FOAK Car batteries
Discussion in 'UK Motorcycles' started by Ace, Mar 21, 2010.
  1. Ace
    So the battery on J's Peugeot seems to be on the way out, but I know
    there's some experts here so I thought I'd see if there's anything I
    can do to extend its life.
    Symptoms are that it's been reluctant to start for a few weeks, with
    clearly only just enough charge to get it going. That is to say that
    it's turning the engine over at noticeably lower speed than normal.
    Today, only three days after it did a long run (100"km) it wouldn't
    start at all. A push start got it going first time, and then it was
    driven home, a distance of 140km. Now the battery's giving just enough
    to start it, but clearly is lacking.
    So I've taken it out and checked fluid levels - all cells are at the
    normal level - and put it on charge, where it's drawing 2A.
    So clearly I'll need to get a new one, but was wondering if removing
    some of the old fluid and topping up with unused battery acid would
    extend its life, at least for a few days untuil I get a new one. Any
    thoughts?
    Ace, Mar 21, 2010
  2. Ace
    Derek Turner Guest
    Try painting it pink: it will do just as much good. It's fucked. Get a
    new one tomorrow as soon as the shops open.
    Derek Turner, Mar 21, 2010
  3. Before you condemn the battery , check the obvous like drive belts ,
    loose connections etc .
    steve robinson, Mar 21, 2010
  4. Ace
    Pretty sure it's all hunky dory in that dept. Followed her home
    tonight and all lights, etc. are working fine, and the battery's taken
    a little charge, but not much.
    Ace, Mar 21, 2010
  5. Ace
    EDTA can help if it's sulphation but in reality if it's got to that stage
    only a new one will solve the problem. Although, having said that I
    managed to extend a Guzzi battery (big, simple brute of a battery) by
    another 18 months using EDTA.
    I have a feeling modern charging systems (i.e. anything post anything I
    own) are quite fussy about batteries.
    sweller, Mar 21, 2010
  6. Wot he said, no point in messing around.
    Fucked battery = buy a new one.
    Speedgazebo MOTP #1, Mar 21, 2010
  7. Ace
    Just checked, and the charging rate has dropped to ~1.7A. Is that a
    sign that it's taking charge better now that when in the car?
    Ace, Mar 21, 2010
  8. Ace
    Yes. I. Know. Re-read my post.
    The question is just whether I can get it better for a few days so I
    don't need to **** up my schedule for the morning.
    Ace, Mar 21, 2010
  9. Ace
    Wassat then?
    How would I know if it's sulphation?
    Ace, Mar 21, 2010
  10. Ace
    Nige Guest
    Buy a new one, don't **** about.
    Nige, Mar 21, 2010
  11. Ace
    Ace, Mar 21, 2010
  12. Ace
    It's a chemical that when added to a battery has the effect of causing
    sulphation to drop off the plates. It's not that readily available and
    is really just putting off the inevitable.
    http://www.sweller.co.uk/mz/electrics/elc_edta.html
    I've got a bit of a stock of it and it's worked for me in the past but I
    don't use it so much now. - I'm sure it'd be pretty useless for you as
    your battery is likely to be sealed.
  13. Quick and dirty: chuck a voltmeter on the battery terminals, expect to
    see 12v or more. Turn on the headlights- it shoildn't drop too much.
    Turn the lights back off.
    Start the car and fast-idle it, expect to see 13.5V at least, probably a
    bit more.
    Chris Bartram, Mar 21, 2010
  14. Ace
    It's not, actually, hence the question about replacing some of the
    fluid with new acid.
    But in any case all I'm hoping for at best is something so J can use
    the car during the day tomorrow and I'll get a new one on the way
    home, rather than having to do it first thing in the morning.
    Ace, Mar 21, 2010
  15. Ace
    ian field Guest
    Try discharging it dead flat then flush with distilled water and re-charge.
    If the SG doesn't come up to spec' after full charge, then top up with acid.
    TBH nursing a knackered battery will cost you more in the long run than a
    replacement.
    ian field, Mar 21, 2010
  16. Ace
    ian field Guest
  17. Ace
    ian field Guest
    Sulphation becomes an insulating layer that forms over the battery plates,
    as the exposed surface area diminishes the charge current from a fixed
    voltage charger decreases - which in turn makes it more difficult to get a
    full charge in.
    Sulphation usually happens when a battery is stored discharged, or in use
    when discharge consitently exceeds recharge for a prolonged period.
    Topping up with acid instead of distilled water (except when replacing
    spilled electrolyte) can make sulphation more likely.
  18. Ace
    **** no. I mean thanks, but no thinks. I'm only trying to get it
    useable for a day or so.
    Clearly. And I intend to spedn precisely nothing on this one.
    Ace, Mar 21, 2010
  19. Ace
    simes Guest
    As someone who has cheated death when a car battery exploded next to me,
    my advice is not to **** about with it.
    Another tip is to always let the battery stand in a well vented place
    for half an hour after charging and before using it.
    I'd been charging a fucked old battery and the connected it to the car
    and tried the starter. The battery, being fucked, sparked internally
    when I pressed the starter button and the built up hydrogen exploded and
    bloody near took my head off.
    simes, Mar 21, 2010
  20. Ace
    Brian Guest
    If you need a new one I was recently pointed in the direction of this
    lot www.tayna.co.uk/ by the FOAK in UKRM. Bloody good service and
    price, so should the worst come to the worst maybe give them a try.
    Brian
    Brian, Mar 21, 2010
