FOAK - Dishwashers
Discussion in 'UK Motorcycles' started by R C Nesbit, Feb 4, 2011.
  1. R C Nesbit
    davethedave Guest
    Errr....
    Well actually my hot water is free, and ecologically sound.
    Got one of these kind of jobbies on the roof.
    http://www.ozbaylar.com/en/urunler_keban.asp
    davethedave, Feb 5, 2011
  2. R C Nesbit
    R C Nesbit Guest
    Ian field spoke:
    I don't think I'll have that problem, the thing starts a cycle by pumping any
    remaining water out. then stops.
    Rob_P
    UKRM(at)indqualtec.co.uk
    uppercase(d) BBIWYMC#1 BOG#11? MRO#31 IBCDBBB#1(kotl)
    FJ1200, CCM130 Benelli Cabriolet (gone)
    Looks like Rab C Nesbit.
    R C Nesbit, Feb 5, 2011
  3. R C Nesbit
    Surely there was some sort of cost and energy consumed to make the system,
    transport it to your home and install it?
    There was a feature on those products on Newsnight a few days ago. Most of
    the panels used in UK are made in China and the production methods are not
    at all environmentally friendly. Then there's the transport costs. They
    would need to be working for many years to recoup the carbon. That was for
    a UK set-up and I acknowledge at your latitude the return time might be
    much shorter.
    wessie, Feb 5, 2011
  4. R C Nesbit
    R C Nesbit Guest
    Paul Corfield spoke:
    As Ben says, they actually use less water and power than using the sink and hot
    water.
    Setting aside the environmental impact of the manufacture - which is what people
    generally do when talking about Prius and the like. What is a dish-washer? a tin
    box with some plastics and some magic smoke.
    Ours is 10 years old. How many bottles of detergent, sponges, scourers, plastic
    dish-washing brushes, rusting dish-drainers will have been consumed doing it the
    hard way?
    Rob_P
  5. R C Nesbit
    R C Nesbit Guest
    Davethedave spoke:
    We have something similar on our roof. They were installed
    by the previous owners. We gave up using it, as it was only
    worthwhile in summer, when we didn't actually need that much
    hot water. It has an electronic control box in the airing
    cupboard, which displays the temp. of the water from it -
    rarely over 30c even in summer, so you still have to press
    the boost button to use an immersion heater to get to useable
    temp.
    Rob_P
  6. R C Nesbit
    Ben Guest
    And boilers grow on trees?
    Quite right, but it's still being manufactured.
    <disclaimer>I don't have a dishwasher</disclaimer>
    Ben, Feb 5, 2011
  7. R C Nesbit
    Owen Guest
    Haynes dishwasher manual... mine has paid for itself at least twice...
    Owen, Feb 5, 2011
  8. R C Nesbit
    ian field Guest
    Recently I found one in the bin room at the flats - just out of curiosity I
    went and got the tools for a look inside.
    It has various sumps & reservoirs that spilled out very smelly water when it
    was turned over.
    The front panel PCB was the only interesting bit, the waterproofed heater
    relay is now slaved to the CBX550 front brake light switch - which hasn't
    failed since despite several heavy rains, but I broke 3 of the 5 surface
    mount triacs getting them off the board.
    ian field, Feb 5, 2011
  9. Quite superb. Bloody well done, that skip dver.
    The Older Gentleman, Feb 5, 2011
  10. R C Nesbit
    Pete Fisher Guest
    All well and good as long as the thing is stacked fuller than the tardis
    before being put through a cycle.
    | Pete Fisher at Home: |
    Pete Fisher, Feb 5, 2011
  11. R C Nesbit
    davethedave Guest
    Inevitably. Plus of course the pollution created by the several cigarettes
    smoked during the install.
    It was I believe made locally-ish as in not imported. It's been on the roof
    for about 7 years or so and the only maintenance it requires is a bit of a
    rinse down once a year of the window bit and a stern kick every now and then
    to dislodge internal limescale a bit. I think it's paid for itself financially
    (landlords pocket) and environmentally, 7 years of hot water electricity is
    kind of a large chunk.
    Doesn't work too well on cloudy days though. :(
  12. R C Nesbit
    zymurgy Guest
    Racist !
    Paul.
    zymurgy, Feb 6, 2011
  13. R C Nesbit
    Switters Guest
    I usually am doing something else, whilst the mrs does the dishes. Takes
    her 5 mins and 1 bowl of water.
    Switters, Feb 7, 2011
  14. We have something similar on our roof. They were installed
    temp.
    [/QUOTE]
    That's because at the English type latitude you can't use a one tank
    system but most of the installers just buy in the system for sunnier
    climates because they don't know what they are doing.
    Use a two tank system one for pre heat one for main heat. Switch the
    solar input from one to the other depending on the differential between
    the solar panel and the main or pre heat tank. Then only add heat to the
    main tank if you need to.
    That works!
    Mick Whittingham, Feb 8, 2011
