FOAK - Fixing a mobile
Discussion in 'UK Motorcycles' started by Adrian, Jul 13, 2010.
  1. Adrian
    Adrian Guest
    'erself dropped her mobile (S-E c902) a couple of weeks ago, and smashed
    the screen into a squillion bits.
    It seemed to switch on OK afterwards, but the screen was totally dark, so
    no way to see what it was or wasn't doing. Which, since S-E's sync
    software doesn't do a thing until you make a choice from a menu on the
    phone-screen, meant there was no way to back the contacts up to a PC
    after the event.
    A new screen has been acquired, and the whole thing has been put back
    together. Without, of course, any sodding success whatsoever. The new
    screen is still consistently and overwhelmingly the one true colour.
    Arse.
    All the connectors seem to be connected properly and firmly.
    So - wtf now? She's muttering about having lost all her contacts.
    Because, of course, they weren't synched BEFORE the event...
    This may go one of two ways.
    1. It will all be my fault. All of it. Even dropping it on a hard floor.
    Even though I was several hundred miles away at the time.
    2. I will be the hero of the hour.
    Clearly, 2 is preferable.
    Anybody think of a way to get the contacts off the phone without having
    to use the screen...?
  2. Adrian
    Adrian Guest
    Fantastic - I'll give it a go.
  3. Adrian
    Dr Zoidberg Guest
    Find someone else with the same handset, and get them to run through a sync,
    noting each keypress - asking on uk.telecom.mobile would be a good place to
    start
    Dr Zoidberg, Jul 13, 2010
  4. Adrian
    davethedave Guest
    As a slightly odd approach, if the bluetooth is on you could attack it with
    the bluediving software. I have managed to get contacts off my nokia 6310
    this way. Nokia and Linux often don't play nicely together. :(
    davethedave, Jul 13, 2010
  5. Adrian
    Adrian Guest
    Arse. Looks like the theory's sound, but the phone is fubar.
    Adrian, Jul 14, 2010
  6. Adrian
    Adrian Guest
    Should add - it's visible as a USB device, pause, device manager
    refreshes, pause, device manager refreshes, pause, it's gone. Longer
    pause, it's visible again. Repeat ad infinitum
  7. Adrian
    As it's fucked anyway, try bunging it in the freezer for a few hours. A
    bit of thermal movement may bring it back to life temporarily.
    Krusty, Jul 14, 2010
