FOAK: Fog Lamps or not on cars.
Discussion in 'UK Motorcycles' started by MrMoosehead, Aug 19, 2004.
  1. MrMoosehead
    MrMoosehead Guest
    This new little Clio thingy we have has two 'sockets' for lights on the
    front bumper.
    Karen has trouble driving in the dark, or twilight times.
    So I figured that we could get the lower lamps fitted to give her that
    extra bit of light to see if it made any difference.
    Anyway, the chap in the Renault garage said it would be illegal to have
    them on all the time as they are fog lights.
    But what makes a front light a fog light? I can understand the rear
    light business. But when is a headlight a headlight and not a foglight
    etc.
    Anyone know?
    Janitors? MOT nerds?
  2. MrMoosehead
    The Construction and Use Regs dictate. A foglight is defined in these
    by its position - a rule of thumb is that if the light is at or below
    bumper level, it is a foglight (although there was a Fiesta that had
    driving lights mounted with foglights in the chin spoiler).
    The lens and diffraction pattern for a foglight gives a broad spread
    of not very bright light over a wide arc, with a sharp cutoff which is
    designed to minimise the amount of light bounced back by the fog at
    the driver.
    It is only permitted to use fog lights in conditions of falling snow
    or severely reduced visibility (not darkness) of, iirc 50m. That
    doesn't stop the Corsa boys, nor the BMW yuppies, mind.
    Pip, Aug 19, 2004
  3. MrMoosehead
    SteveH Guest
    For lamp has a low aim to illuminate the road surface in foggy
    conditions. Usually wired so they can be switched on with anything from
    sidelights through dip and main beam. They're illegal to use in anything
    other than 'restricted' visibility.
    What you want are lights that would commonly be known as 'driving
    lights' - these have a higher aim, similar to that of your main beam,
    and can only come on with the main beam. Not had a car with them for a
    while, but I had them on my shite old Escort (although they were mounted
    above, rather than below the bumper) - and they had the ability to turn
    night into day.
    SteveH, Aug 19, 2004
  4. MrMoosehead
    Stoneskin Guest
    SteveH left a note on my windscreen which said:
    My VW Passat has fog lights in the main headlight cluster. Would these
    be more accuratly described as 'driving lights' then?
    Stoneskin, Aug 19, 2004
  5. MrMoosehead
    I don't think he does, see. Mrs Moose wants to be able to see better
    on her commute, I guess, where use of main beam would be unwelcome.
    Pip, Aug 19, 2004
  6. MrMoosehead
    SteveH Guest
    No. VW are a little odd in this respect. A MkI / MkII Golf can have fogs
    mounted in the grille next to the headlamps.
  7. MrMoosehead
    Catman Guest
    If they come on with dipped lights (and go off with full beam) then they're
    fog lights. If they stay on with full beam, or come on only with full
    beam, they're driving lights.
    FWIW very few modern vehicles (AFAIK) have driving lights.
    www.cuore-sportivo.co.uk
    Catman, Aug 19, 2004
  8. They do, however, provide a highly visible indication of "**** behind the
    wheel". Which is nice.
    Soy.
    Soylent Green, Aug 19, 2004
  9. MrMoosehead
    Catman Guest
    I find they dazzle as well as providing the above indication.
  10. MrMoosehead
    Incorrect. Most (all?) standard fitment foglights stay on with the
    main beam as well.
    Ace, Aug 19, 2004
  11. MrMoosehead
    [car front fog lights]
    Indeed they seem to - which doesn't indicate that they are a) aligned
    correctly or b) fulfil their designed function.
    Pip, Aug 19, 2004
  12. MrMoosehead
    Catman Guest
    Erm, are you really sure about that?
    No car I've ever own or seen has had front fogs that stay on with main
    beam. Apart from anything else, it's a bit pointless. You won't be using
    full beam in fog, and if it's not foggy, they should not be on.
    However I could be (and probably am) wrong.
  13. MrMoosehead
    Not necessarily true. Depending on the car's normal lights, there may
    be occasions where the extra close-up spread of the fog lights is
    helpful even with main beam. And consider all the different causes of
    poor visibility - they don't all cause massive reflection back at the
    driver.
    Apart from very heavy rain and spray, sleet, snow, smoke etc.
    Pus many (French) drivers like to leave them on at all times, so I've
    had plenty of opportunity to observe.
    Well I can say with 100% certainty that Volvo and Peugeot (current
    cars) fogs stay on with main, perhaps 99.5% sure of BMW & Jaguar,
    going down to perhaps 99.0% confidence for Rover, Vauxhall and Ford.
    Ace, Aug 20, 2004
  14. Not in the UK matey, the rules are 'Falling snow and fog that reduces
    visibility to less than 50 mtres". Not rain, drizzle, artichoke
    invasion or posing down the pub cos it looks cool.
    Attilla the Hungry, Aug 20, 2004
  15. MrMoosehead
    No good quoting rules to me mate. you're not seriously going to claim
    that nobody uses their fog lights in heavy rain or sleet (which could
    perhaps tachnically be called snow anyway) are you?
    My point was simply that there may be times when one would want the
    fog lights on as well as the main beam.
    Ace, Aug 20, 2004
  16. No - there are plenty of examples of people who use them inapropriately.
    I can't think of any.
  17. MrMoosehead
    Really? You must have a very limited imagination then.
    Ace, Aug 20, 2004
  18. MrMoosehead
    Stoneskin Guest
    Bob left a note on my windscreen which said:
    My VW Passat has it's 'fog lights' in the main headlight cluster - above
    the bumper and the same height as the headlights and main beam.
    So are these fog lights and is it illegal to use them in 'normal'
    weather conditions?
    Stoneskin, Aug 20, 2004
  19. Why would I want to use a set of lights that dazzle other road users
    and offer only a low level of illumination when I have correctly
    adjusted headlights and driving lights to use?
  20. MrMoosehead
    Because fog lights shine in places that headlights and 'driving
    lights' don't. Didn't you read what I wrote up there^? foglights can
    give significantly improved visibility of the road edges immediately
    in fron of the vehicle, which is a great help in poor visibility, even
    if you've got main beam on.
    What point, exactly, are you trying to make? So far you seem
    determined to disagree on principle, which is fine, of course, but it
    might be nice to know what you're wanting to prove.
    Ace, Aug 20, 2004
