. If it's with the cached version
    of your network domain profile then there shouldn't be a problem.
    The network drives don't appear in Explorer but any shortcut (file or
    folder) will reconnect and the AD credentials should be honoured.
    Only time this didn't work for me was when my local profile password had
    expired.
    It doesn't work if you just logon to the local machine domain.
    Dave Emerson, Aug 22, 2007
  4. Cane
    Cab Guest
    Zigzactly. Should be fine
    Cab :^) - I'm dyslex-spic apparently
    GSX 1400 - Speedy Zimmerframe.
    UKRMMA#10 (KOTL), IbW#015, BoB#4, POTM#3, SKA#1
    email addy : ukrm_dot_cab_at_rosbif_dot_org
    The gingeometer: http://www.rosbif.org/ukrm/gingeometer/
    Cab, Aug 22, 2007
  5. Cane
    Jeremy Guest
    Once again, sorry to disappoint.
    Jeremy, Aug 22, 2007
  6. Cane
    Ofnuts Guest
    It allows you to not use the shift key to type the most frequent
    accented letters. Choices had to be made...
    Ofnuts, Aug 22, 2007
  7. Cane
    Cane Guest
    On 22 Aug, 09:43, Wicked Uncle Nigel
    I've searched the control panel and found the mouse & keyboard bit but
    no where can I find a place to switch from US to UK settings.
    Cane, Aug 23, 2007
  8. Cane
    "Regional & Language Options"
    CT, Aug 23, 2007
  9. Using the patented Mavis Beacon "Hunt&Peck" Technique, Cane
    It'll be under "Regional and Language Settings" in the Control Panel.
    You need to select "English United Kingdom".
    Honda GL1000K2 (Fallen apart) Kawasaki ZN1300 Voyager "Oh, Oh, It's so big"
    Suzuki TS250 "The Africa Single" Honda ST1100 wiv trailer Norton 850 Commando
    Kawasaki GTR1400
    Wicked Uncle Nigel, Aug 23, 2007
  10. Cane
    Cane Guest
    D'oh!
    Cane, Aug 23, 2007
  11. Cane
    Cab Guest
    Hmm, there are 10 digits and four accented characters é,è,ç and à. The
    rest being symbols.
    Seems like a silly choice to me. Mind you, I suppose frequency of use
    of each of these characters has a lot to do with it. At the same time,
    when I want to use the ^ or ¨ over a character, I have to hit two keys
    anyway. e.g hôtel or Jamaïque (admittedly, there are fewer words with
    these sybmols).
    Cab, Aug 23, 2007
