FOAK: iPAQ memory cards
Discussion in 'UK Motorcycles' started by Nursey, Jul 7, 2004.
  1. Nursey
    Nursey Guest
    Oh, fount of all knowledge, can you use both compact flash and secure
    digital cards on an iPAQ 2210 at the same time?
    I've looked in the manual, and on hp's site and there is no mention of
    this.
    Nursey RN
    ALS Provider OSOS#25 MIRTTH#6 IbW#09 4#COFF EFFA MOP#1
    Honda Deauville (NTV650-V) (Mine)
    Tweenies Trike (Caitlin's)
    Nursey, Jul 7, 2004
  2. Nursey
    Ben Guest
    Allegedly, yes. But I've only got CF ones so that's all I've tried.
    Ben, Jul 7, 2004
  3. Nursey
    Catman Guest
    What he said, in every particular.
    www.cuore-sportivo.co.uk
    Catman, Jul 7, 2004
  4. Nursey
    JoeR Guest
    I've use a 16Mb MMC card and a 64Mb CF card at the same time without
    problems on the 2210.
    HTH.
    JoeR, Jul 7, 2004
  5. Nursey
    Alan T Guest
    Similarly only tried one card type, but no problems with any of the SD
    cards I've used
    Alan T, Jul 7, 2004
  6. Nursey
    Catman Guest
    Since we have all these 2210 owners together, has anyone else had problems
    with the black rubber down the sides lifting?
    Catman, Jul 8, 2004
  7. Nursey
    Alan T Guest
    Actually I'm a 5450 owner (nice hard case) but the 2210 I bought to
    bring my parents into the 20th Century is suffering this in only 2
    months
    Alan T, Jul 8, 2004
  8. Nursey
    entwisi Guest
    Not an IPaq but I have a Dell Axim X5 and can use both SD/MMC and CF at
    the same time. They get mounted under "SD Card" and "CF Card" respectively.
    entwisi, Jul 8, 2004
  9. Nursey
    JoeR Guest
    I've not had this problem in 6 months, but I don't use it too heavily.
    JoeR, Jul 8, 2004
  10. Nursey
    Ben Guest
    Nope, but does anyone else find it freezes or generally doesn't work
    properly after a couple of days unused in the docking station?
    Ben, Jul 8, 2004
  11. Nursey
    Catman Guest
    Mines barely two months old
    Catman, Jul 8, 2004
  12. Nursey
    Catman Guest
    Mine crashes with checkpoint + tom tom, but no more than other non-XP
    windows OSs I've seen
    Catman, Jul 8, 2004
  13. Nursey
    Catman Guest
    Sounds about right. Can't be doing with sending it back again though.
    Catman, Jul 8, 2004
  14. Nursey
    Nursey Guest
    Ditto. Did it once going down the M60 when heading towards Glossop.
    Required a restart.
    Nursey RN
    Nursey, Jul 8, 2004
  15. Nursey
    Catman Guest
    Fortunatley it's only crashed once whie actually on the road. What
    normally happens is that checkpoint loads, but tom tom dunt
    and then checkpoint hangs........
    Catman, Jul 8, 2004
  16. Nursey
    Nursey Guest
    I found that after checkpoint loading there is a longish delay with
    tomtom loading. It does load, and work, but takes quite a while.
    Wonder if it has anything to do with the amount of poi's that it needs
    to load. I have all the speed camera's as layers, as taken from
    poiplace. That might cause the slow load, but I've never had tomtom
    hang when checkpoint initiates the load.
    Nursey RN
    Nursey, Jul 9, 2004
  17. Nursey
    Catman Guest
    Mine sometimes loads within seconds, sometimes, it just doesn't. Sometimes
    it loads eventually
    Hmm, interesting. The amount of overlays definitley has an upper limit
    (detailed on the website).
    In general, although it's not perfect, it's a *whole* load better than
    anything else I have access to.
    Catman, Jul 9, 2004
  18. Nursey
    Alan T Guest
    You can't in TT2. TT3 allows a route via multiple locations, but TT2
    is point to point only (and only within one map). POIs allow
    additional information to be added and can be done in any number of
    ways, but if you want to use them as way points you'd have to navigate
    to the first, then stop and ask the system to plan a route to the
    second (repeat as necessary).
    If you can be bothered to spend enough time doing it you could frig
    the system to generate a route, but it would involve doing things like
    setting motorway default speed to 1mph and using "avoid area" to force
    the route down the roads that you want, which becomes problematical if
    you then decide to detour and still want to get to Edinburgh!
    I stand to be corrected by those in the know, but that's my
    understanding at least.
    Alan T, Jul 9, 2004
  19. Nursey
    entwisi Guest
    Just out of interest, how do you set way points in TT2? Or is it possible
    to create a route yourself and load it into TT. I want to make a nice day
    of my ride up to edinburgh in a few weeks and would like to get the route
    planned outside of TT and then load it in. I must admit I haven't looked
    into it much, but this thread has sort of prompted me to think about it
    and I thought one of you may have done this already.
    Cheers
    entwisi, Jul 9, 2004
  20. Nursey
    Catman Guest
    You can't AFAIK
    Not that I'm aware of
    Catman, Jul 10, 2004
