FOAK: Laptop repairs
Discussion in 'UK Motorcycles' started by Doki, Feb 23, 2008.
  1. Doki
    Doki Guest
    My bird's laptop has packed up. It won't charge, so it seems the charger
    connector has probably broken off the PCB. Does anyone know of a decent
    repairer? I'm probably up to the soldering, but dismantling things like this
    is always an absolute PITA.
    Doki, Feb 23, 2008
  2. Doki
    JB Guest
    Likely as not it will need a new motherboard if the connector has snapped
    off the pcb (almost certainly if it's a Dell). Motherboards are often up to
    12-layer pcbs and a bitch to solder. Ask over on uk.adverts.computer for a
    chap called Paul Durkin (used to run ITDealers.co.uk). He's now got a *very*
    reputable laptop repair business.
    JB
    JB, Feb 23, 2008
  3. Doki
    Doki Guest
    It's an Acer that's a couple of years old. TBH it's tempting to bin the
    piece of shit and get something half decent like a Toshiba. The connector
    outwardly looks fine, but there's obviously *something* wrong with it.
    Doki, Feb 23, 2008
  4. Doki
    Iridium Guest
    Not the power pack or the battery?
    Iridium, Feb 23, 2008
  5. Doki
    Catman Guest
    Greybeard just fixed a very similar fault on my mother's. Good service,
    very reasonably priced. HTH
    www.cuore-sportivo.co.uk
    Catman, Feb 23, 2008
  6. Doki
    Greybeard Guest
    If you want to send it to me, I'll have a look and let you know the likely
    cost.
    If it's not viable or too pricey all you'll have to pay is the return
    courier, about 8.90 UKP IIRC.
    email in sig works if repaired.
    Greybeard
    FLHR -03 UK (95 cu-in Stg 2. Big Boy2!)
    Trumpet Trophy 1200-03
    Garmin Zumo 550, To get me home!
    ukrm@foxtails[dot]co[dot]uk
    Greybeard, Feb 23, 2008
  7. Doki
    Doki Guest
    Where are you? I'll have a hunt for a laptop shaped box. It's got work for
    the bird's disseration on it so it could do with fixing...
    Doki, Feb 23, 2008
  8. Doki
    I may have a IBM/Lenovo Thinkpad X32 for sale very soon for a reasonable
    price.
    Timo Geusch, Feb 23, 2008
  9. Doki
    SteveH Guest
    Might be worth whipping the drive out and backing it up using an
    external caddy before you send it anywhere, then.
    SteveH, Feb 23, 2008
  10. Doki
    Doki Guest
    Specs and age?
    Doki, Feb 23, 2008
  11. Doki
    From memory, 'cos I can't get Solaris to display a decent dmesg on it
    atm:
    1.8 GiggleHurtz Centrino w/ 40GB HD, 1.5GB RAM. Wifi, wired ethernet
    and all the usual Centrino-spec stuff. It's the 12.2" ultraportable in
    case you were wondering (JFGI).
    Comes with the "bottom half" docking station with integral DVD and all
    that bollox as well. Battery is in good nick - I use it on the train
    quite often (well, I use it when I take the train) and it does hold
    enough to get me to London and back. So it's good for at least two
    hours if not longer.
    Age? Hmm. I bought it used and I think I found that it was about six
    months old back then, so that'll make it roughly two years old by now.
    No idea of the warranty status but I think it may well be just out of
    warranty. It's still in very good nick as I don't use it that much.
    It does come with a valid Windows license but the git I bought it from
    reinstalled Windows manually instead of using the restore partion so
    the latter went tits up. IBM will flog you a set of restore disks which
    I haven't bothered to get, but I think that would be a jolly good idea
    as most of the special IBM software is missing. Not that you can't
    download most of it.
    AFAIR it's in the books for around 275 but as it's my company laptop
    I'd have to charge VAT on top of that. That's still a rather good price
    - they tend to sell on ebay for ~300 without the baseplate which means
    that this would be without an optical drive, and the cheapest
    baseplate/docking station is around 70 quid...
  12. Doki
    Greybeard Guest
    emailed;
    Newmarket, Suffolk.
    Greybeard
  13. Doki
    Greybeard Guest
    _Very_ good suggestion.
    Greybeard
  14. Doki
    Simon Wilson Guest
    You might want to check the drive for photos too before you send it
    away. You just can't be too careful with these laptop repair folk.
    Simon Wilson, Feb 23, 2008
  15. Doki
    Greybeard Guest
    Hey!
    Don't spoil _all_ the fun ;o)
    Greybeard
  16. Doki
    Catman Guest
    You should see what he puts *on* it.......
  17. Doki
    Doki Guest
    A bit more examination (a bit more than being told it's not working)
    suggests the charger is at fault. The LED on it's not lighting up. It
    appears to be a standard liteon item so hopefully it won't be too hard to
    find another (strange cable with a plugthat looks similar to an IEC "kettle"
    lead but is like three bits of macaroni stuck together, going into a little
    switched mode looking box that goes to a normal laptop style plug at the
    other end).
    Doki, Feb 23, 2008
  18. Doki
    If it helps, Compaqs, some IBMs and pretty much all Dells use this kind
    of cable. Won't help the guy at PC Woe, but it's proper useless info
    anyway :).
  19. Doki
    Greybeard Guest
    That's not too serious.
    PSU bricks are not to hard to find, and prolly around the 30 quid mark.
    Greybeard
  20. Doki
    SteveH Guest
    That's a standard 'cloverleaf' plug.
