FOAK: Media PC and TV/Satellite cards
Discussion in 'UK Motorcycles' started by Ian White, Oct 16, 2009.
  1. Ian White
    Ian White Guest
    Either I'm searching for the wrong thing or it doesn't exist.
    I've got a satellite dish on the house, regular digital aerial is shite
    reception. I want to build a media PC and need to source a card that
    will take the satellite feed. I get either blank stares or "you need a
    freesat card and these are *very* new" in local PC specialist shops. I'm
    not sure a freesat card is what I need.
    So, does such a thing exist? A card that will take the regular satellite
    cable and show me all the free-to-view channels. Or better still, a card
    that will take same cable, together with my Sky viewing card, and show
    me all the free-to-air (or (should I choose to) subscribed channels).
    Cheers in advance.
  2. I use a Skystar2 for exactly that. There are more recent versions around
    now. I use DVB-Dream software, which is excellent and free. In
    development all the time, so there's a short and easy learning curve.
    The maker's sw is ok, but a bit limited.
    I'm sure I've seen something similar - a PC card that will take a CAM,
    but whether a Sky card will work is something else.
    Grimly Curmudgeon, Oct 16, 2009
  3. Ian White
    Higgins Guest
    As Grimly says, there are PCI cards available to do just what you want,
    including BBC HD. I use a Technotrend 3200-S2.
    You can use a Smargo USB card reader to do this but it's a bit of a faff
    and you need to be pretty keen.
    Higgins, Oct 16, 2009
  4. Ian White
    Go back & tell them they're clueless fuckwits.
    Yes, plenty of them. I've got a Hauppauge HVR3000 hybrid which does
    free-to-air satellite, Freeview & analogue in (Sky box).
    You need a CAM to do that. Not really mainstream, but plenty of info
    out there if you Google. I went for an alternative approach - hybrid
    card for freesat & freeview, & a PVR150 card for the Sky box.
    Krusty, Oct 16, 2009
  5. Ian White
    Ian White Guest
    There's a reason this NG is called the FOAK.
    Plenty to go on there, thanks all.
  6. Ian White
    Others have covered the ground well enough, but here's a bit more.
    The simplest solution is to get some soty of satellite set top box
    (STB), either FreeSat or Sky, yjrm plug the output of that into a
    pretty vanilla analogue TV card. The Hauppauge PVR150 is the card of
    choice for this. You'll also need a thing called an IR Blaster which
    flashes infrared at the STB to get it to change channel. The various
    verions of Windows Media Center (XP, Vista, Windows 7) all do this, as
    does GBPVR. This is what I, Krusty & several others do.
    The next, slightly more complicated step is to plug the feed directly
    from the satelite (the LNB) into the TV card, dispensing with the STB.
    A liitle more complex, but AIUI, straightforward enough for FreeSat.
    You need a DVB-S/S2 card for this.
    The most complex option is where you plug a Sky feed directly into the
    TV card and can access the encrypted Sky channels. As the others say,
    you need a thing called a CAM for this. It is do-able, but most
    solutions seem to be homebrewed atm. Google is your friend.
    I can give lots of advice on option 1, so ask away if you want.
    Champ, Oct 17, 2009
  7. Ian White
    Well, "soty" is obviously "sort", but I'm fucked on "yjrm" - is it a
    predictive text alternate, or some variety of component feed into the
    TV?
    Pip, Oct 17, 2009
  8. Ian White
    gary Guest
    yjrm = 1 key out when typing - try reading a keyboard 1 key to the left of
    quoted letters - it'll all make sense then.
    And beware - I'm back on 2 wheels
    Big Fat Ugly Old Bloke
    gary, Oct 17, 2009
  9. Ian White
    <sigh>
    Back on a newsreader, too. Kindly dmo[ dohd on uk.r.m. Thanks.
    Pip, Oct 17, 2009
  10. Ian White
    Ian White Guest
    Cheers for the in depth. I've thought about the STB, but I want to get
    rid of all the crap we have and have a single unit and a TV.
    That way I can rip the kids' favourite DVDs, watch the basics on TV and
    have access to iPlayer and a US-based slingbox and listen to streamed radio.
    I may be in touch later when I get round to actually sourcing all the
    pieces. At the rate it's going so far, that'll be January .. 2011. ;)
    Ian White, Oct 17, 2009
  11. Ian White
    Catman Guest
    Way too mych effort expended there, sir. In the old days a simple '****
    off' would have been the way.
    *sigh* Things ain't what they used to be.
    116 Giulietta 3.0l Sprint 1.7 GTV TS 156 V6 2.5 S2
    www.cuore-sportivo.co.uk
    Catman, Oct 17, 2009
  12. Ian White
    Ian White Guest
    Excellent read, thanks. I like the look of the SilverStone and as I'll
    be running Slingbox and otherWeb stuff the right mouse on the iMon looks
    useful - Microsoft not got a right click on theirs?
    "I did however, want a VFD in the front" - WTF is a VFD i this context?
    Acronym finder says "Volunteer Fire Dept." ;)
    I been running Windows (Ultimate) 7 via VMWare on my MacBook Pro for a
    few months now and it's a **** of a lot better than Vista. Whilst I'd
    like to think I'm platform agnostic (Mac, Solaris, Linux, whatever) it's
    looking favourite for the home box. Apart from being quite slick, a mate
    at work's got a free unrestricted MSDN subscription which puts it on a
    par with *NIX, price-wise. ;)
  13. Ian White
    Higgins Guest
    Not my experience at all, using 32 and 64 bit versions on different
    boxes. I don't recall a single problem.
    Higgins, Oct 17, 2009
  14. Ian White
    Ian White Guest
    Probably made by Apple.
    Ian White, Oct 18, 2009
  15. Ian White
    Ben Guest
    Ben, Oct 27, 2009
