FOAK - ZZR600 chain clunking/back wheel squirming about
Discussion in 'UK Motorcycles' started by Miles Reading, Aug 28, 2008.
  1. Hello all
    Haven't posted here for ages!
    My zzr600 e3 has a problem with the back wheel/chain/something I dont
    know.
    Basically in any gear if you let off the throttle and coast for a bit
    say downhill, when you re-apply the power the chain clunks/snaps about
    and the rear wheel squims - it is almost as if the chain goes slack
    and when you re-apply the power it takes the slack back up instantly
    and the rear tyre squirms.
    The problem started co-incidently after I got a new rear tyre fitted,
    this being about 4 weeks into a new set of sprockets and a new chain.
    I figured the tyre place must have put something back incorrectly so I
    dismantled the rear wheel but everything was there and assembled
    correctly.
    I have now put on another new chain, figuring the issue was with the
    chain but the problem still persists, I have even tightened up the
    slack so there is only 20mm of movement but still no progress.
    Does anyone have any ideas - I cannot think what could is causing the
    issue.
    Cheers
  2. Cheers
    Tyre pressures are spot on - its almost like the chain becomes loose
    and then tighten up instantly under power - the tyre squirming is a
    result of the chain jolting and giving it a hard kick.
    Cheers
  3. I checked the cush drive when I dismantled the rear and it looks fine
    - ie it is in 1 piece and not cracked or stress fractured or anything.
    Many thanks
  4. Miles Reading
    Has the spindle been done up correctly?
    Are all spacers present & correct?
    If you grasp the rear wheel at the front (by the engine) & rear (by
    the number plate) , can you wiggle it? Ditto vertically?
    Can you wiggle the sprocket - does it move independently of the wheel
    either in-out, flappy-wise[1] or rotationally-wise[2]? The last one
    suggests that the rubbers were left out (I don't know ZZR600s so these
    might be built-in).
    Any sign of chewing on components near the chain?
    Swingarm play?
    Brake caliper torque rod done up correctly?
    [1][2] These are technical expressions.
    Pip Luscher, Aug 28, 2008
  5. I bet it's not.
    The Older Gentleman, Aug 28, 2008
  6. Miles Reading
    Dave Emerson Guest
    Something's gone back wrong.
    What's the wheel alignment like when checked with a straightedge or sighted
    by eye, ignoring any markings on the swingarm?
    Dave Emerson, Aug 28, 2008
  7. Not really an issue if it's squirming.
    A spacer is almost certainly missing.
    jackhackettuk, Aug 29, 2008
