FOAK: Keys
Discussion in 'UK Motorcycles' started by Cane, Oct 21, 2006.
  1. Cane
    Cab Guest
    Wot? Cane is allergic to books?
    Cab, Oct 22, 2006
  2. Cane
    Cab Guest
    I did. I thought I was cracking a joke.
    Obviously not, so I'll not give up the day job.
    Cab, Oct 22, 2006
  3. Cane
    Cane says...
    Are you sure you haven't had them fall out of the lock because it's
    worn? You can't trust these modern locks you know - better to use a big
    padlock and chain.
    <scratches chin in a Jimmy Hill stylee>
    Lozzo
    GSF600SW (broked)
    'I do not object to people looking at their watches when I am speaking.
    But I strongly object when they start shaking them to make certain they
    are still going.' William Norman Birkett, 1st Baron Birkett, Oct 1960.
    Lozzo, Oct 22, 2006
  4. Cane
    Cane Guest
    Good point as when I turn my bike upside down the keys generally drop
    out of that too.
    Cane, Oct 23, 2006
  5. Cane
    Repeat after me:
    "Raised intonation cannot be represented in a text-based medium simply
    by adding a question mark"
    CT, Oct 23, 2006
  6. Cane
    Err, can I just ask why you think this is not the case? You quite
    clearly took the question mark so to represent, so you are, in fact,
    contradicting yourself.
    _______
    Ace, Oct 23, 2006
  7. Cane
    <fx:stands up>
    "My name is Chris and I'm a grammar pedant."
    <fx:sits down>
    It's because, IMHO, a question mark indicates a question.[1] What Champ
    typed wasn't a question.
    Is this one of those "if we know what it means then it doesn't matter
    if it's wrong" instances?
    Anway, just because (I think) I understood what Champ was trying to
    achieve by adding the question mark, I still think it's wrong to do so.
    [1] Or does it? Maybe now a '?' represents either question or RI. And
    if we can tell whether it's a question or not without it, why do we
    need it? Discuss.
    CT, Oct 23, 2006
  8. Cane
    Yes it was. He was quite clearly asking if the OP could perhaps read
    the rest of the thread. You could tell, see, because he put a question
    mark at the end of the sentence.
    It's more one of those "if everyone knows what something means, then
    how can it be wrong?" instances.
    Well I say that you're wrong to try and apply an arbitrary rule of
    _your_own_making.
    In fact, the use of a question mark in this way, to indicate that a
    statement is intended as a question without reversing the verb/subject
    order, has been around for centuries.
    <reaches for Complete Works of Shakespeare>
    Here we go: As you like it Act V Sc II "Why then, tomorrow I cannot
    serve your turn for Rosalind?" Sc IV "You say, if I bring in your
    Rosalind, you will bestow her on Orlando here?"
    Need I go on?
    _______
    Ace, Oct 23, 2006
  9. Cane
    The words formed a statement, the question mark confused the issue.
    Either the question mark was wrong or the order of the words "you
    could" was wrong.
    Well, this is ukrm. I thought it was obligatory.
    Yeah, but Shakespeare was shit. Everyone knows he couldn't write
    proper English.
    CT, Oct 23, 2006
  10. Cane
    I don't think so. A rhetorical question is still a question, it just
    requires no answer (or has an implied answer).
    CT, Oct 23, 2006
  11. Cane
    You'd better tell the OED and other grammar and dictionary makers
    then, as his work forms the basis for many of the rules we comsider
    normal.
    _______
    Ace, Oct 23, 2006
  12. Cane
    You're both 'wrong' according to dictionary definitions.
    _______
    Ace, Oct 23, 2006
  13. Cane
    Yeah, right[1].
    [1] "and there is no construction in which two positives make a
    negative"
    CT, Oct 23, 2006
  14. Cane
    <fx: waves hands dismissively>[1]
    But what do they know?
    [1] Credit WUN as I think this is one of his.
    CT, Oct 23, 2006
  15. Cane
    Mups Guest
    Probably still in the pot at the last party you went to...
    Mups, Oct 23, 2006
  16. It could?
    The Older Gentleman, Oct 23, 2006
  17. Cane
    Err, I'd very much like you to expand on that, as I believe you are
    wrong. A very high proportion of 'new' words and usages that entered
    the language between 'middle' and 'modern' English are first
    encountered in Shakespeare and it's largely his work that we (the OED
    et al.) use as a reference for their 'modern' meaning.
    _______
    Ace, Oct 24, 2006
  18. Cane
    Yes, I know. And it also records when the normally understood usage
    was first recorded. Perhaps you misunderstood me when I said " his
    work forms the basis for many of the rules we comsider normal." What I
    meant was that the first recorded instances of 'normal' usage 'rules'
    appear in his work. Mainly because he was so prolific and used current
    language (we assume) in what he wrote.
    Quite. As I was saying earlier.
    My point entirely. So he's the single largest source of reference as
    to what we consider 'modern English' as it's understood and recorded
    by peeps like your bro. He didn't invent the language, he just
    recorded it.
    For the meaning of those usages that he first recorded, is what I
    meant. You seem to be extrapolating my meaning to encompass the whole
    of the English language, which was not what I said or meant.
    _______
    Ace, Oct 24, 2006
