FOAK: Dyeing clothes
Discussion in 'UK Motorcycles' started by Cane, May 8, 2006.
  1. Cane
    Cane Guest
    I've got some black jeans that are fine but a little faded so I've
    decided to dye them black again.
    I've never done something like this but have found some advice at
    http://www.dylon.co.uk/main.htm.
    Is this easy or should I just buy new jeans?
    Cane, May 8, 2006
  2. Cane
    It's that easy. I did it with a shirt and trousers a week or so ago. Get
    a pack of Dylon black machine dye and a 500g back of salt, pop both in
    the washing machine and run a 40deg cycle, then do a wash. Piece of
    piss. Dylon even do a silver pack now with the dye and salt in one,
    works out a few pence cheaper *and* fucks the environment. Hurrah!
    ogden, May 8, 2006
  3. Cane
    Eiron Guest
    Easy enough if you have a large enough vessel, remember to fix it,
    and wash the garment separately for the first few times.
    I've still got some green whites from the last time I made a tie-dye T-shirt.
    You could just ask if your local dry cleaner still does dying.
    Eiron, May 8, 2006
  4. Cane
    Dan White Guest
    Woolworths.
    Dan White, May 8, 2006
  5. Cane
    Robert Dyas or similar.
    ogden, May 8, 2006
  6. Cane
    Cane Guest
    Apparently Woolworths and Wilkinsons stock it so I assume Tesco would
    too.
    Cane, May 8, 2006
  7. Cane
    piece of piss.
    darsy, May 8, 2006
  8. Cane
    Cane Guest
    Can it be done in the bath rather than the washing machine?
    Cane, May 8, 2006
  9. Cane
    you'd probably stain your bath, even if it's metal/enamel and not a
    pikey plastic bath.
    Use a big bowl you don't care much about, or a large stainless steel
    sink.
    Also, you need specifically to buy the hand-dye rather than machine
    dye stuff.
    Not that I'm an expert, or anything.
    One last point, black jeans are for gaylords.
    darsy, May 8, 2006
  10. Cane
    Cab Guest
    Normally yes. It's just more messy.
    Cab, May 8, 2006
  11. Cane
    Cane Guest
    So what's the sophisticated heterosexual about town wearing this season?
    Cane, May 8, 2006
  12. Cane
    Eiron Guest
    Jodhpurs.
    Eiron, May 8, 2006
  13. Cane
    Cane Guest
    I'm just a little nervous about contaminating future washes with black
    dye.
    Cane, May 8, 2006
  14. Cane
    Cane Guest
    Thanks Trinny.
    Cane, May 8, 2006
  15. Cane
    You won't. If you're paranoid, do the dye cycle, then the wash cycle,
    then another hot wash without a load. By that point, the machine will be
    about as clean as it needs to be.
    Just follow the instructions on the packet and you'll be fine.
    ogden, May 8, 2006
  16. Cane
    Cane Guest
    Ta. I'll buy some today.
    Cane, May 8, 2006
  17. Cane
    Not a problem. Jude's use the 'back to black' and denim blue stuff
    several times in the machine with no ill effects. Piece of piss.
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, May 8, 2006
  18. Cane
    Cab Guest
    What I've done in the past, is run the machine through on an empty wash
    afterwards (Even then, I'm fairly convinced you don't need to do this).
    It's never caused me any probs.
    Cab, May 8, 2006
  19. Cane
    velvet.
    darsy, May 8, 2006
  20. Cane
    Nicknoxx Guest
    Just look in the Saturday Guardian Magazine. The 'Mens' Fashion page is
    as gay as ****.
    Nicknoxx, May 8, 2006
