FOAK: Personal web servers
Discussion in 'UK Motorcycles' started by Mark Derbyshire, Dec 15, 2004.
  1. Right, I've just upgraded so I've got a spare Athlon XP2100+, motherboard
    and disk sitting in the spare room doing nothing.
    How do I, can I set up my own web server with my own site/files etc on it?
    How do I do it, what security do I need to put in place[1] etc, etc
    I found this 'KF Web Server 2.5' is it any good, if so how do I use it?
    Help would be most welcome, simply if possible
    Ta very mucho for any future advice and or sites
    [1] connected via a NAT modem/router with static IP
    Mark
    ZX12R-B1 (Blue)
    CG125 (hers)
    Blata Ninja 3.4
    BOTSWCAW#3
  2. Mark Derbyshire
    tallbloke Guest
    Apache on *nix is your best most secure bet without havingto spend money.
    tallbloke, Dec 15, 2004
  3. Mark Derbyshire
    Stonge Guest
    XP Pro comes with IIS.
    Win 98 comes with PWS.
    Both of which are good enough for most needs.
    Stonge, Dec 15, 2004
  4. Mark Derbyshire
    Spete Guest
    Don't, I speak from experience. Still running a webserver here (Apache), but
    due to limited upload speed and trading porn it's dead slow. I may be moving
    to external hosting thingy eventually.
    Spete
    www.gimmemoney.mine.nu
    www.spete.homeip.net
    Occasionally, I'll be consistent
    Spete, Dec 15, 2004
  5. tallbloke <> came forth with the following in
    uk.rec.motorcycles
    *Numpty Mode*
    *nix as in Sloaris or Linux[1]
    can '*nix' run on a pc based proccessor?
    [1] I really should know as most of the printers front end I work on are
    Sloaris 8 or Gnome
    Mark
    ZX12R-B1 (Blue)
    CG125 (hers)
    Blata Ninja 3.4
    BOTSWCAW#3
  6. Haven't got
    Have got along with NT, 2003 Pro and XP Home
    I never knew they had this inbuilt
    Mark
    ZX12R-B1 (Blue)
    CG125 (hers)
    Blata Ninja 3.4
    BOTSWCAW#3
  7. I spose it would be limited to your ISP's upload speed - Yes
    As to the porn, what's that then ;0)
    What I want to get away from is the 'exceeded max limit' probs you get with
    hosted sites. It only takes a 50Mb mpg and a few peeps downloading it to
    create that[1]
    [1]I'm on an unlimited connection
    Mark
    ZX12R-B1 (Blue)
    CG125 (hers)
    Blata Ninja 3.4
    BOTSWCAW#3
  8. Mark Derbyshire
    tallbloke Guest
    <blatent advert mode>
    I can offer a very cheap hosting deal on an external server which gives
    you loads of control and graphical site stats etc. Email me if you want
    more info.
    </bam>
  9. Mark Derbyshire
    thttpd on Linux is most simple to get to do bandwidth throttling, if you
    don't like your ADSL connection being clobbered.
    Muck, Dec 15, 2004
  10. Willdo. I see how my current ISP handles it sofar for a few days first to
    see if they start to complain
    Mark
    ZX12R-B1 (Blue)
    CG125 (hers)
    Blata Ninja 3.4
    BOTSWCAW#3
  11. Mark Derbyshire
    Antoine Guest
    You don't HAVE to have web hosting of course. But its generally nice to have
    the availability of server side stuff, but then you have to secure your
    server and make sure its on 100% of the time.
    I'm not into that expense, I am just using webspace (yeah I know, crap).
    Mind you that DOES include some web scripting stuff via my ISP, so might be
    worth questioning why you are trying to do it and if you have the resources
    (backup devices etc).
    Antoine
    Antoine, Dec 15, 2004
  12. Mark Derbyshire
    Mark Derbyshire scribbled on the back of a napkin:
    Either of them will run Apache w/o problems, but for your application
    I'd use either Linux or FreeBSD. Probably the latter...
    And yes, you can get Solaris 10 for x86 architectures again.
    Timo Geusch, Dec 15, 2004
  13. http://www.apache.org/
    genuine_froggie, Dec 15, 2004
  14. Mark Derbyshire
    I have Windows 2000 [1] running Apache. I use MS IIS as an FTP server
    (also does SMTP and NNTP).
    If you're familiar with Windows it's quick; easy and as secure as you're
    likely to need.
    Linux is not exactly quick and simple to learn. Alright if you've got
    time on your hands.
    Patched to buggery and make sure the permissions are set correctly on the
    FTP server.
    Took me a couple of hours to get set up the box and sort out the port
    forwarding on the firewall/router.
    [1] Admittedly it's the Server version but the only advantage that gives
    me as a non professional user is Terminal Services. You can run it
    without a monitor/keyboard etc. using RealVNC.
    sweller, Dec 15, 2004
  15. Mark Derbyshire
    prawn Guest
    I use http://www.indigostar.com/indigoperl.htm on my PC at home. It
    comes with Perl and apache and works straigt out of the box. I only use
    it my side of the firewall for testing, mind.
    I also have PHP and MySQL, which are a doddle to set up.
    prawn, Dec 15, 2004
  16. Mark Derbyshire
    Cab Guest
    Stonge bored us all completely to death with wittery prose along the
    lines of:
    Err, I don't think so. W2K Server family and W2K3 Server family yes, XP
    no.
    Cab, Dec 15, 2004
  17. Mark Derbyshire
    Eddie Guest
    Add or Remove Programs > Add/Remove Windows Components > IIS
    Eddie, Dec 15, 2004
  18. Mark Derbyshire
    Cab Guest
    Eddie bored us all completely to death with wittery prose along the
    lines of:
    Is that really installed (but not activated) by default? Hmm, I thought
    it wasn't.
    Cab, Dec 15, 2004
  19. Mark Derbyshire
    Eddie Guest
    Well, it "comes with" XP Pro, if that's what you mean. Whether it's in
    the default installation options, I can't remember.
    Eddie, Dec 15, 2004
  20. Mark Derbyshire
    W2K (non server) does.
