FOAK: Waterproof coats
Discussion in 'UK Motorcycles' started by Fr Jack, Dec 3, 2007.
  1. Fr Jack
    Fr Jack Guest
  2. Fr Jack
    DDastardly Guest
    DDastardly, Dec 3, 2007
  3. Fr Jack
    I got an everyday coat for traipsing to/from lectures. It is made from the
    same sort of material as a donkey jacket but is shaped like a duffle coat.
    No toggles. Very warm, windproof and suprisingly waterproof. It's wearing
    well, on it's 4th winter.
    Cost £25 from Primark.
    wessie, Dec 3, 2007
  4. Fr Jack
    Fr Jack Guest
    It will be for general bimbling about.
    Needs to be breathable and waterproof enough for a half hour walk in
    rain.
    I picked that particular jacket for the long fitting - I have a long
    bod and find many jackets/coats are cut too short for me.
  5. Fr Jack
    simonk Guest
    Goretex is overkill for everyday use - and not a brilliant combination of
    waterproofness and breathability.
    Membrane-based stuff is only breathable under certain conditions - ideally
    when there's a strong temperature and humidity gradient. So it'll work best
    in very cold, dry conditions - and not so well when you're walking through a
    rainstorm at 15deg.C. Not ideal for England, then.
    If you want to keep dry while pottering around, you will do as well to get a
    cheapo own brand waterproof coat from Millets - you'll sweat like a rapist,
    but goretex wouldn't do you much better and you'd be a hundred quid richer.
    If you want proper waterproof and breathable, I can recommend Paramo stuff,
    but it's not cheap, and hard to come by. To truly be comfortable in all
    weathers in the UK, though, you need to embrace soft-shell, and banish these
    old-fashioned notions of dryness...
    simonk, Dec 4, 2007
  6. Fr Jack
    Go for something that's breathable but not Goretex. I used to use a
    Lowe Alpine jacket for fucking about on mountains but the price
    differences aren't as great as they were a few years ago.
    FWIW, I don't think £145 is a bad price for a Goretex jacket from a
    reputable manufacturer. If cost is a priority get a few bin liners and
    I'll post you some gaffer tape to hold it all together.
    Andy Bonwick, Dec 4, 2007
  7. Fr Jack
    Fr Jack Guest
    Heh!
    Fr Jack, Dec 4, 2007
  8. Fr Jack
    darsy, Dec 4, 2007
  9. Fr Jack
    I bought a Eckl Kawasaki waterproof a couple of years ago direct from
    the team and it's the single greatest big of wet-weather clothing I've
    ever owned. Not only is it more watertight than the prosecution case
    against Ian Huntley, it's lime green to boot.
    ogden, Dec 4, 2007
  10. Fr Jack
    Pete Fisher Guest
    For standing around waving a fishing rod and a bit of light walking I
    still rate a Barbour (with fleece lining if cold), but for more
    strenuous activity I am really pleased with a Berghaus Tempest jacket I
    acquired in the spring. Not Goretex but 'Aquafoil'. So far 100%
    waterproof. Very light and soft. I made sure it was loose enough to get
    warm layers underneath if required. About 90 quid from Barretts Outdoor.
    Only problem for you would be the length.
    | Pete Fisher at Home: |
    Pete Fisher, Dec 4, 2007
  11. Fr Jack
    Pete Fisher Guest
    The lad has a similar one we got from the BMF show a couple of years
    ago. Amazingly hard wearing, despite wash after wash. He has finally
    conceded that it is too small for him, so a replacement is being sought.
    Pete Fisher, Dec 5, 2007
