FOAK: Backing up data.....
Discussion in 'UK Motorcycles' started by Donnie, Feb 19, 2011.
  1. Donnie
    Donnie Guest
    ........particularly photos.
    So, basically what does the font do?
    I was keeping them all on my laptop, silly I know but thought I needed
    a spring clean when I discovered there was less than 10GB space left on
    my 100GB disc.
    So, made use of an external HD (350GB) which has a seperate power
    supply. This however has been acting up a bit recently so now Im
    thinking I need something more stable.
    Ive thought of online but it takes so long to upload on our broadband
    line which is only a 2 or so meg :-/
    Ive noticed that sainsbury had an offer of 25 DVDR discs at about £8
    recently. Now I know that they're not rewritable, I know per mb they
    will be more expensive but has anyone got a solution that works well
    for them?
    Donnie
    "**** the world, it's time to fight back"
    Lambretta Series 2 186cc "The Shitter"
    Lambretta LD 175cc "The Chopper"
    Honda CB500R "Look out, Donnie's about!"
  2. Donnie
    Simon Wilson Guest
    Either another external hard drive, or some kind of online storage like
    dropbox. I'm sure someone will send you an invitation to build up their
    own free storage.
    Simon Wilson, Feb 19, 2011
  3. Donnie
    I dropped 17 quid on a Flickr account.
    ogden, Feb 19, 2011
  4. Donnie
    Ian Field Guest
    What works for me is having 2 PCs - one connected to broadband (for
    downloading stuff) and another which is sort of my personal library.
    The method I use to transfer files from one to the other is via DVD+RW
    disks - the disks are stored in a safe place as a backup in case the HDD
    packs up on the library PC.
    Obviously DVD+R disks are cheaper but its a lot of fucking about burning
    each disk in turn and then working out which files to delete on the source
    HDD. You soon end up losing files or backing them up twice (more likely a
    little of both).
    What I use is Nero7 (bundled with a drive from Maplin) and InCd which allows
    you to use a CD/DVD+RW just like it was a floppy.
    That way you can put all the files into a backup folder (complete tree if
    you like) and cut/paste from the source HDD to DVD, when the disk is full
    you get prompted to put another in - repeat until all the files are backed
    up.
    There are various warnings on the web about Nero8 and a special offer Nero9
    someone picked up for me has yet to arrive, so I havent been able to try it
    yet.
    There are sometimes compatibility issues with InCd and the one on the Nero7
    disk doesn't like this MOBO but the InCd-Free I downloaded (since taken
    down) works fine.
    Name a binaries group and I'll upload a Nero7 ISO and the InCD.
    Ian Field, Feb 19, 2011
  5. Donnie
    @news.eternal-september.org:
    even if you could upgrade to a faster download speed the upload speed might
    not increase. The trick is to do it frequently or set it to run overnight
    so the upload does not impact on other internet use. Using an online
    account like flickr, as ogden suggests, handles your indexing, storage and
    sharing in one product. You can even use it when travelling to transfer
    photos from a camera thus saving the need to issue a Lozzo Ultimatum or
    having to buy another memory card.
    wessie, Feb 19, 2011
  6. Donnie
    Donnie Guest
    hmmm had a look at dropbox but potentially 20 dollars a month for
    storage? It'd be cheaper to run with DVD RWs I think.
    Donnie
  7. Donnie
    Donnie Guest
    Never thought about that as I assumed there'd be a limit that wouldnt
    meet my needs but it appears to be unlimited, looks pretty good to me
    unless Im missing something obvious
    Donnie
  8. Donnie
    Donnie Guest
    I have no idea how to or desire to start with nero and InCD etc to be
    honest, I want a simple solution and cant be arsed to faff about
    learning new programmes to be honest. Im sure it's a solution but it's
    too much for me Im afraid.
    Donnie
  9. Donnie
    Donnie Guest
    Early days I know but looking like the Flickr upgrade may be the way to
    go except I've just thought and did a quick check and it appears that I
    can't upload RAW files to flickr. Hmmmm bugger
    Donnie
  10. Donnie
    Buy a usb external drive, Google robocopy.
    ogden, Feb 19, 2011
  11. Donnie
    Donnie Guest
    googled and **** that, again, command line stuff etc is beyond me :-/
    I cant get my head round why I simply wouldnt drag and drop to a usb
    external drive rather than use robocopy either.
    Donnie
  12. Donnie
    Ben Guest
    Ben, Feb 19, 2011
  13. Donnie
    drag & drop? How quaint. My Seagate external drive runs a utility that
    automagically transfers any new data from the desktop HDD to itself at a
    predetermined interval I selected.
  14. Donnie
    petrolcan Guest
    Stored on laptop, backed up to external HDD.
    Big external HDD.
    petrolcan, Feb 19, 2011
  15. Donnie
    petrolcan Guest
    Actually, don't you have paid for hosting? Just upgrade the storage on
    that.
  16. Donnie
    Catman Guest
    Terastation with a USB drive plugged in. The Terastation has a share
    called backups, that all the machines can access, but the mail server
    does an rsync of the home folders as well as the mail files.
    The Terastation then does its own backups to an external drive.
    When the external gets full I just bin a month of backups.
    I also have an *archive* of photos on the USB drive, so there are three
    copies of that.
    #www.cuore-sportivo.co.uk
    Catman, Feb 19, 2011
  17. Donnie
    Ian Field Guest
    It was as simple as drag & drop with the 320Gb Mobox USB external I bought
    from Lidl.
    There is the inconvenience that it needs the combined current supply of 2
    USB ports (and still struggles to spin up) and you can't run it via a
    powered USB expander hub.
  18. Donnie
    Donnie Guest
    Just checked out what i currently have and thats only 1.5GB :-/ to
    upgrade even to 5GB would be back to the cost of an online service with
    more space :-/
    Donnie
  19. Donnie
    Donnie Guest
    Hey, not my fault, thats all thats currently available here :-(
    I already have the 320GB one but as I say, seems to be acting
    intermittently recently
    Donnie
  20. Donnie
    whoever has been telling you *that* is big has been very kind, so to speak
