FOAK: XP won't load web pages.
Discussion in 'UK Motorcycles' started by Krusty, Nov 30, 2005.
  1. Krusty
    Good grief no. If I can't get this working I'll install Win 2003 Server.
    Krusty.
    http://www.muddystuff.co.uk
    http://www.muddystuff.us
    Off-road classifieds
    '02 MV Senna '96 Tiger '79 Fantic 250
  2. Krusty
    John Guest
    OK, so we know that the underlying IP connectivity works. So I suspect it's
    an issue with IE not using the system settings. I'm a little out of my depth
    here as I'm one of the dreaded Unix folks.
    I did see that you are not using a proxy and have no settings for one -
    good.
    On the same window, make sure that you are not using automatically detect
    settings or config scripts.
    I would set the security to Internet at the moment as well.
    Did I read the you can get Google and Mozilla. V Strange. I would have
    thought that if you can get to them, you can get to anything else, unless
    there should be a Proxy running somewhere within Bulldog. I wonder if there
    is a proxy issue here?
    OK I know when to quit. I think that you need an XP / Bulldog person now.
    Sorry.
    J.
    John, Nov 30, 2005
  3. Krusty
    I can get to Nat West too. I've just trashed it & re-installed, & it's
    still doing it. It's very similar to a problem I hit with Internet
    Connection Sharing yonks ago - some sites would work & others wouldn't.
    ISTR the general consensus after Googling was something to do with
    packet sizes, & that tweaking the RWIN setting would sort it. I bought
    a router instead.
    Noooooo - don't leave me!!
    Krusty.
  4. Krusty
    It works! I'll post the solution here for the benefit of future
    Googleers.
    It was, as I suspected, an RWIN/MTU issue. My router MTU was set to
    Auto, which equated to 1492. I lowered it in increments of 10, & when I
    got to 1452, the problem went away - all websites now load.
    Krusty.
    Krusty, Dec 1, 2005
  5. Krusty
    dwb Guest
    So definitely Windows fault then? ;-)
    dwb, Dec 2, 2005
  6. Krusty
    Oh yes, absolutely. You'd think Microsoft would be able to make their
    software change my router settings wouldn't you - fucking useless
    tossers.
    Krusty.
    Krusty, Dec 2, 2005
  7. Krusty
    Catman Guest
    Using AOL by any chance?
    Catman MIB#14 SKoGA#6 TEAR#4 BOTAFOF#38 Apostle#21 COSOC#3 OMF#22
    Alfa 116 Giulietta 3.0l (Really) Sprint 1.7 156 TS S2
    www.cuore-sportivo.co.uk
    Catman, Dec 2, 2005
  8. Krusty
    Good grief no. I'd rather stick my data packets in an envelope & post
    them than have AOL anywhere near my computer.
    Krusty.
    Krusty, Dec 2, 2005
  9. Krusty
    Catman Guest
    Interesting. They are the only people I know that require a different MTU
    Catman, Dec 2, 2005
  10. Krusty
    It might be due to me using PPPoE & the router handling the
    dialing/loging on rather than the modem. The Linksys ADSL2MUE modem
    doesn't handle port fowarding, so using it as a bridge is the only way
    around that particular problem. It was fine at 1492 with Win2k, so
    presumably XP's a bit more picky.
    Krusty, Dec 2, 2005
