FOAKs: Noise-cancelling earphones?
Discussion in 'UK Motorcycles' started by Rudy Lacchin, May 11, 2009.
  1. Rudy Lacchin
    Rudy Lacchin Guest
    Noise-cancelling ear-phones: any good? Do you use them? If so, which ones?
    I've glanced at the Sony MDRNC11 (I like Sony), Philips SHN2500 and JVC
    HA-NCX77.
    Better than the plain ordinary isolating ones (Sennheiser CX) which just
    keep the outside noise out and the inside noise in?
    I'll be using them on the bike. Possibly.
  2. Rudy Lacchin
    Both Ann and me have some JVC headphones and they seem to be working OK,
    but my experiments with noise cancelling earphones were a little
    disappointing. They lower noise levels but don't 'cancel' it and the
    earphones let too much ambient noise through.
    I prefer my Shure earphones with the foam "earplug" type bud on as
    they're far better at insulating you from background noise.
    I've never tried that - mine are mostly for plane use.
    Timo Geusch, May 11, 2009
  3. Rudy Lacchin
    Cab Guest
    I've got the JVC's you mentionned. Very bloody good for the price.
    Dunno 'bout that then. I use them on 'planes.
    Cab, May 11, 2009
  4. Rudy Lacchin
    Buzby Guest
    Got some cheapy Phillips ones in HK - great on the plane/train etc. Bit
    too lumpy for undeer the helmet.
    Buzby, May 11, 2009
  5. Rudy Lacchin
    B 650 Guest
    On a related note, what's the deal with earplugs? I bought some for the
    first time recently, after noticing a little ringing in the ears after
    long rides, but I cannot get the fuckers to stay in place while I put my
    helmet on (I've even reverted to perching helmet on top of head,
    sticking earplugs in, then quickly jamming helmet over bonce, but no
    luck...)
    B 650, May 12, 2009
  6. Rudy Lacchin
    you need to insert the plug into the ear canal - roll plug between fingers,
    tug down on ear lobe to open canal, insert ear plug into canal, about half
    the length of the plug. Stick finger in ear like Colin Irvine singing a
    ballad, until the plug has expanded in the canal[1]. Unless you are a
    freak, the plug should now stay inserted until you decide to extract it.
    [1] if you are not sure how long to wait then sing, in 6/8 time,
    "Lumps of plum pudding and pieces of pie,
    Me mother she gave me for telling a lie;
    She gave me so much I fear I shall die
    From lumps of plum pudding and pieces of pie"
    and you'll be done
    wessie, May 12, 2009
  7. Rudy Lacchin
    Cab Guest
    You've got weird ears. HTH.
    Cab, May 12, 2009
  8. Rudy Lacchin
    B 650 Guest
    alas, you're not the first to note this
    B 650, May 12, 2009
  9. Rudy Lacchin
    B 650 Guest
    Ah, I'll give that a go, cheers. As Cab has already astutely noted, I
    have odd shaped ears (in ear headphones fall out within seconds if I
    move at all).
    B 650, May 12, 2009
  10. Rudy Lacchin
    Colin Irvine Guest
    One doesn't stick one's finger actually into one's ear, one gently
    presses on the flap at the bottom of the opening of the ear to close
    it off.
    Colin Irvine, May 12, 2009
  11. Rudy Lacchin
    Or all of it, depending on shape. If I insert only half it'll pop
    straight back out again.
    Do you guys think that all ears are the same? There's no one technique
    for everyone, as each person's ears are unique to them. FWIW mine need
    me to grip the back of the ear and pull backwards ro open the canal.
    Pulling upwards does nothing, downwards slightly stretches but reduces
    the opening size.
    Ace, May 12, 2009
  12. Rudy Lacchin
    Yeah, they're a right pain for me an 'all. Never been able to use them
    for more than a few seconds at a time.
    Ace, May 12, 2009
  13. Rudy Lacchin
    Eiron Guest
    Assuming they are tapered foam plugs, you roll them, lick them, and stick them in all the way
    (or until you reach the eardrum, then pull them back a bit)
    Eiron, May 12, 2009
  14. Rudy Lacchin
    I have the same problem. A slight movement and they're out.
    I might get some of the over-ear clip-on ones, but I generally only use
    headphones on the train these days an it's not that common an
    occurrence so whether ICBA is a different matter.
    CT, May 12, 2009
  15. Rudy Lacchin
    Yes, by all means lick them. If you _like_ ear infections.
    Ace, May 12, 2009
  16. Rudy Lacchin
    Slips in easier if you lick the end first...
    platypus, May 12, 2009
  17. Rudy Lacchin
    Lady Nina Guest
    I know some people who not only give it a quick lick but actively suck
    the end.
    Makes me shudder.
    <reads back>
    Just to be clear I'm talking about earplugs.
    Lady Nina, May 12, 2009
  18. Rudy Lacchin
    The _taste_ alone would make me shudder, but all that warm moisture
    trapped in there for hours on end is asking for trouble.
    Yeah, what else ;-?
    Ace, May 12, 2009
  19. Never has done for me..
    Phil
    Phil Launchbury, May 12, 2009
  20. Rudy Lacchin
    Hateful things. I've tried cheap foam ones, better foam ones and even an
    uber-expensive set of custom-moulded ones with acoustic filters in them
    which were brilliant (if a bit over-effective on the volume reduction
    front) for gigs but **** all use on the bike.
    I tried making an effort and wore some riding up to the BOSM last month.
    I made it halfway to Kettering before I had to stop and take them out.
    ogden, May 12, 2009
