FOAK: Inverters for lower voltages
Discussion in 'UK Motorcycles' started by R obbo, Aug 29, 2005.
  1. R obbo
    R obbo Guest
    I've Googled for info but little available.
    All I need to achieve is to produce a stable 24v dc at around 8A from a
    regular 12v car/van battery or supply.
    I also have a good power output 7kVa generator on board but it's too
    unstable to use for the job I need to do, even if I was to use a 24v charger
    off the supply
    I can get many devices to do 230v from 12 or 24v at all sorts of amperages
    for loadsamoney.
    So, how can I build a reasonable stable output unit to power the computer
    system on a crane when the original power system has gone tits up or is
    unavailable?
    I sometimes need to power a system up without a lorry unit being attached to
    be able to perform diagnostics of crane failures or problems from the
    onboard computer unit. The tests may take up to an hour at a steady 8A.
    Fluctuation over + - 4v or a couple of amps and the system shuts down.
    Carrying 24v batteries may be a solution but impractical really.
    TIA
    R o b b o
    Trophy 1200 1998
    B.O.S.M 2003, 2004, 2005
    FURSWB#1 KotL..YTC449
    PM#7
  2. In uk.rec.motorcycles, R obbo amazed us all with this pearl of wisdom:
    uk.radio.amateur is that way ------->
    Seriously.
    Whinging Courier, Aug 29, 2005
  3. R obbo wrote
    Not really, it actually sounds quite the best idea. An 8ampere/hour
    load is less than your most pathetic of bike batteries could handle
    standing on its head. It really is not very much at all. Whack a
    couple in series for your 24V and the only problem you have is charging
    them
    Unless you are doing this every day: a couple of square feet of solar
    panel, a voltage control chip of some sort, a couple of small
    components, all you need. If you intend to do it regularly then get
    bigger panels.
    steve auvache, Aug 29, 2005
  4. R obbo
    R obbo Guest
    Now *that's* an idea!
    Maplin do a solar charger unit quite cheap, so I could arrange a panel on
    the van roof for charging to a couple of 12v batteries in series.
    I'll look at Maplin for bits
    Ta Steve
    R o b b o
    Trophy 1200 1998
    PM#7
  5. R obbo wrote
    While you are shopping at Maplins you may wish to consider dispensing
    with the panels and buying a DC/DC converter. Such that you can charge
    the 24V battery from the van 12V system, when the ignition is on say.
    As much as I would like to see it, I don't fancy the panels you can get
    from Maplin are really up to the G forces coming their way when glued to
    the top of a van.
  6. R obbo
    Steve Parry Guest
    R obbo fumbled, fiddled and fingered:
    http://www.directsupplyukltd.co.uk/category50_89/product168/product_info.html
    http://www.justoffbase.co.uk/s.nl/sc.9/category.162/it.A/id.6556/.f
    Steve Parry
    K100RS SE & F650
    (not forgetting the SK90PY)
    http://www.gwynfryn.co.uk
    Steve Parry, Aug 29, 2005
  7. Use a parallel charge series discharge set up. Whack a relay in there to
    do it automatically if you want.
    Mick Whittingham, Sep 5, 2005
