FOAK: Paging the Ultrasonicisti
Discussion in 'UK Motorcycles' started by Donnie, Mar 2, 2010.
  1. Donnie
    Donnie Guest
    Right, bought a 2.5l ultrasonic cleaner from maplins and just been
    playing with it and put a cack old carb in
    to be honest it doesnt look much cleaner than it went in :-/
    am i missing a trick here or what?
    im using it on the heated setting, even a bit of washing up liquid in
    there too and on longest settings.
    Donnie, Mar 2, 2010
  2. Donnie
    'Hog Guest
    UC's are somewhat over rated but you might want to think about something a
    bit stronger on the old chemical front
    'Hog, Mar 2, 2010
  3. Donnie
    Jeweller Guest
    I use a UC regularly and for my purposes warm soapy water is good.
    I used to use ammonia in there too but it fairly stinks.
    I have wondered about using parafin or diesel (explosive?) for dirty
    bike bits or even a Gunk type additive in the mix.
    R100RT
    Aprilia Pegaso 650 IE "The Flying Mythos"
    Formerly: James Captain, A10, C15, B25, Dnepr M16 solo, R80/7, R100RT
    (green!)
    www.davidhowardjeweller.co.uk
    Jeweller, Mar 2, 2010
  4. Donnie
    Donnie Guest
    Pete Fisher said:
    Was about to do the latter then thought better and stripped it.
    what i didnt do at first though was clean any crud off it as i thought
    it may do that with the ultrasonics.
    I'm wondering if I should have degreased it and possibly a bit of brake
    cleaner to clean out any oil etc.
    It says it goes to a max of 65 degrees, and set it for the max time
    which is 8 mins.
    Donnie, Mar 2, 2010
  5. Donnie
    Donnie Guest
    'Hog said:
    hmm yes, it came with a flyer about some sea clean concentrate that
    will apparantly remove tarnishes, carbon and even rust it says.
    Donnie, Mar 2, 2010
  6. Donnie
    Pete Fisher Guest
    Ah, I do give things a bit of a blast with standard carb cleaner first.
    Mine can go much longer. I generally use a 30 degrees for 30 minutes
    cycle. Though Simon Wilson warns me I might burn it out if I repeat that
    too soon/often.
    | Pete Fisher at Home: |
    Pete Fisher, Mar 2, 2010
  7. Donnie
    Pete Fisher Guest
    I have a can of 'Green' i.e. eco friendly gunk in reserve, but the 50%
    Autoglym stuff seems to work OK. It certainly sorted out the Keihin from
    SWMBO's Honda.
  8. Donnie
    Donnie Guest
    Pete Fisher said:
    Is yours the ebay one, been looking at that now that I remember,
    thinking I might have been better spending the extra..
    Donnie, Mar 2, 2010
  9. Donnie
    Pete Fisher Guest
    Yes, I got mine from an Ebay source. I didn't know Maplins did one big
    enough to hold a carb body.
    I naughtily used it for a bit of hyper-degreasing on some rear
    suspension linkages recently (so that I could heat them in our cooker)
    and seem to have got away with it.
  10. Donnie
    petrolcan Guest
    SCISSORS, YOU ****. KNOW HOW TO USE THEM?
    petrolcan, Mar 2, 2010
  11. Donnie
    Donnie Guest
    petrolcan said:
    Jaysus, to think I share the same genepool as that, still, I know it
    got shallower as time went on :)
    Donnie, Mar 3, 2010
  12. Donnie
    Donnie Guest
    Pete Fisher said:
    Tis only a small carb to be fair, but now Ive looked im thinking I
    should have planned on it being able to take larger ones :-( A YTC
    number in the making methinks.
    Donnie, Mar 3, 2010
  13. Maybe try some Clit Bang in it.
    Grimly Curmudgeon, Mar 3, 2010
