I am fitting a tow-bar to the Pan. I have a new trailer socket and cable to wire into the loom. Ideally I would like to break the cable between the loom and the trailer socket so that the tow-bar can easily be removed and disconnected when not needed. So... I need some kind of cable-mounted 7-pin plug and socket arrangement which will fit easily under the seat. I guess, because of its position in the dry it doesn't need to be too water/dust resistant but it does need to be able to carry the necessary current for stop-lights and indicators etc. So something beefier than audio DIN but less than mains. What says the FOAK? (The obvious answer of an extra SN12 trailer plug and socket will be much too big to fit under the seat, I suspect). tia
