FOAK - glue on clothes
Discussion in 'UK Motorcycles' started by Ace, Nov 29, 2005.
  1. Ace
    OK, so I was glueing a bit back onto one of Jude's ski boot last night
    and inadvertently got some on my jeans and short.
    So anyone know any old wives' tales for getting glue off fabrics?
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, Nov 29, 2005
  2. Ace
    muddy Guest
    Is there anything on the glue container on what to do if you get it on
    soemthing you didn't intend?
    muddy, Nov 29, 2005
  3. Ace
    No. It's a bostik-like stuff though. I imagine any solvent will work,
    but I'm a biit loath to try tstuff at random.
    _______
    Ace, Nov 29, 2005
  4. Ace
    muddy Guest
    You could just leave them like that, they'll have used look then.
    muddy, Nov 29, 2005
  5. Ace
    Jeremy Guest
    Still got some stuck on your fingers by the looks of it.
    jeremy
    '01 Triumph Sprint ST in green
    jeremy0505 at gmail.com
    Jeremy, Nov 29, 2005
  6. Ace
    flash Guest
    Try fire and water.
    flash, Nov 29, 2005
  7. Ace
    flash Guest
    Sounds like it needs glueing.
    flash, Nov 29, 2005
  8. What type of glue is it
    Steve Robinson, Nov 29, 2005
  9. stick them in the freezer that should make it brittle enough to pick off
  10. Ace
    muddy Guest
    And then drag them behind the bike for a few miles.
    muddy, Nov 29, 2005
  11. Ace
    Sticky stuff. Not cyanoacrylate, not epoxy, just glue.
    _______
    Ace, Nov 29, 2005
  12. Ace
    flash Guest
    But make sure you drag it from warp to weft.
    flash, Nov 29, 2005
  13. Ace
    Cane Guest
    Rub it with a glass and then break the glass. Bury the bits in your
    neighbours garden.
    Cane, Nov 29, 2005
  14. Ace
    B.G. Finlay Guest
    Steve Robinson () wrote:
    : >>> OK, so I was glueing a bit back onto one of Jude's ski boot last night
    : >>> and inadvertently got some on my jeans and short.
    : >>> So anyone know any old wives' tales for getting glue off fabrics?
    : stick them in the freezer that should make it brittle enough to pick off
    Think you've got your old wives tales mixed up ... isn't that the one for
    getting chewing gum off stuff?
    Blair
    '03 R1150GS
    '97 CBR600
    B.G. Finlay, Nov 29, 2005
  15. In uk.rec.motorcycles, Ace amazed us all with this pearl of wisdom:
    What sort of glue?
    Stick em in the freezer and pick it off when frozen, unless you can buy
    that whizzy ice in a can stuff we had when I worked at the cleaners.
    Whinging Courier, Nov 29, 2005
  16. Ace
    Chris H Guest
    Try normal washing first. If that doesn't work, assuming the fabric is
    *not* synthetic, use nail varnish remover and then wash as normal.
    That worked for most of the people who used to ask us the same question
    at work [1].
    Chris H, Nov 29, 2005
  17. Ace
    Removes footnotes too!
    CT, Nov 29, 2005
  18. Also works on some contact adhesives
    worth a try.
  19. Not on a hot wash though and don't stick them in the tumble drier or iron
    them.
  20. "If glue on fabric ye would have gone,
    A peck of hensteeth must ye rub on.
    Then douse the site with snail's blood,
    And hence to Sketchleys in your 'hood."
    -Anon.
    Soylent Green, Nov 29, 2005
