FOAK Traveling in Europe on the bike
Discussion in 'UK Motorcycles' started by AJ Peters, May 2, 2006.
  1. AJ Peters
    Cab Guest
    Bad form, etc. No 28 can be yours. Otherwise you'll have to fight DNC.
    Cab, May 3, 2006
    #61
  2. AJ Peters
    Cab Guest
    Tosspot wrote:
    <snip stuff>
    Do you have a UKRMMA no? Want one? No 29 is going.
    Cab, May 3, 2006
    #62
  3. AJ Peters
    Tosspot Guest
    Ta very muchly for the offer, but I have been studiously avoiding such
    numbers to avoid being labelled as 'In The Clique', iyswim.
    Other than, of course, the much coveted YTC numbers, but I havent found
    anything stupid enough to do to warrant one.
    Tosspot, May 3, 2006
    #63
  4. AJ Peters
    Tosspot Guest
    Yep, in France (where I was stopped), Switzerland, Germany (the latter
    of course are the same), though not so much in Spain or eastern europe.
    I actually forgot to mention a small speeding incident in Hungary,
    taking the toll up to 2:1:1, stopped 4 times in total.
    You lights do have a kickup don't they? The Trophy has a very
    pronounced kickup and coupled with luggage/pillion combinations caused
    all sorts of flashes from oncoming drivers. The 'Bird is symetrical.
    I'm on the fence on that one, but what I do object to is having two
    lamps but only one comes on so if you blow a bulb it goes dark. Wtf is
    wrong with having them both on?
    Germany it's compulsory to have lights on as well. Common Euro legislation?
    #64
  5. AJ Peters
    Spete Guest
    Mpeg, mpeg, mpe.... oh wait, that would involve me, wouldn't it.
    Never mind...
    Spete, May 3, 2006
    #65
  6. AJ Peters
    Spete Guest
    Unless it expires, otherwise no (I hope, still riding on Irish license)
    Spete, May 3, 2006
    #66
  7. The plates on the car/bikes, yes, as they are resident etc.
    For the licence, you are correct, I shouldn't need to - however, there
    is case after case on many an expat forum, where Brits with valid UK
    licences, in the Photocard format, being fined for not swapping to a
    cloggy licence after 6 months residence.
    I'm figuring I apply now for a replacement UK licence, swap the current
    one for a cloggy licence and have one of each. Best (and worst) of both
    worlds.
    Dnc
    B1200 - +30bhp ~|~ ZZR1100 - faster when upright
    V2300 - flat cap and rug ~|~ A6 2.5TDi V6 Quattro Sport
    DoetNietComputeren, May 3, 2006
    #67
  8. I would strongly suggest you follow my plan in other post - just to save
    yourself any potential grief. Especially as you're native and speaka da
    lingo - even less excuse.
    Dnc
    #68
  9. AJ Peters
    Be careful - when you swap your UK one for the cloggy one it will be
    returned to DVLA, so you will no longer appear as having a licence.
    Then again, you would only be showing it outside the UK, I suppose...
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, May 3, 2006
    #69
  10. This is only partially true. Your driving test pass and subsequently
    issued licence is valid until you are 70 unless revoked. So, whilst they
    might have a record of "currently driving on a cloggy licence", finding
    an "old" licence "down the back of the sofa" shouldn't cause too much of
    a problem.
    *ding*
    Dnc
    #70
  11. Bad form, the new photocards are only valid 10 years as a document, but
    the right/privilege to drive is still valid until 70.
    Dnc
    #71
  12. AJ Peters
    YTC#1 Guest
    That was a fun run wasn't it :)
    YTC#1, May 3, 2006
    #72
  13. AJ Peters
    I would if it came with one, but I was told when I bought it that as
    it was a cat C write off, the insco kept all the documents. Not
    totally sure I believe this, I can't see why they'd keep user manuals,
    etc.
    Pip Luscher, May 3, 2006
    #73
  14. AJ Peters
    Owen Guest
    I have a new van and porridge. The well is dank?[/QUOTE]
    I have a skin helping van and porridge... HTH...
    Owen, May 3, 2006
    #74
  15. AJ Peters
    Owen Guest
    Take a hazard triangle...
    Owen, May 3, 2006
    #75
  16. Roughly: you have the intellect of a poffertje
    Poffertje being a tiny little pancake type thing. Far too moreish to be
    safe in my house.
    Dnc
    #76
  17. AJ Peters
    zymurgy Guest
    And I don't take those either. I take photocopies of them, and a
    passport !
    That's what we have foreign embassies for ;-)
    P.
    zymurgy, May 15, 2006
    #77
