FOAK: PC powerdown problems.
Discussion in 'UK Motorcycles' started by Salad Dodger, Jun 25, 2006.
  1. Salad Dodger
    Salad Dodger Guest
    Sat there typing away, when the PC just turns itself off. All attempts
    to turn on again lead to 10-15 seconds of fan spinning and disc
    revving, then it turns itself off again.
    What should I look at first?
    This lappie is a bit awkward for typing on.
  2. Salad Dodger
    Macie Guest
    So nothing else - no boot screen, no beeps?
    Macie, Jun 25, 2006
  3. Salad Dodger
    SD Guest
    No, nothing.
    As you may be able to tell - it's now working fine.
    Everything was *very* hot inside, though. Fan looks a little slower
    than I remember.
    | ___ Salad Dodger
    |_\_____/_| ..80264../..21661.../..31308.
    '^' RBR'06 Points: 75 Miles: 317
    SD, Jun 25, 2006
  4. CPU fan clean time? Get all the pubic hair and dead skin out of the fan
    and fins on the CPU.
    eric the brave, Jun 25, 2006
  5. Salad Dodger
    catman Guest
    Sounds like it's overheating. Give it a hoover out inside, see if that
    helps.
    Failing that I've seen plenty where the thermal transfer paste between the
    PCU and heatsink gives up
    www.cuore-sportivo.co.uk
    catman, Jun 25, 2006
  6. Salad Dodger
    Cab Guest
    I need some mind bleach now. I really don't want to imagine SD in the
    buff, surfing the web.
    Cab, Jun 25, 2006
  7. Salad Dodger
    SD Guest
    There was a lot of dust[1], and the CPU/motherboard fit wasn't the
    most secure I've ever seen.
    All back together now - but I think I'll get a new/bigger fan just to
    be on the safe side
    I'm not *that* keen on the image myself, tbh.
    [1] That dark brown sticky dust, that non-smokers won't recognise.
    | ___ Salad Dodger
    SD, Jun 25, 2006
  8. SD wrote
    Fresh London Air?
    I have always wondered what that dust is composed of that appears when
    the puddle dries up when you hang your gear[1] up after a wet ride. Why
    is it a sort of red colour for a start, is it mostly composed of rust
    dust?
    [1] Textile of course, it don't seem the same with leathers. Mind you
    it is about 20 years since I was last out in the rain in leather.
    steve auvache, Jun 25, 2006
  9. The PSU. Classic cause of symptoms like that. Chuck out the shite OEM
    one and spend at least 30quid on a replacement - in PSUs you largely get
    what you pay for.
    Grimly Curmudgeon, Jun 25, 2006
  10. I was thinking more of treacle myself.
  11. Salad Dodger
    Dan White Guest
    I had this last week. Overheating would be my guess. Mine was ok once I left
    it 10 mins and then took the side of the tower off.
    Dan White, Jun 25, 2006
  12. Non-functional fans, clogged filters, etc. In this weather it's
    almost certainly overheating.
    Check its heat-exchanger, too. They clog up with dust quite easily.
    I rigged up an experimental Peltier cooler to try to feed cool air
    to my laptop, but the hot side needs much more than convection cooling;
    with 3 amps at 12 V the heatsink gets very hot and the "cool" side
    basically stays at room temperature. :-(
    Dr Ivan D. Reid, Jun 25, 2006
  13. Let me know what type of CPU you have, drop me a mail and I'll sort you out
    a decent heatsink from my cupboard of samples.
    Brownz \(mobile\), Jun 25, 2006
  14. Salad Dodger
    SD Guest
    Ohh, ta.
    Issa little square one.
    "System info" says: Intel Pentium 4 - 3.40 GHz
    It's currently got a big wavy heatsink thing on it - solid copper
    core.
    | ___ Salad Dodger
    SD, Jun 25, 2006
  15. Salad Dodger
    Cab Guest
    Luckily Brownz will be able to figure out your heatsink type from your
    description. Likley to be a 478 socket, no?
    Cab, Jun 25, 2006
  16. Are you running windoze ?
    Can you run http://www.cpuid.com/download/cpu-z-134.zip and post or mail the
    results.
    3.40 P4s came in both S478 & LGA775 flavours.
    Brownz \(mobile\), Jun 26, 2006
  17. Salad Dodger
    SD Guest
    Number of CPUs 2 (1 Physical)
    CPU #1
    APIC ID 0
    Name Intel Pentium 4
    Code name Prescott
    Specification Intel(R) Pentium(R) 4 CPU 3.40GHz
    Family/Model/Stepping F34
    Extended Family/Model 0/0
    Package mPGA-478 (2h)
    | ___ Salad Dodger
    SD, Jun 26, 2006
  18. Salad Dodger
    Cab Guest
    Handy program that.
    There y'go. 478, as I said.
    Cab, Jun 26, 2006
  19. Salad Dodger
    My monster multi-fanned tower was getting a bit warm around the CPU a
    couple of weeks ago, when ambient temp first exceeded 10C. It was all
    fine except the CPU heatsink which was fluffed to buggery. Half a can
    of compressed air and the CPU temp dropped by 15C.
    I really ought to find some filters for the fans that don't restrict
    airflow through them. I did try circles of ex-ZX-9R air filter, but
    that stuff is obviously designed to resist being dragged in to the
    inlet tract by a big four sucking huge lungfuls at a time and dropped
    the throughput of an 80mm fan by a couple of orders of magnitude. One
    day I'll remember to buy some pukka filters ... ;-)
    Pip, Jun 26, 2006
  20. Excellent..... any height restrictions ?
    Mail me your address and I'll pop one in the post.
    d w b r o w n z [ a t ] n t l w o r l d [ d o t ] c o m
    Brownz @ Work, Jun 26, 2006
