FOAK : Tyre valves
Discussion in 'UK Motorcycles' started by Steve, Nov 23, 2009.
  1. Steve
    Steve Guest
    I have a leaky valve stem that losing 5psi a day - its leaking around
    where the valve enters the wheel.
    Is there a bodge to seal it up or will I have to get this tyre off the
    damn wheel?
    Steve
    Steve, Nov 23, 2009
  2. Steve
    Nige Guest
    Slime
    Nige, Nov 23, 2009
  3. Steve
    I'd go with that - and asap, too: if the thing is leaking then it's
    either damaged or perished and losing the valve to sudden failure, at
    speed, could be a little uncomfortable.
    Pip, Nov 23, 2009
  4. Steve
    Yes, but: you're a racer, a demonstrably competent road rider - and a
    really lucky ****. I'd say that in comparison a mere mortal might find
    things like this more difficult to cope with, and that's why I used the
    phrase "a little uncomfortable" rather than a more emotive YER GONNA
    CRASH AND DIE!!!!
    If you see what I mean. Like.
    Pip, Nov 23, 2009
  5. Steve
    "A little uncomfortable" might still be overstretching it. Although I
    suppose in conjuncion with "might" I'd allow it.
    Only time it happened to me was on a French autoroute returning from
    watching the ecclipse in 1999, and I almost didn't notice it at all.
    Stopped for petrol, then rejoined motorway and accelerated up to a ton
    or so, only thinking after a few minutes that it felt just a little
    bit squidgy, and continuing to ride for perhaps another five minutes
    before deciding I ought to check what the problem was. I was utterly
    gobsmacked to find that the rear tyre was absolutely completely flat.
    Ace, Nov 23, 2009
  6. Steve
    Only blowout I've had was in the Porsche, doing 140ish on the Swindon
    ring road. Span it right round (thankfully without hitting anything) &
    left me a tad more than slightly breathless.
    Krusty, Nov 23, 2009
  7. Steve
    Dave Emerson Guest
    My SOB CBX550 had a similar problem, with no obvious damage to the tyre or
    the rim.
    In a (rare) flash of inspiration, or should that be desperation, I tried the
    following...
    - With the bike on the stand and an axle-stand under the engine, taking the
    weight off the front wheel.
    - Removed the valve core and totally deflated the tyre.
    - Sprayed Holts Rubber Lubricant around the valve housing and the valve hole
    in the rim, working the housing by hand until it would turn with little
    effort.
    - Replaced the valve core and reinflated the tyre.
    This resulted in no subsequent loss of air for the next five years I had the
    bike.
    YMMV but it's worth a try and can't do any harm.
    Dave Emerson, Nov 23, 2009
  8. Steve
    Pete Fisher Guest
    Tubed tyres can let go pretty quick too. The rear on the Morini 375
    rapidly deflated on Pahnd Island a quarter of a century ago. I was
    coming down in to Foxdale off the Round Table road. Used all my side of
    the road and a bit of the other on a fastish left hander before bringing
    it to a halt.
    | Pete Fisher at Home: |
    Pete Fisher, Nov 23, 2009
  9. Steve
    Strangely, the faster you go, the less these kind of things bother you.
    I was riding Ratty's ZX6R round Mallory the other week and got quite
    used to the arse end spinning up on the power out of every corner
    because the tyre was fucked. If that sort of thing happens on the road
    at half the speed, I crap myself, but I just carried on going at the
    same pace and got used to it.
    Lozzo, Nov 23, 2009
  10. Deflate tyre, slacken valve stem nut, push down stem, finger in some
    silicone sealant, tighten back up. It'll work for a while, but not a
    substitute for a proper removal and cleanup/replacement.
    Grimly Curmudgeon, Nov 23, 2009
