FOAK: Video cameras
Discussion in 'UK Motorcycles' started by Ben, Nov 14, 2006.
  1. Ben
    Ben Guest
    This is a "what do I want to buy" post.
    Anya wants a video camera for Chrimbo, so I've managed to come up with
    a budget of 500 notes, but I know bugger all about vid cameras.
    What do I want to look for? I guess my only real requirement is that
    it can be easily connected to the laptop (which has Firewire 400 and
    USB2 ports) so that the film can be pulled off to turn into dvd. I
    know how to author dvds from mpgs and avis, but I don't know what's
    the best way to transfer from camera to 'puter.
    Cheers FOAK.
    Ben, Nov 14, 2006
  2. Ben
    Switters Guest
    Panasonic NV-GS300 - 3CCD, Leica lens, Optical stabalisation, 16x9 mode.
    Of course, there will be others, but I don't follow the other brands so
    much these days.
    Firewire. You can use USB2 on some camcorders, but firewire is the best,
    and most reliable.
    Switters, Nov 14, 2006
  3. Ben
    peter Guest
    Seconded. Works a treat with a Sony camcorder connected to my VAIO.
    Controls it from the DVgate app.
    peter, Nov 14, 2006
  4. Ben
    Ben Guest
    One for the list then.
    How does the stuff transfer across? Does it just 'play' and you need
    to capture it, or does it copy across an mpeg2?
    And ultra-thick question of the day... What do these things actually
    record onto in the camera? I'm assuming they don't use solid state
    memory yet.
    Ben, Nov 14, 2006
  5. Ben
    peter Guest
    In my case the full DV on the tape in the camcorder is captured on the
    PC.
    Sony DVGate application controls the playback of the camcoder and you
    click to start and stop capture of the clip you want.
    On mine the full DV is on tape, but it can also hold short MPEG clips
    in 'memory' - a bit like the latest digital still cameras. These can be
    copied across by USB, or, if on a memory card, via a card reader.
    peter, Nov 14, 2006
  6. Ben
    Vass Guest
    if you go down this route I'd suggest one with a LANC control input too
    so you can record on/off from a switch on the handlebar
    Vass, Nov 14, 2006
  7. Ben
    Ben Guest
    Thanks.
    Ben, Nov 14, 2006
  8. Ben
    Veggie Dave Guest
    Firewire.
    Veggie Dave
    UKRMHRC#2 BOTAFOF#08
    IQ 18 FILMS http://www.iq18films.com
    POST PRODUCTION http://www.iq18films.co.uk
    Toxic Shock Syndrome Gets More Girls Than Me
    Veggie Dave, Nov 14, 2006
  9. Ben
    Veggie Dave Guest
    It's just a cable that connects one drive to another. The actual
    captured file type is dictated by the software you use.
    Do not capture to MPG2 if you have that option. If it's a Windows system
    and you're not using Avid, then capture as AVI. Let your NLE do the
    converting to MPG2 once you've finished assembling your project.
    Veggie Dave
  10. Ben
    Vass Guest
    DVD camcorders seem to be popular
    then there is no transfer issues
    Vass, Nov 14, 2006
  11. Ben
    Veggie Dave Guest
    The quality is also shite.
    Veggie Dave
  12. Ben
    Vass Guest
    ah, as you were then
    Vass, Nov 14, 2006
  13. Ben
    Ben Guest
    NLE?
    Ben, Nov 14, 2006
  14. Ben
    Veggie Dave Guest
    Sorry. It's your editing software [1]. Although you can let the DVD
    software do the converting, you get a lot more control, and therefore a
    better quality file, if you convert from your editor.
    [1] Non Linear Editor.
    Veggie Dave
  15. Ben
    Switters Guest
    Adding to what others have said, some editors offer a capture mode.
    Firewire allows control codes to be sent down it, so the software on your
    computer can rewind the tape, and then play it to grab the video. The
    data is captured at high quality rate that will eat disc at around
    210MB/minute of video into an AVI file. Yes you can capture as MPEG, but
    you're then stuck with a seriously compressed file, which gives you less
    options for editing.
    Most, including the one I quoted, use DV tapes. With the 3CCD and 16x9
    mode, it's great quality. It's not High Def, but it's pretty rocking.
    There are some camcorders that have hard discs, and others that use
    recordable DVDs. If you're not bothered about editing, then these are OK
    options - particularly for techno-biffs who just want to record something
    and slap it in a DVD player when they get home.
    Using DV tape is the "real" way of doing it, but it's more involved to get
    the video to DVD. At the very simplest, you capture to the computer and
    pass the AVI files to a DVD creator. The more creative you want to be,
    the more steps are involved.
  16. I bought a Panasonic NV-GS 180 3ccd jobby. Under £300 and the
    performance is stunning.
    What he says.
    Mick Whittingham, Nov 14, 2006
