FOAK: Photo-printers
Discussion in 'UK Motorcycles' started by Derek Turner, Aug 21, 2007.
  1. Derek Turner
    Derek Turner Guest
    Seriously considering getting a dedicated photo printer, the sort that
    does up to A6, has an LCD screen and takes media. First question: what
    technology? Inkjets claim 1024 dpi or more these days, dye-sublimation
    seems to stuck at 300 dpi. Which is more resilient/cheaper to run/better
    quality photos at this size/more stable colours?. Is there a FOAK
    recommended model?
  2. Derek Turner
    Dunno about the FOAK, but I'm very impressed with the HP PhotoSmart
    C5180 I bought earlier this year.
    Quality is as good as I've ever seen - one test I did involved copying
    a proper photo print and I honestly couldn't tell the difference
    between the original and the copy, even with a magnifying glass. Both
    the colour match (with 6 seperate ink cartridges) and pixellation were
    indistinguishable.
    Speed isn't that great for photos, but I rarely print more than a
    couple in one go, so that's OK, and for normal text printing it's only
    a few seconds/page. It has the screen you're looking for, and with it
    the ability to edit/crop and print directly from various media cards,
    as well as via ethernet and USB ports.
    _______
    Ace, Aug 21, 2007
  3. Pro printing is dye-sub. Our lot makes OEM printers for at least one of
    the big photo companies.
    doetnietcomputeren, Aug 21, 2007
  4. Derek Turner
    Yuss but the kit and the consumables are more. Top quality inkjet with the
    right paper does for SoHo.
    Do you mean A6 or in fact A3 poster size?
    If it's smaller format, Epson R360
    www.morecomputers.co.uk/extra.asp?pn=C11C658021
    and can recommend this supplier
    If it's larger format high quality, Epson R1800
    www.morecomputers.co.uk/extra.asp?pn=C11C589021CU
    Hog, Aug 21, 2007
  5. Derek Turner
    Derek Turner Guest
    I really meant A6/6X4. My experience with ones that can do A4 is that
    they don't feed smaller sizes very easily or cleanly. Loading is
    one-at-a-time and fiddly. Besides, I wanted a small piece of kit. On the
    rare occasions I want to do A4 I can swap cartridges on my Deskjet 5150
    which does a very nice job.
  6. Derek Turner
    christofire Guest
    Dad has a C3210 all-in-one photosmart thing - printer/scanner/negative
    scanner, reads from usb/all manner of flash cards, usb+network.
    My only issue with it is that it seems to need a 100MB+ driver package
    installed before you can do anything with it. I've tried installing the
    lightweight(!) 50mb package, but that doesn't seem to work. His
    computer's slowed down a fair bit since installing it, but it does seem
    to be a good printer.
    christofire, Aug 21, 2007
  7. Derek Turner
    The HP 5180 has a dedicated 6x4 (or close sizes) paper tray, as well
    as the normal A4/letter tray. Piece of piss.
    But as someone else mentioned, there's a hefty driver installation
    required - using a generic driver printed OK, but I couldn't control
    which tray was used, leading to several wasted sheets. But although it
    does leave an app running all the time (which I usually close if I'm
    at work) I don't think it slows the machine down appreciably.
    _______
    Ace, Aug 21, 2007
  8. Derek Turner
    Derek Turner Guest
    I take it we're talking Windoze here? I'll check out the support linux
    before parting with money!
  9. Derek Turner
    Crashmatt Guest
    You still got the cornwall pictures you took? If so can you send me the
    one of me using the firestick, ta.
    Crashmatt, Aug 22, 2007
  10. Derek Turner
    Danny Guest
    I nearly bought a dye-sub printer (Hi-Touch HiTi 640PS), but when they
    sent sample images (including one of my own I emailed) I didn't like
    the output - reminded me a bit of the wax printers I used to test).
    Ended up with an Epson R1800 (A3 printer) and the output is superb.
    I've printed A3 prints from a fairly average 5mp Sony DSC-T100 with
    great results.
    I don't doubt that dye-sub is best, but there seems to be some
    difference between the model I got results from and what they use in
    the machines - what do you think that is? Is 300/400dpi the same in
    the bigger machines?
    Danny, Aug 22, 2007
  11. Derek Turner
    Danny Guest
    I have the Epson R1800 and it has never failed to feed anything from
    6x4 to A3 correctly. I just stuff a load of whatever paper I'm using
    and off it goes - prints CD's nicely as well.
    Danny, Aug 22, 2007
  12. Derek Turner
    Surprisingly enough, it comes with wondows and mac/OS drivers, but
    I've no idea if the Mac ones will work on linux. But you really needto
    use a driver, as tray selection, resolution, etc. is all
    software-controlled.
    _______
    Ace, Aug 22, 2007
  13. Unlikely - they both use CUPS but the Mac is BSD derived.
    Phil.
    Phil Launchbury, Aug 23, 2007
  14. Derek Turner
    dog Guest
    more to the point, the executable format is different (mach-o vs. elf).
    dog, Sep 3, 2007
