FOAK: broken studs
Discussion in 'UK Motorcycles' started by Timo Geusch, Aug 24, 2010.
  1. Timo Geusch
    I've seen exhaust studs shear square with the surrounding surface, but
    not really inside the hole - anybody seen this before?
    I'm trying to work out if my shed of a steed (DR650) has lost one of the
    studs or if if it is broken off deep into the hole. If its the latter,
    any idea how to get it out (steel stud in an alloy head) given that the
    usual tricks like welding a nut to it aren't going to work?
    I'm currently hoping that the stud simply vacated the hole and that
    they're not screwed in very deeply but this does feel odd...
    Oh well, time to order another stud and see how far it screws into the
    hole, methinks. That thing needs its own personal bottle of thread lock
    anyway, given the way it vibrates.
  2. Using the patented Mavis Beacon "Hunt&Peck" Technique, Timo Geusch
    LH drill bit.
    Wicked Uncle Nigel, Aug 24, 2010
  3. Timo Geusch
    .... in a bench drill, I assume? Bah. Head-off job but there are a bunch
    of machine shops around here. Oh well.
  4. Timo Geusch
    Simon Wilson Guest
    +1
    Worked a charm on the last one I did.
    Simon Wilson, Aug 24, 2010
  5. Timo Geusch
    Why? I mean, I've never done this, but I can't see why you couldn't
    just do it in situ.
    Ace, Aug 24, 2010
  6. Using the patented Mavis Beacon "Hunt&Peck" Technique, Ace
    Exactly that. Pick a drill that's undersized and go carefully. Have a
    look at the swarf that comes out. If it's steel, you've got the remains
    of the stud in there, continue. If it's ally, stop.
  7. Timo Geusch
    ian field Guest
    "easy-out"
    Its a tapered LH thread with a square end to fit a tap (as in tap & die)
    holder.
    You have to drill a pilot hole into the sheared stud then open it up with a
    bigger drill to fit the best size of easy-out.
    As you run the stud through it distorts slightly and helps break the
    "frozen" thread, but you only get one go at drilling the stud - off centre
    or break out sideaways and you're down the machine shop to have it drilled
    out and tapped for a brass insert.
    If the stud starts to turn when you drill it, you can probably get it with
    one of those JML screw extractors.
    ian field, Aug 24, 2010
  8. Timo Geusch
    TOG@Toil Guest
    It's nice to know that Timo's bikes don't change, though they may now
    be several thousand miles away ;-)
    TOG@Toil, Aug 24, 2010
  9. Using the patented Mavis Beacon "Hunt&Peck" Technique, ian field
    Which breaks and leaves you with a hole full of hardened steel.
  10. Timo Geusch
    ian field Guest
    Which can just as easily happen to the drill bit used to prepare the stud
    for whatever tool is ultimately used.
    It just one of those shitbag jobs you don't want to be doing the morning
    after.
  11. Timo Geusch
    Simon Wilson Guest
    Not IME. The drill's far less likely to jam than something that *has* to
    jam in order for it to work. And sometimes you get in the situation
    where the damn thing won't turn in either direction until it snaps.
    DAMHIKIJD
  12. Using the patented Mavis Beacon "Hunt&Peck" Technique, ian field
    You'd have to be pretty cack-handed to break a drill bit on a job like
    this.
  13. Timo Geusch
    Go and find yourself a drill that only just goes into the existing
    hole, put a mark on the drill that measures twice the diameter of the
    thread, see what happens when you try drilling the damaged thread.
    If it takes out any steel you've removed the stud and if it doesn't
    then you'd made a mistake.
    Once you've done that buy a helicoil set and use it to insert the
    head. Drilling, tapping and fitting the insert will probably take the
    grand total of about 5 minutes and if the existing threads are fucked
    you won't even need to pre-drill it, just tap it and fit the insert.
    Andy Bonwick, Aug 24, 2010
  14. Timo Geusch
    I bet you said the same about cross-threading wheel spindles at some
    point.
    ogden, Aug 24, 2010
  15. Timo Geusch
    Thread appears to be undamaged so I'd rather not Helicoil it. I'll take
    a better look on the weekend once I got all the crap off that prevents a
    more thorough inspection...
    Timo Geusch, Aug 25, 2010
  16. Timo Geusch
    I wouldn't go /quite/ that far, but yeah, I'll never use one again
    since discovering LH drillbits.
    Krusty, Aug 25, 2010
  17. The one time I used one (on a master-cylinder reservoir screw on the
    600) it was a fingers-only job -- because drilling the pilot hole had
    cracked the inter-metal corrosion.
    Anyone know a source of socket-head countersunk 6/32x3/16" screws?
    I'm having to use violent taps on the heads of cross-heads holding hard
    drives into hot-swap caddies in the RAID arrays of our GRID storage
    elements. Luckily force is tolerated as the drives being removed are
    deemed dead.
    Dr Ivan D. Reid, Aug 25, 2010
  18. Timo Geusch
    ian field Guest
    I'd wager the one's who're complaining about easy-outs snapping off are the
    one's who made a piss poor job of drilling the pilot hole.
    Can't say I've never done it myself, but I could see what I did wrong and
    didn't blame the tools.
    ian field, Aug 25, 2010
  19. Timo Geusch
    The problem with an easy out is that it forces the outside of the
    thread to expand as you wind it in so it makes the seized fastener an
    even tighter fit in the hole.
    I'd use one to extract a stud I'd broken by over-tightening but I
    wouldn't use one on a stud that was seized in after a few years of
    use.
    I don't use them because there are better ways of doing the job.
    Andy Bonwick, Aug 25, 2010
  20. Timo Geusch
    Pete Fisher Guest
    I also managed to actually twist one without moving the stuck fastener
    once years ago. They were cheap shite TBF.
    Some frog must have tried to drill out a stuck chain adjuster on the YZ
    years before I acquired it. Even John at Revs who fitted the new swing
    arm bearings didn't want to try to undo the damage. So now the one side
    has just a long hex head set screw and lock nut in a hole which isn't
    threaded or perfectly straight. As it is on the sprocket side I don't
    worry too much about it, and as long as I keep the nut nipped up tightly
    it passes scrutineering OK.
    | Pete Fisher at Home: |
    Pete Fisher, Aug 26, 2010
