FOAK: High-pitched whining from laptop
Discussion in 'UK Motorcycles' started by TD, Jan 2, 2010.
  1. TD
    TD Guest
    It's not loud as such, but in a quiet room I can hear it quite well enough,
    and it's pissing me right off. Sounds like a very high-pitched intermittent
    scratchy noise. Laptop is a Lenovo Thinkpad R61, before I phone the on-site
    maintenance line, anybody know what the problem is likely to be? Otherwise,
    they'll just turn up and waste time replacing random parts.
    Or I could listen to more loud rock music until I can't hear anything
    high-pitched.
    TD, Jan 2, 2010
  2. TD
    Gavin Guest
    Only thing it can be is anything thats moving, so thats the internal
    CPU fan, thats going to be on a heat pipe, or the HDD is on its way out.
    Id make sure of a known good backup right now, as both could cause data
    loss in the event of a failure.
    Gavin.
    GSXR600K1
    Twitter: http://twitter.com/gavin_wilby
    Blog: http://www.stoof.co.uk
    Gavin, Jan 2, 2010
  3. TD
    Catman Guest
    Could be the backlight inverter if it has one.
    www.cuore-sportivo.co.uk
    Catman, Jan 2, 2010
  4. TD
    it could just be some crap in a fan, or a badly routed cable fouling a fan
    wessie, Jan 2, 2010
  5. TD
    TD Guest
    I like this. A lot. The noise sounds more "electrical" than "fan-ny"[1].
    Any specific tests I can do to test this hypothesis further (without
    disassembling the laptop)?
    [1] It's not a moist, squelchy, warm noise.
    TD
    2000 GSX1300RX (red and black)
    1991 VFR400R NC30 (black and red)
    1993 Eunos Roadster (supercharged)
    Missing: SOB, Unreliable Italian exotica
    TD, Jan 2, 2010
  6. TD
    Catman Guest
    If it's fan then it is *likely* to change with CPU load, getting higher
    pitched / louder under load
    Disc would be dependent on disc access (durrr)
    Inverter is a bit trickier. You could try turning the backlight right
    down to zero. That might turn off the light, which should do the
    inverter. Also try sleeping the screen. Normally inverter noise is
    pretty constant as well, so it could be a complete red herring.
    Catman, Jan 2, 2010
  7. TD
    rick Guest
    Seconded - assuming you haven't trapped a woman inside the laptop.
    rick, Jan 2, 2010
  8. Sounds likely to me as well.
    Plug in a monitor and switch to external display only.
    Chris Bartram, Jan 2, 2010
  9. TD
    Cab Guest
    Cab, Jan 2, 2010
  10. TD
    make that old woman, then
    wessie, Jan 2, 2010
